Like Tree200Likes
Old 05-26-2007, 11:50 PM   #4111
Originally Posted by Scottrik
Hey,
I'm having trouble getting onto the RC Market site to complete an order. Any ideas?
Scottrik
As of yesterday they said their server is down. All the links on their thread come back dead.
Sydewynder is offline   Reply With Quote
Old 05-27-2007, 12:18 AM   #4112
Scottrik's Avatar
Trader Rating: 245 (100%+)
K--Roger that.
Thanks.
Scottrik
Congressmen should wear uniforms like NASCAR drivers so we can identify their corporate sponsors.
THE REVOLUTION WILL NOT BE TELEVISED -Gil Scott-Heron (1949-2011)
Scottrik is offline   Reply With Quote
Old 05-27-2007, 06:47 AM   #4113
Trader Rating: 44 (100%+)
Thanks again. I wasn't sure if the TB-02 axle stubs would be the right length.
M03R, M04L, TT-01R Type E, Midnight Pumpkin,
Lunch Box, CC-01 Wrangler, SC10.2FT,
SC10B, Traxxas Slash
minimadman2003 is offline   Reply With Quote
Old 05-29-2007, 08:11 PM   #4114
tony gray's Avatar
We dropped off to Pg 3! I thought I'd better post to bring it back to the front again...
tony gray is offline   Reply With Quote
Old 05-30-2007, 07:00 AM   #4115
Default Mini 1000
If anyone needs a good mini fix and wants to see Jonesboro Arkansas you must go to this race. Prize money at a mini race....oh my.
link to the thread:
ATTENTION! WANT TO TRY THIS?
link to the track:
http://www.rchobbiesraceway.com/
frankrehnelt is offline   Reply With Quote
Old 05-30-2007, 12:05 PM   #4116
what is everyone using for tires now that HPI in their infinite wisdom has discontinued the x-patterns. also any setup tips for carpet????
Granpa is offline   Reply With Quote
Old 05-31-2007, 01:06 AM   #4117
minimanintaiwan's Avatar
RP makes some 24R, 30R, 36R
and Spice 24R, 28R, 32R
Never tried them so dont have any performance information.
minimanintaiwan is offline   Reply With Quote
Old 06-01-2007, 11:08 AM   #4118
hierog's Avatar
hey all:
just built my first Mini (M03R). What a breeze to build. A few questions though:
I put on my TRF shocks and there is quite a bit of slop which causes the shock to move front to back - what did you guys do to correct this?
Also, the steering linkage rubs against the chassis - is anybody else having this problem?
thanks
vic
hierog is offline   Reply With Quote
Old 06-01-2007, 12:07 PM   #4119
Hawk6's Avatar
Trader Rating: 50 (100%+)
What I've learned from this thread, experience, and other racers:
Tamiya S-grip tires in front with maybe double inserts (to expand the diameter of the tire and effectively get a little more "gearing" or rollout)
Tamiya M-grip tires with standard inserts in rear
70 wt oil front with short white (stiff) springs
50 wt oil in rear with short yellow (medium) springs
Internal spacers in shocks to lower ride height.
Shimmed gear diff or tightened ball diff to get better acceleration out of corners.
I think that's about it. My son's spun out at the TCS race, so we were advised to just use traction compound on the inside 1/4 of the front tires and all the way across the rears.
That's our set-up. Good luck.
Hawk6 is offline   Reply With Quote
Old 06-01-2007, 12:37 PM   #4120
Originally Posted by hierog
hey all:
thanks
vic
For the TRF shocks, I prefer to use the 5mm ball ends instead of the shock collar/screws that came in the "R" kit. You can get a bag of brass balls, or go with blue aluminum for extra bling (TAM53642).
As for the steering rub, I'm assuming you are rubbing the gear case. They included a set of spacers to push the servo farther forward if you use a servo that does not have enough height from the mounting ears. Take a look and see if that would help.
Old 06-01-2007, 12:49 PM   #4121
tony gray's Avatar
Don't worry about the shocks moving, it doesn't make any difference. We've run the car like that and it makes no difference at all. If it really freaks you too much, then put an o ring on there to take out the slop.
As for the steering linkage hitting, its because the TRF shocks you've put on are too long. They're not letting the car sit low enough and hence the steering links are hitting the chassis. It's a common problem with any M03 that's sitting too high. Centre to centre your shocks need to be around 47mm or so at ride height.
Old 06-01-2007, 04:22 PM   #4122
HotrodHopkins's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to HotrodHopkins
hey all:
thanks
vic
i just ground down a section of the gear case a little big, no big deal, doesn't hurt anything, just don't go too far.
-Shaun
SHAUN HOPKINS a.k.a NoRod Hopkins
-1990 Chevrolet K1500 Silverado TBI350 "Heavy Half". 1971 Chevrolet Nova
-My lug nuts require more Torque than your Honda makes.
HotrodHopkins is offline   Reply With Quote
Old 06-01-2007, 10:37 PM   #4123
Thanx for the info, will try. Are you using the 2 or 3 hole pistons in the shocks? I'm running spacers in the shocks already. Have you tried the sway bars???? This track wants us to run 5mm ride hts. Seems a little high to me, but hopefully won't be a problem. again thanx for the help
Old 06-01-2007, 11:27 PM   #4124
NT
NT's Avatar
Trader Rating: 21 (100%+)
3 holes for me.
5mm might be a touch high - if the mini starts traction rolling - drop it down a little a see if that helps it out
Some people swear by sway bars - i had them on my mini and didn't feel any difference in the car, so took them off again!
NT is offline   Reply With Quote
Old 06-01-2007, 11:40 PM   #4125
Originally Posted by NT
3 holes for me.
5mm is to keep you from ripping up the rug.
If you're running on rug the roll bars will help keep you from rolling over.
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 05:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-02-2011 12:08 AM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 09:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 07:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 08:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
