Like Tree1Likes
Old 07-05-2007, 07:14 PM   #4411
Originally Posted by zipper View Post
I cant get on past the second page and it comes up with this
www.rc-mini.net
http://www.rc-mini.net/MiniWeb_A_02_04_07/Forum.html
You have requested a page or object that was not found on the server. This may be the result of a typo or broken link.
Error 404 Not Found (File does not exist: /home/htdocs/MiniWeb_A_02_04_07/Forum.html)
I get the same message.
Tony did ya forget to pay the bill?
Sydewynder is offline   Reply With Quote
Old 07-05-2007, 09:09 PM   #4412
tony gray's Avatar
Just checked, and about 75% of the source files are missing from the home server.. As to why that is I don't know.
However, by the time most people read this they should all be uploaded there again (I hope) although it's going to take a little while given the sheer amount of stuff that needs to be reloaded.
tony gray is offline   Reply With Quote
Old 07-05-2007, 10:45 PM   #4413
tony gray's Avatar
All fixed...
Although anyone who has anything other than the 'welcome' page (http://www.rc-mini.net) bookmarked will find that it no longer works.
I took the opportunity to reload a new (although it still looks the same) site completely so old bookmarks wont work.... But the site itself is back online again.
TG
Old 07-05-2007, 11:42 PM   #4414
sportsracer-5's Avatar
It now works in Safari too! Cool.
sportsracer-5 is offline   Reply With Quote
Old 07-06-2007, 12:57 AM   #4415
tony gray's Avatar
It does? Wow, I didn't even know I'd fixed that....
Old 07-06-2007, 12:37 PM   #4416
HACHIROKU13BT's Avatar
Default TA03 DIFF
Recently replaced the Manta Ray Diff w/ a TA03 Diff. Usually, the diff is tightened until it stops - then backed-up 90 degress. The TA03 keeps breaking loose. Does anybody have any recommedations???
HACHIROKU13BT is offline   Reply With Quote
Old 07-06-2007, 03:37 PM   #4417
tony gray's Avatar
Don't back it off at all. We run ours TIGHT.....
Old 07-06-2007, 03:44 PM   #4418
madjack's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to madjack
had the same problem, went back to the gear diff
madjack is offline   Reply With Quote
Old 07-06-2007, 06:16 PM   #4419
Default TA-03 Diff Problem
Thanks, was thinking about doing the same, but the ball diffs turning appears to be better w/ my style of driving. I think i'll keep trying to work w/ the TA-03 Diff.
Old 07-06-2007, 06:19 PM   #4420
Thank you for the advice. Let me try it turned tight. When turned tight, do you still use the ball diff grease supplied by Tamiya? If so, how much do you stuff inside the diff w/ the grease? I heard some people stuff the heck out of the diff w/ the grease??? What do you think?
Old 07-06-2007, 07:51 PM   #4421
rccardr's Avatar
Clean the diff screw threads with solvent, let dry, then use a little rubber cement or shoo goo on the threads when you put it back together. No more backee-outee!!!
I've never lost.
I've just been a little bit behind when time ran out...
RED DOT MOTORS- Fastest Titan 12T and silver can 540 motors in the known galaxy!
rccardr is offline   Reply With Quote
Old 07-08-2007, 08:09 PM   #4422
tony gray's Avatar
My diffs are built by the book, with standard Tamiya grease. AllI do is tighten the crap out of em.
As for the stuffing, thats for gear diffs. Works OK until it all leaks out..which it usually does!
Old 07-08-2007, 08:16 PM   #4423
Customworksking's Avatar
Trader Rating: 70 (100%+)
Red face
I run the kit diff with 5 to 6 shims in it till it's tight as it can get very lil diff action ....btw in a M03r
Customworksking is offline   Reply With Quote
Old 07-09-2007, 10:39 AM   #4424
Default TA-03 Diff Problems
*Thank you for the advice. Tested the M03 this weekend, w/ the diff tightened as much as possible. It works great! Although, the diff is tightened all the way, didn't feel any difference w/ the handling.
Please let me know. What is the benefit of placing the 5~6 shims inside the gear diff?
Old 07-09-2007, 11:48 AM   #4425
Red face diff
it is somewhat like a spool it will not unload as much side to side ..u will get much more rip out of turns
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 05:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-02-2011 12:08 AM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 09:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 07:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 08:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
