Like Tree108Likes
Old 06-20-2005, 12:27 PM   #406
Nova F1 Racer's Avatar
R/C Tech Charter Subscriber
Does anyone have a list of bodies that will fit Tamiya's Mini Coopers, M03 and M03L versions?
THX
This is DICK!!! And you're NOT!
RC Tech member #11
Aussie Rules Footy, Brisbane LIONS!!
[url]http://www.pitter-pat.com/[/url] for pet care needs in Northern Virginia
Nova F1 Racer is offline   Reply With Quote
Old 06-20-2005, 05:21 PM   #407
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
Originally Posted by Kail
Thanks! But how do u stuff full size sedan inserts in? cutting them to correct size n regluing the inserts with ca?
Believe it or not the 24mm inserts fit perfectly to the tire carcus. No air gap
tamiyarcracer is offline   Reply With Quote
Old 06-21-2005, 10:03 AM   #408
hey what are the best rims and tires for just general play. I am looking for the best traction and longevity. I have quite a few sets. I burned through the stock tamiya radial tires in one battery. But I believe that was my fault for no throttle management. I have a set of HPI V groove that stick really well but not sure how long they will last, Tamiya slicks have good traction too but how long will they last? I don't race I just race around cones but I do like performance and traction, and longevity at the best price. seems as though the stock rims dont last very many hard crashes before the beads get messed up or winds up bent. do the tamiya reinforced rims handle crashes better than the stock or the HPI star rims? I have a set of new Tamiya alloy rims too but I don't think I will run them as if I did they shurly would wind up looking like crap. I got some new HPI tires last night. they stick really well. so well that while cornering the Mini flipped a couple of times. Some of my older HPI tires stick well but not that well.
gpwpat is offline   Reply With Quote
Old 06-21-2005, 12:45 PM   #409
Pat as for longevity of tire not sure what to tell you there. If you were able to run down a set of kit tires that quick it sounds like you surface is VERY abrasive. I always ran the Tamiya tires only and not the HPI, mainly this was due to TCS so no experience on the HPI tire. All said the Tamiya slick is a good tire and usually has long wear but again that is with the surfaces I run on.
As for rims yes the reinforced rim is better from a tweek standpoint but if you shock them real good you will still have the same issues of them cracking usually at the center.
Hope it all helps
UF1 Seattle - SPEEDWERKES - VBC Racing - Team ORCA
Difuser is offline   Reply With Quote
Old 06-21-2005, 02:49 PM   #410
rccardr's Avatar
For play tires, HPI X-Patterns work really well and seem to last forever around here (I used one set for two full seasons of non-TCS racing). As ugly as the rims get, they seldom really get bad enough for me to throw away. And if they seem to wobble on the axle, get a set of the clamp-on type wheel adapters from Tamiya (they're the silver ones). wOw.
And believe it or not, even the wode sedan inserts fit inside a mini tire. Some guys cut them down a little on the outside but if you really want to stuff a tire, that's the way to do it.
Later
Doc
I've never lost.
I've just been a little bit behind when time ran out...
RED DOT MOTORS- Fastest Titan 12T and silver can 540 motors in the known galaxy!
rccardr is offline   Reply With Quote
Old 06-21-2005, 03:22 PM   #411
Ok any body know the difference in handling for the belted hpi mini tire? What is the purpose of the belting? the seem to be a few dollars more. seems to keep the tread pattern flatter. maybe requiring not as much stuffing? The hpi tires I have now are not belted. and they seem to roll over during hard cornering. but I havn't stuffed them with anything other than the foam that came with the tire.
Old 06-21-2005, 04:05 PM   #412
RED-LINE M03's Avatar
Trader Rating: 127 (100%+)
Default Integy gears
Has anybody tried Integy gears and what was the out come?
We have a non TCS event coming next month and I want to change out my stock gearing.
RED-LINE M03 is offline   Reply With Quote
Old 06-21-2005, 05:08 PM   #413
ringo's Avatar
the belted tyres will hold their shape much better. makes them more predictable, and they'll wear more evenly. worth the $$$$.
Jarrod Currie
ringo is offline   Reply With Quote
Old 06-21-2005, 05:21 PM   #414
Thanks for the insight on the belted tires. I think I will order a few sets.
redline I have the integy gears on the way. they were shipped fedex yesterday so I should see them this weel. I will post my insight for you.
Old 06-22-2005, 04:28 PM   #415
can anyone please tell me the part#'s for the m04 chassis I want to convert my m03 to an mo4.
sportracer is offline   Reply With Quote
Old 06-22-2005, 04:48 PM   #416
50849 front and rear gearbox (A parts)
50850 Front Bumper mount and body posts (E parts)
50851 center frame (F parts)
6275061 Urethane bumper
I think that is all that is needed, all other parts are TL01 or M03
Old 06-22-2005, 04:51 PM   #417
cool thanks will the m03l cooper body fit or do i need another body also from a previous post their is a link to a site and their is a tray? for the servo that the esc sat in do you also have that part#. Thanks again.
Old 06-22-2005, 04:56 PM   #418
here is a picture
Old 06-22-2005, 04:57 PM   #419
They tray is there.
The body you'll want is the Mazda Miata / Enuos roadster. Hard to find I know Burien Toyoya had them. 1 800 654 6456 ask for Kevin
Old 06-22-2005, 04:58 PM   #420
nozauta619's Avatar
Red face M04M...?
I have a tamiya m04m. does the m03 universals fit this kit also? how about the m03 sway bars? what parts are compatible between m03 and m04?
Anthony
Kyosho Blizzard EP / Tamiya DF-03RA / Tamiya TA-03F / Traxxas Monster Jams Maximum Destruction / HPI Pro 3
nozauta619 is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
