Like Tree81Likes
Old 06-22-2005, 05:03 PM   #421
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
Mo3 uni's fit, not the sway bars though. ou'll need 53382
tamiyarcracer is offline   Reply With Quote
Old 06-22-2005, 08:03 PM   #422
thanks for your help tamiyarcracer going to order the parts .
sportracer is offline   Reply With Quote
Old 06-22-2005, 08:15 PM   #423
nozauta619's Avatar
Default M04M....
Thanks tamiyarcracer,
Any other parts that can share with the M03 and M04? Thanks.
Anthony
Kyosho Blizzard EP / Tamiya DF-03RA / Tamiya TA-03F / Traxxas Monster Jams Maximum Destruction / HPI Pro 3
nozauta619 is offline   Reply With Quote
Old 06-22-2005, 09:36 PM   #424
The suspension is the same from the M03 to the M04. The internal gears are the same, the rear (M03) wheel axle is the same as the front (M04). the Servo mounts are on the tree the suspesion is from. the rear bumpers are the same.
The heatsinks are different. the sway bars are different. (as for hop ups)
drive axles are the same unless you run the M04L (S2000 or Z3) they are are the longer ones from a gas car.
Old 06-22-2005, 10:01 PM   #425
nozauta619's Avatar
Thumbs up M04M....
Thanks again tamiyarcracer.
Anthony
Old 06-23-2005, 06:11 AM   #426
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
I have an MO4M, and was wondering if there is a spacer like the MO3 to lengthen it? i have a Z3 and one other body, and id like them to fit.... anyone know of one?
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 06-23-2005, 06:40 AM   #427
Aries326's Avatar
Trader Rating: 19 (100%+)
I've got a M04L and I was wondering if there are other bodies for it besides the Z3 and S2000. Also, what's the best bang for the money when it comes to oil filled shocks for it? I bought some GPM shocks that were supposed to be for the TT-01 and the guy selling it on eBay said it would also fit the M04L but it doesn't fit right. Thanks...
Aries326 is offline   Reply With Quote
Old 06-23-2005, 12:15 PM   #428
TRF Shocks, if cost is no object... I just bought used Tamiya Alu shocks, sadly not threaded... but only $30 cdn
MartynD is offline   Reply With Quote
Old 06-23-2005, 01:35 PM   #429
Aries326's Avatar
Unfortunately, cost is an object and that's why I bought the GPMs to begin with. Bad move. Maybe I'll look around eBay and see if I can get a good deal on shocks.
Old 06-23-2005, 03:41 PM   #430
Turbo yes there is an extender not sure I cannot remember the parts tree that it comes on though.
Aries there you could try the Boxster, Mercedes SLK and I think there was 1 other. They should all fit the 04L Originally they were all on the M02. Another option is to get the long arm set for the TB01 and you can run the Porsche GT1 body from a few years back. IT gets to be a handful with higher HP motors.
Also for shocks look for a set of the plastic shocks they are not the ultimate, but built with care they can perform better than a badly built set of aluminium shocks.
UF1 Seattle - SPEEDWERKES - VBC Racing - Team ORCA
Difuser is offline   Reply With Quote
Old 06-23-2005, 05:02 PM   #431
The extender comes with the center chassis section. part # 50851 Should have got it in your kit no matter what M04 you got.
Old 06-23-2005, 08:14 PM   #432
Turbonium's Avatar
yea, i got this one second-hand, so no spacer.
i have the Z3 and Boxster, and thought id use something different for the Memphis TCS, instead of all the Coopers! of course, the MO3 will be along, just in case the gearing difference kills me...
i also have the MO1, which i understand has the gearing a little taller... anyone have any experience with that one? thought about bringing it along, as well... the Memphis track is usually rather big!
Wes
Team Novak
Old 06-24-2005, 02:45 AM   #433
mild seven's Avatar
Trader Rating: 62 (100%+)
Send a message via MSN to mild seven
i own a m01 and a m02l
mild seven is offline   Reply With Quote
Old 06-24-2005, 05:12 AM   #434
Trader Rating: 35 (100%+)
Default HPI Mini Wheels
Anyone know if HPI's Mini Wheels will fit on the Tamiya Mini (M03L)? Will Tamiya Mini tires fit on the HPI Mini Wheels?
Geppetto is offline   Reply With Quote
Old 06-24-2005, 06:02 AM   #435
Turbonium's Avatar
yes, and yes... the wheels fit for sure, and i have interchanged the tires before, as well....
Wes
Team Novak
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
CW22
