Old 08-05-2007, 10:35 PM   #4621
Very nice kenchan
Sydewynder is offline   Reply With Quote
Old 08-05-2007, 11:47 PM   #4622
thanks, Sydewynder!
i luv this kit.
kenchan is offline   Reply With Quote
Old 08-06-2007, 12:01 AM   #4623
Burlap's Avatar
Send a message via MSN to Burlap
Originally Posted by kenchan View Post
Awesome paint job there, very well done
Burlap is offline   Reply With Quote
Old 08-06-2007, 01:48 AM   #4624
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Hey all . .
I am running a swift on carpet currently with te M insert betwen the chassis halves. I am quite jealous of all the bodies available for the short chassis mini. Any suggestions on changing my current "M" set up to compensate for the shorter wheelbase? I am a bit hesitant to do this as my mini is quite dialed at the moment, but I would love to be able to run something other than the swift "bend over and give me $35 " body.
How well does the civic body fit the swift??? I ahve heard varied opinions on the fit, but haven't seen one in person.
Old 08-06-2007, 03:23 AM   #4625
straightspeed's Avatar
We see no noticeable difference between the medium and short wheelbase cars on carpet. In fact, all the quickest cars are SWB.
LEIGHTON BUZZARD MODEL CAR CLUB
straightspeed is offline   Reply With Quote
Old 08-06-2007, 06:16 AM   #4626
Hi, what's the thickest grease that I can use in my M03 gear diff?
kytan is offline   Reply With Quote
Old 08-06-2007, 06:29 AM   #4627
NT
NT's Avatar
Trader Rating: 21 (100%+)
If i said i've seen railway grease (ie full size train grease!) would you believe me?
NT is offline   Reply With Quote
Old 08-06-2007, 06:31 AM   #4628
I prefer either Corally Ball Diff lube, or Kyosho 30000 Diff Grease. The quickest Mini at my local club uses 300000 Silicon Diff Oil, but it does leak a tiny bit from the outdrives.
Tried various industrial and commercial grease's, none do the same job as the above.
One racer swears on water pump lube from days gone by, but we cant find anyone who sells it now.
Railway grease would work
Old 08-06-2007, 06:38 AM   #4629
thanks, burlap!
Old 08-06-2007, 07:47 AM   #4630
MD
MD's Avatar
Trader Rating: 105 (100%+)
andrewdoherty - For M03M bodies you may want to check out the HPI mini bodies. I don't know if the M03M is too long for the HPI Minis. Checkout the wheel base. I also found that Phil's Hobby Shop on line has some Tamiya bodies at a more reasonable price. They have the Tamiya M03L body, which I run, for $23.80.
kenchan - Great paint job!
MD is offline   Reply With Quote
Old 08-06-2007, 09:10 AM   #4631
The HPI Mini Cooper shell is for the SWB only. If you can find a Civic or Maita, I believe they're for MWB.
Its all here at the bottom of the page http://www.rc-mini.net/MiniWeb_Onlin...D7756B281E1090
Old 08-06-2007, 12:14 PM   #4632
thanks, MD!
Old 08-06-2007, 12:23 PM   #4633
MD
MD's Avatar
The HPI Civic might be close to fitting. HPI also has a mini body called the Concept 1 which is a Beetle body.
Old 08-07-2007, 04:36 AM   #4634
tony gray's Avatar
Civic and Miata are the right (225) wheelbase but don't fit.
Like on a lot of other things the body hits the servo mounts on an M03.
You can put the body on but it has to sit real high at the front and it looks crap...
The only 225mm alternative that I know of is the Audi TT from Proline. Only problem being that its been out of production for about 3 years...
The HPI Mini and/or VW Concept are both 210mm, they wont fit.
Solution? Pull out the spacer and run 210mm!
tony gray is offline   Reply With Quote
Old 08-07-2007, 05:18 AM   #4635
Burlap's Avatar
Got a heap of Mini parts in today from overseas, the limited edition uprights, tons of tyres and a 3Racing Ball diff.
Broke the TA03 one on the weekend when fixing it, so see what the 3Racing does.
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 05:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-02-2011 12:08 AM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 09:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 07:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 08:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
SEO by vBSEO 3.5.0
