Like Tree18Likes
Old 07-09-2007, 11:23 AM   #4426
HACHIROKU13BT's Avatar
Default TA-03 DIFF
Okay, i see now - thanks.
HACHIROKU13BT is offline   Reply With Quote
Old 07-11-2007, 06:40 AM   #4427
Burlap's Avatar
Send a message via MSN to Burlap
Ran my M03-M Swift for the first time last night. I'm running the black tin Tamiya Sports motor and TA03 ball diff in it and had a great time. The car has a bit of bump steer, which I'll fix with a different servo horn. Loved the way the car went, drove it like how I drive my 415, and seem to go pretty well, but you have to be really sensitive with throttle movement in corners. With mine the rear end will step out if you get off the throttle too quickly. Plus need to shoe-goo my screw in the diff, damn thing kept coming loose.
Great little car, can't wait to race it more.
Burlap is offline   Reply With Quote
Old 07-11-2007, 06:48 AM   #4428
Burlap's Avatar
Damn browser playing up
Old 07-11-2007, 08:45 AM   #4429
rcarmchl's Avatar
Trader Rating: 15 (100%+)
UMMMM - I think that is every M03!!!!!
rcarmchl is offline   Reply With Quote
Old 07-11-2007, 08:54 AM   #4430
Scottrik's Avatar
Trader Rating: 241 (100%+)
Yeah...I think it even has a part number. Comes in one of the bags...
Congressmen should wear uniforms like NASCAR drivers so we can identify their corporate sponsors.
THE REVOLUTION WILL NOT BE TELEVISED -Gil Scott-Heron (1949-2011)
Scottrik is offline   Reply With Quote
Old 07-11-2007, 09:14 AM   #4431
Core Creations's Avatar
Trader Rating: 92 (100%+)
Send a message via AIM to Core Creations
Probably part of the reason it's stepping out is because you shouldn't drive it like a sedan. You need to be more linear in the corners. The name of the game in mini is corner speed. And to keep all the speed you can you need to be smoother in the corners.
Mine has only ever stepped out if I have the wrong tires on the car. Otherwise if anything the car pushes a little off power and just pulls through the corner on power. No sign of stepping out.
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 07-11-2007, 02:32 PM   #4432
rcarmchl's Avatar
On the front arms of the M03 FWD....if I move the ball stud from the back position to the front...what effect will that have on the handling of the car?
Old 07-11-2007, 02:40 PM   #4433
I am assuming you mean the 2 options on the front steering knuckles? Using the back holes will make the steering smooth and linear. The forward holes will make the car mor aggressive and have much better turn in. I always use the forward holes.
Old 07-11-2007, 03:18 PM   #4434
rcarmchl's Avatar
you assumptions are correct..thanks for the help.
Old 07-11-2007, 04:07 PM   #4435
Burlap's Avatar
Thanks for the tip. I did notice that, still learning. Far easier to drive than the crappy F103GT I had.
Can't wait to run the Mini/Swift again
Old 07-11-2007, 04:49 PM   #4436
Capelracer's Avatar
Originally Posted by HACHIROKU13BT View Post
Please let me know. What is the benefit of placing the 5~6 shims inside the gear diff?
Where in the diff do you put the shims - any photos????
Cheers.....
Capelracer is offline   Reply With Quote
Old 07-11-2007, 04:59 PM   #4437
When your assembling the stock gear diff...the shims you use next to the output bevel gears as your assembling it. I personally use 2 on each side instead of the 1 described in the instructions. Here is a pic of the parts. The washer looking pieces are the shims.
Old 07-12-2007, 04:28 AM   #4438
RC MARKET's Avatar
new parts
RC MARKET is offline   Reply With Quote
Old 07-12-2007, 06:23 AM   #4439
rcarmchl's Avatar
For all you guys running the Aluminum knuckles on the M03...what size bearing are required for use?
Old 07-12-2007, 06:30 AM   #4440
Scottrik's Avatar
I've got Tamiya and 3-Racing aluminum knuckles...both take the standard 1150 (11 X 5 mm) bearings.
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
