Like Tree200Likes
Old 07-30-2007, 09:28 AM   #4576
rcarmchl's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Granpa View Post
Sorry---assumed it was the rt side where the servo mount bolts to the chassis. If you break the X-ray ends, you might as well use the Tamiya ball cups as they have very little play and will pop off before they break. Also, I assumed you were running a silvercan. If you're running a 27 turn stock or hotter, all bets are off as you'll break stuff that isn't even on the car.
silver can only, this would be the second time that I have broken the mount on the left side, it just cracks and breaks right off. It there a brace that can go betwwen the 2 servo mounting points that might make it flex less?
rcarmchl is offline   Reply With Quote
Old 07-30-2007, 10:18 AM   #4577
Try using the Tamiya ball cups. They'll pop off and won't transfer the load. Surprized you didn't break the arm on your servo saver before you broke the chassis .I'd racer pop a ball link back on before replacing a chassis. We were having probs with the rt side cause the screw that mounts the little tab that goes to the servo mount was too short and that broke rather easily. Best of luck on your breakage prob. sorry we weren't more help.
Granpa is offline   Reply With Quote
Old 07-30-2007, 10:45 AM   #4578
minimanintaiwan's Avatar
Default Tamiya Asia Cup 2007
You guys from down under making it!?
Venue: Beitou Sports Center in Taipei, Taiwan http://btsc.tms.gov.tw/en_index.htm
Race Schedule: September 14-16, 2007
minimanintaiwan is offline   Reply With Quote
Old 07-30-2007, 12:23 PM   #4579
GeekSpeed's Avatar
You guys still racing minis at SoCal? I am about to pull the trigger on getting an MO4L Beelte, but wanted to make sure there was still racing going on.
Now that I think about it, what setup should I start with? What tires, springs, etc. are popular over there?
Thanks.
GeekSpeed is offline   Reply With Quote
Old 07-30-2007, 12:56 PM   #4580
Core Creations's Avatar
Trader Rating: 95 (100%+)
Send a message via AIM to Core Creations
I have always used the stock servo saver with one of the c-ring springs off the Tamiya high torque servo saver snapped over the built stock saver...works awesome!
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 07-30-2007, 01:07 PM   #4581
Thanks.
Yes on frday nites. Right now, we're all running the MO3 and I haven't a clue as to what the setup is for a MO4L. Racing starts at 7PM and when we're not running the Mini's we're racing a 540 TC class. Stop by and check it out. Our turnouts have been small, not the 10 or so we used to get. Some of the guys who used to race can't make it on fridays so we're trying to build it up again.
Old 07-30-2007, 03:47 PM   #4582
GeekSpeed's Avatar
Ok gang, I just put an order in for an M04L Beetle, so hopefully that will be here in a week or so. I am going to get it ready to come out to SoCal for some racing. Granted, I’m a novice racer, so you all will probably mop the floor with me. I tried racing a TC3 a couple of years ago, but the touring cars kind of rubbed me the wrong way. It was all about who could spend the most money and kick the most ass, so that was not cool…. However, since you mentioned a 540 TC class, I might do that with the old TC3. That seems like a really good idea…
Just so I know what to start with, what kind of tires do you run on the Minis?
Old 07-30-2007, 03:58 PM   #4583
Customworksking's Avatar
Trader Rating: 73 (100%+)
Wink
buy all the tires M,S, and slicks...as soon as u get it going hit me up for some HP I can build u a motor ,if anything u will be fast ! the driving is up to u !
Customworksking is offline   Reply With Quote
Old 07-30-2007, 06:26 PM   #4584
Default motor question
any sugestions for breaking in johnson motor?do you run it until brushes are about halfway down touching com?how many amps should a good one have at 2 volts ? 1.2 amps?
motorhead68 is offline   Reply With Quote
Old 07-30-2007, 07:35 PM   #4585
Hello, I am looking for a set of mini tires that won't traction roll.
I tried almost all of the third party slicks, and they all do traction roll on my M03. The only tires that don't do it are the tamiyas and x-patterns(but they understeer more than I want it to). Any info on anti-traction roll set up with these high grip tires?
redbones is offline   Reply With Quote
Old 07-30-2007, 07:55 PM   #4586
You can try gluing the sidewalls of the front tires...that's usually the best fix.
Old 07-30-2007, 07:58 PM   #4587
Like coating CA to the sidewalls all the way up to the shoulders?
Old 07-30-2007, 08:00 PM   #4588
NT
NT's Avatar
Trader Rating: 21 (100%+)
Stiffer rear springs to get the back end to slide around a bit - its really the only way you'll stop it. Sway bars do nothing IMO.
Dump the whole car down low too - somewhere around the 4-5mm ride height and try to get the ESC and Rx inside the chassis to get the weight of the car lower as well
See how it goes
NT is offline   Reply With Quote
Old 07-30-2007, 08:10 PM   #4589
I have everything tucked in the rear compartment. All the wires are run internally, so nothing sits on top of the chassis. I use a lightweight futaba s9650 for the servo. Tried different camber, 5-2mm ride height, super hard inserts, etc. the 60Ds are nice, but it just doesn't have the responsiveness of the new slicks.
Old 07-30-2007, 08:21 PM   #4590
Regional Moderator
Darkseid's Avatar
Yeah. All the way up the sidewall from the rim to the top edge of the tire.
This leaves you with a tire that wont traction roll, but wont push through the corners. As taught to me by Core Creations.
TLR 22...Tamiya F104...
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
