Like Tree23Likes
Old 06-27-2007, 12:01 AM   #4381
straightspeed's Avatar
Default Oops
My bad. I got all excited as the last couple of posts I read were about the M03R. (Logs of PC quietly, very embarrassed, and gets on with his work)
LEIGHTON BUZZARD MODEL CAR CLUB
straightspeed is offline   Reply With Quote
Old 06-27-2007, 12:21 AM   #4382
tony gray's Avatar
I wont point out your faux pas to anyone... Trust me!
tony gray is offline   Reply With Quote
Old 06-28-2007, 06:59 AM   #4383
Registered User
Bodywerx's Avatar
Send a message via MSN to Bodywerx
Anyone got a M04 chassis extension (M-L) to sell me?
Bodywerx is offline   Reply With Quote
Old 06-28-2007, 07:11 AM   #4384
Jam-ehz's Avatar
Send a message via ICQ to Jam-ehz
I may have one in my parts box.. I'll have to check at home this evening to make sure.
Jam-ehz is offline   Reply With Quote
Old 06-28-2007, 10:23 AM   #4385
MACH55's Avatar
Trader Rating: 22 (100%+)
Just picked up a M03, what ESC and servo and motor would go well??
Besides club race, also want to get into TCS. Any recommendations?
MACH55 is offline   Reply With Quote
Old 06-28-2007, 12:16 PM   #4386
Jam-ehz's Avatar
For TCS, motor choice isn't much of an issue, silver can all the way
I'd take any of the quantum comp ESC's for their lightness and small size, but even GTX'es will fit well inside the body. Just set them to regular stock racing mode. You can find these pretty cheap in the used forum, every ESC I own (Quantum Comp 1, GTX, Rapida Pro) I had bought used, and they all still work great. I don't even bother with capacitors or diodes for the most part, it's only a silver can motor..
Serious racers will get the ESC with the lowest on-resistance, the new Tekins look promising.. my main one is a Rapida Pro for my M-04M, the power-limiter is priceless for traction. It's a bit heavier than the Quantums, though, but the on-resistance is crazy low, is fully programmable, and I can set the frequency waaay down..
For a servo, anything like .12s or faster have always worked for me.. I keep it lightweight by using a plastic geared JR 4750. Torque really doesn't matter too much with these cars..
Old 06-28-2007, 12:32 PM   #4387
Registered User
Bodywerx's Avatar
What's your setup for carpet on the M04M Jam-ehz
Old 06-28-2007, 03:20 PM   #4388
Default M03m and M04m
Hi,
Just sharing. M03m swift and M04m (adjusted) Trueno AE86. Thanks.
joel
rccartips is offline   Reply With Quote
Old 06-29-2007, 08:30 AM   #4389
MACH55's Avatar
Do you guys know if there are pre-mounted wheels/tires for the M03?
If not, which rims/tires/inserts do you buy for TCS or club race?
Thanks in advance
Old 06-29-2007, 11:20 AM   #4390
Jam-ehz's Avatar
Thanks in advance
Nope, you just gotta roll yer own..
For fronts I like S-grips for asphalt, M-grips for carpet if it has a lotta traction. Use the firmer dark grey foam inserts, or try a double-stuff (TC insert cut to fit around the rim, and the foam insert around that) for maximum rollout..
For rears Type A's for clean asphalt and carpet, S-grips for parking lots and looser conditions. Use the same grey inserts.
The light blue ones that come with kits are just way too soft for anything.
I like the silver-plated Monte Carlo wheels myself.. The carbon reinforced rims may seem nice and solid, but have little give if you really hit something hard and may crack.
Whatever you do, make sure the foam doesn't bunch up in spots.. if you find a bump, roll the tire in between the length of your hands, concentrating on that spot and it will eventually "massage" out.
Old 06-29-2007, 05:42 PM   #4391
Default Nice Cars
RCARTIPS (Joel)
Your cars looks awesome! Nice job. Did anyone catch the Honda S2000 on www.rctvlive.com ? It is under classics it is the newest one. Not a bad little car.
Ginsu is offline   Reply With Quote
Old 06-30-2007, 03:39 PM   #4392
tony gray's Avatar
Sometimes I think my paintjobs are just getting siller and siller.... Or maybe its just the customers who ask me for them are getting siller?
Old 06-30-2007, 04:51 PM   #4393
Customworksking's Avatar
Trader Rating: 71 (100%+)
Wink paint
2 of mine
Customworksking is offline   Reply With Quote
Old 06-30-2007, 07:53 PM   #4394
Jam-ehz's Avatar
Yup! Got one for you.. posted it a while back, took a while to fish it out.. let's see..
M-04M Carpet Setup
Front:
TRF Short White springs
TRF Shocks, 85 wt oil, 2-hole pistons, 2 o-rings, no rebound
S-Grips, moulded insert (hard to find), 1/3 traction compound on inside
Sway bar
0-1 degree toe out, depends on how you like your steering.
Rear holes on the steering uprights (mine gets stuck on the chassis when it's on the inside holes)
Rear:
Short Fluorescent Red springs (53333 set)
TRF Shocks, 60 wt oil, 2-hole pistons, 3 o-rings, no rebound
Type A's, firm foam insert strip, full traction compound
5-6mm ride height all around
It's a very stiff setup in the front, and runs like a touring car.. no body roll for quick transitions, and at the same time I can run through the whole track full-throttle without flipping. If you need more steering, widen the strip of compound in the front.
Get the 2-degree rear uprights if you can, or just upgrade to the lightweight "M03M" set, it has 2 degrees already, and is very nimble.
Put the receiver and speedo on the sides like saddlebags, keeps the COG way low.
I use the Alfa body for TCS, and the HPI Miata for the other races.. love the rear wing..
That's the basis of the setup, the rest is optional.. aluminum hexes, rear universals, carbon gearshafts, TA03 Ball Diff w/ lightweight plates, aluminum screws with a few Ti in spots, but it's not that necessary.
This setup handles great, and the fl. red springs will keep your rear tires planted. Just make sure to put 1-2mm extra preload on the rear left shock because of the motor, keeps the car straighter when accelerating.
Old 07-01-2007, 04:00 AM   #4395
NT
NT's Avatar
Trader Rating: 21 (100%+)
No Comment....... You've seen my future ideas
Here's another example of Tony's Handiwork. Its even better in the flesh! The design comes from Felipe Massa's helmet.
NT is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
shmit 1
