Like Tree81Likes
Old 06-07-2007, 04:23 AM   #4201
Originally Posted by hierog View Post
can somebody verify if any of the HPI mini bodies fit the M03R? Specifically, i'm looking at the Civic body
thanks
vic
yes, it fits
frankrehnelt is offline   Reply With Quote
Old 06-07-2007, 10:09 AM   #4202
ckbridge's Avatar
Default HPI body on MO3M
Yes the HPI bodies fit but the shock tower on the MO3M is higher than the HPI MINI. I have the Golf body and the body sits right on the shock towers. I put a layer of butle tape then a disc of aluminum (beer can) the size of a dime then another layer of tape inside the body where the towers hit. It keeps the paint from getting torn up. The body still sets just a little high in the front.
ckbridge is offline   Reply With Quote
Old 06-07-2007, 06:57 PM   #4203
tbeardmore's Avatar
Originally Posted by andrewdoherty View Post
In Todd's case its defintely the car. I have seen him drive!!!
Just kidding Todd. Hoping to see you again at next year's Carpet Challenge.
LOL....
Thanks Andrew!! YOU'RE RIGHT!!!
BMI DB10R, Corally RDX PHi, BMI 12R..!!
Need a "real" car... contact me at:
www.beardmorechevy.com -or- www.beardmoresubaru.com
tbeardmore is offline   Reply With Quote
Old 06-07-2007, 07:39 PM   #4204
Fastforward's Avatar
Originally Posted by tbeardmore View Post
LOL....
Hey Todd, Big Bad Bob here. I just got a mini and some of the guys down here are getting into them too. I saw you post on free drive line. Are you using ball bearings? Any tips for us beginners?
Fastforward is offline   Reply With Quote
Old 06-07-2007, 07:53 PM   #4205
tbeardmore's Avatar
Hi Bob!
Make sure you add the extra bearings to replace the bushings... Use a bearing blaster to clean out the bearings and place a small drop of "thin" oil (I used WD-40 I put in a dropper) before you install them.
When you install the bearings, turn the plastic part upside down. If the bearing "doesn't" fall out.... you need to ream out the bearing housing slightly.. just enough so it'll drop out.
When you put the whole thing together, tighten the screws until they are "snug"... then back them out 3/4 turn so the casing won't bind the gears or bearings.....
Same thing when you put the motor in... but I only back out about a half turn...
Before putting the motor in... Free Spin the front wheels... if you get 12-15 seconds --- YOU'RE GOLDEN!!!!!
Old 06-07-2007, 08:15 PM   #4206
Hi Bob!
Before putting the motor in... Free Spin the front wheels... if you get 20-25 seconds --- YOU'RE GOLDEN!!!!!
Thanks Todd. Do you use the kit grease on the gears or run them dry? What about tire inserts? How about limiting shock travel, I guess we would call that seting droop in our C-dans.
thanks
BBB
Old 06-07-2007, 08:57 PM   #4207
minidriver's Avatar
Originally Posted by Big Daddy Boomer View Post
I thought I would post this. Trackside has started racing dirt Oval and Minidriver (Dave Weir) decided to put his mini in the mix in Stock and Man it looked good!
Boomer
Thanks Boomer.
I bet Tamiya never designed a mini with dirt oval racing in mind, but it is very fun to try. They threw me in with the off road buggies who were running 19 turn or brushless motors. It was a good choice - they were turning 5.1 sec best laps, I was at 5.2 secs on the dirt oval. Long chassis mini cooper, s grip tires, stock (not silver can) motor with 16 tooth pinion, tamiya shocks with staggered springs, staggered internal shock limiters (droop). Now I just need a little more practice in the art of "turning left only".
minidriver is offline   Reply With Quote
Old 06-08-2007, 06:40 AM   #4208
Hustler's Avatar
Originally Posted by minidriver View Post
Thanks Boomer.
M03 or 04? thx...
-Sean
Hustler is offline   Reply With Quote
Old 06-08-2007, 06:46 AM   #4209
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
Originally Posted by Hustler View Post
M03 or 04? thx...
-Sean
M03L
tamiyarcracer is offline   Reply With Quote
Old 06-08-2007, 06:52 AM   #4210
Core Creations's Avatar
Trader Rating: 93 (100%+)
Send a message via AIM to Core Creations
I've never needed to do any extra driveline work to make the car fast. Just put the bearings in the gear case and leave the gears dry....then run the crap out of the car. My car doesn't lack speed at all and that's all I have ver done.
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 06-08-2007, 05:39 PM   #4211
rcarmchl's Avatar
Trader Rating: 15 (100%+)
Originally Posted by TMcKinney711 View Post
Does anyone have a general M03 setup for out side asphalt? Thanks!
bueller? bueller? anyone?!?! anyone?!?!?
rcarmchl is offline   Reply With Quote
Old 06-08-2007, 06:13 PM   #4212
tony gray's Avatar
I would have thought that you may have visited our website by now to see what we recommend....
tony gray is offline   Reply With Quote
Old 06-08-2007, 06:22 PM   #4213
rcarmchl's Avatar
been there ...couldn't find it..you want to point the way?
Old 06-08-2007, 06:41 PM   #4214
tony gray's Avatar
Start here and work through...
Old 06-08-2007, 07:56 PM   #4215
RandomFellow's Avatar
A great resource!
RandomFellow is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
