Like Tree137Likes
Old 07-30-2007, 09:27 PM   #4591
the chassis is complete, test drove it. i was amazed how quiet it is vs
the original M03 that my wife built almost a decade ago... they must have
revised something in the gear box. car runs great.
here's how i programmed the throttle curve...
i didn't program the steering speeds for turn and return... motor's (mabuchi) not
really fast enough for that. lol
the chassis is running HPI oil dampers, mantaray ball diff, ball bearings,
XXL, hitec metal gear servo. i dont plan on making this thing that fast...
just for home use. i have a tamiya sport-tuned motor so i might run
that later on.
kenchan is offline   Reply With Quote
Old 07-30-2007, 09:51 PM   #4592
Send a message via AIM to minijosh Send a message via Yahoo to minijosh
Wink
I just finished building and painting my Suzuki Swift. For some reason I'm not a huge fan of the shell. Seemed weak when I was cutting it out but hopefully that was just the sides. Anyways, it's bone stock except for bearings in the gearbox. Now I'm on the hunt for some good oil shocks.
I placed the Tamiya ESC in the empty space in the center of the chassis. It fits perfect in the short section that divided the front from the rear. My rx will fit with ease all the way to the rear also.
As for racing my Mini last night, it didn't happen. Wife got home from Texas and is very jet lagged hehe. I was able to finish my car in peace.
minijosh is offline   Reply With Quote
Old 07-30-2007, 11:38 PM   #4593
straightspeed's Avatar
Originally Posted by rcarmchl View Post
silver can only, this would be the second time that I have broken the mount on the left side, it just cracks and breaks right off. It there a brace that can go betwwen the 2 servo mounting points that might make it flex less?
Yeah, Tech Racing and 3 Racing make them. Maybe others.
http://www.rcmart.com/catalog/produc...ducts_id=17754
Nice transponder mount as well.
LEIGHTON BUZZARD MODEL CAR CLUB
straightspeed is offline   Reply With Quote
Old 07-31-2007, 05:35 AM   #4594
MD
MD's Avatar
Trader Rating: 112 (100%+)
I haven't had my M03L out for over a year. My Mini Cooper body is showing the wear and the driver's lack of skill. Are there any other bodies, besides Tamiya, that will fit the chassis? Thanks.
MD is offline   Reply With Quote
Old 07-31-2007, 08:00 AM   #4595
Registered User
Bodywerx's Avatar
Send a message via MSN to Bodywerx
Anyone know if the M03 swaybars will fit the M04 ?
Bodywerx is offline   Reply With Quote
Old 07-31-2007, 11:39 AM   #4596
Default "cheater gears"
i have heard of an aftermarket product that replaces the gearbox gears in an m03 to give you a higher ratio. how do i check for this when teching a car or are these just a myth? if they are real, who makes them?
www.RennMultisport.com
frankrehnelt is offline   Reply With Quote
Old 07-31-2007, 12:34 PM   #4597
the m04 sway bars are totaly different but I saw ,on this thread that someone modded the mo3 bares for their m04
sportracer is offline   Reply With Quote
Old 07-31-2007, 02:10 PM   #4598
Tim K's Avatar
Eagle racing do a speed tuned gear set, the plastic is a different color to the Tamiya items. The eagle gears are much whiter than the Tamiya gears.
Tobee craft do a speed tuned gear set as well, this has a 2 piece spur/idler, the idler part is purple aluminium, the spur is held on with a clip allowing you to change to a 34, 35, 36 or 37T spur, the spurs can be either white or black.
You should be able to tech by removing the small motor cover where you can check pinion mesh and see the different color of the aftermarket gears.
Tim K is offline   Reply With Quote
Old 07-31-2007, 02:25 PM   #4599
RC MARKET's Avatar
New suspension arm
SPICE Hard type suspenion arm
RC MARKET is offline   Reply With Quote
Old 08-01-2007, 11:04 AM   #4600
afr0sch's Avatar
Trader Rating: 95 (100%+)
Send a message via MSN to afr0sch
Default Selling my mini - barely used - Check it OUT!
Here is the link to the 'For Sale' thread for my barely used mini. It comes with some upgrades and a bunch of extras in a complete package.
Thanks for looking!
http://www.rctech.net/forum/showthre...99#post3540299
Teaser pic -
afr0sch is offline   Reply With Quote
Old 08-02-2007, 02:42 AM   #4601
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Has anyone compiled a comprehensive list of tires for the M chassis cars. Perhaps even jsut the Tamiya tires would work. I wanna try out some different tire combos and seem to continually find new tamiya part numbers and there isn't always an explanation as to which compoud they are, if they're belted (which is called reinforced by Tamiya, corect?) and so forth. There even seems to be the same issue for me with the tamiya foam inserts. I'm not too interested in aftermarket tires, jsut the tamiya ones. I may have to start this compilation myself. : )
Heres all the info I have so far . . .
53254 S Grip Tires
50568 Radial Tires
53340 60D tires
53255 Foam Inserts
50686 Foam Inserts
50684 M Grip Tires
53215 M Chassis slicks
53222 M Chasis super slicks
I get the S grips and the M grips . . .
But whats the difference between the 50568, 53340, and the M Grip tires? And whats the difference between hte 53255 foam inserts and the 50686 inserts?
AWD
Old 08-02-2007, 05:46 AM   #4602
Jam-ehz's Avatar
Send a message via ICQ to Jam-ehz
53254 S Grip Tires
50568 Radial Tires
53340 60D tires
53255 Foam Inserts
50686 Foam Inserts
50684 M Grip Tires
AWD
The M and S grip use this pattern:
While the 50568 radials have more of a 'radial tire' pattern:
The S-grip has the softest rubber, then M-grip, and then likely the Radial. I've never seen the radial in use before..
53340 is the Type-A belted slick, looks just like the other Slicks except the stamp on the sidewall:
53222:
I'd say the Type-A is the softest then the two slicks.. I've never used the slicks before..
I would stick to the Type-A, and the S and M grips.. they cover every situation you'd be racing in.
The 53255 are the firmer inserts, usually the only ones I purchase for most racing.. I remembered the softer 50684's being light-blue, they must have changed the colour to that same dark-grey recently..
Jam-ehz is offline   Reply With Quote
Old 08-03-2007, 12:44 AM   #4603
perfect! Thank you!
Old 08-03-2007, 09:18 PM   #4604
Burlap's Avatar
Send a message via MSN to Burlap
I've noticed with my M03-M that it is wearing the insides of the front tyres mainly. It seems like only 1/3rd of the front tyres are getting any real contact with the track, even in straights. I am running the plastic uprights at the moment, but have a set of the Tamiya limited edition aluminium uprights on order at the moment. The tyres I am running on the front are the HPI X-Patterns.
The car doesn't seem to have a heap of bump steer, and since the top arms are non-adjustable, trying to give it neutral camber is near impossible.
One thing I am tempting to try is a set of rear top arms on the front, and see if it moves the wear pattern to the middle of the tyre.
Has anyone else dealt with front tyre wear issue? Or is it the case that "well it is always there"?
Burlap is offline   Reply With Quote
Old 08-03-2007, 10:08 PM   #4605
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
AW106, c-lyon
