Like Tree81Likes
Old 06-17-2005, 06:15 AM   #391
Nova F1 Racer's Avatar
R/C Tech Charter Subscriber
Originally Posted by Jam-ehz
Any tips on getting the gears to be a little quieter? Mine sound like they're grinding a stone out, but they're all clean and lightly lubed with super-speed gear lube, and have smooth bearings on them.
I bought a new set with a new steel pinion to no avail, but I haven't replaced the diff gear yet.. could that be it? It's the TA03 ball diff... do they have replacements for just that gear?
Does the M04 Aluminum heatsink-mount actually do anything? It's only touching the motor with 2 screws...
On a side note, what colour should the Tamiya black-can Sport Tuned brushes be? I think I've overgeared it for a race and baked them with the TB-02 , and they're a dark purpley-grey. I forget what they were before, but i'm being outrun in every race (hey, could be the batts too, I guess). Is there any way to fix them, or is that it? How hot should it be after 5 mins?
Thanks!
Dark purple means brushes are toasted, after 5 minutes if you can't touch it then something is wrong. Could be over geared/ drivetrain binding/etc....
This is DICK!!! And you're NOT!
RC Tech member #11
Aussie Rules Footy, Brisbane LIONS!!
[url]http://www.pitter-pat.com/[/url] for pet care needs in Northern Virginia
Nova F1 Racer is offline   Reply With Quote
Old 06-17-2005, 10:45 AM   #392
RED-LINE M03's Avatar
Trader Rating: 127 (100%+)
Default INTEGY GEAR RATIO
WHAT WOULD THE GEAR RATIO BE ON A M03 IF I INSTALLED THE INTEGY GEARS??
RED-LINE M03 is offline   Reply With Quote
Old 06-17-2005, 11:22 AM   #393
well I just ordered the integy gear set. we will soon find out. they came to 36 bucks with shipping. I know it is steep but I had to try them. could not resist. Now I just need the new body set.
Hey is there a good place online to order the extension to turn my m-03 into a m-03L? I have a new cooper body that came with my purchace but I need the D parts tamiya part #0005798 but none of my LHS stock tamiya stuff. they can order it but I have forund it is usally cheaper and faster to just order what I want online.
gpwpat is offline   Reply With Quote
Old 06-17-2005, 01:02 PM   #394
Default BEARINGS ????
IS THERE ANY DIFFERENTS BETWEEN A $60 DOLLAR TAMIYA SEALED (BLUE) BEARING AND SAY A SET OF $100 ACER OR BOCA BEARINGS OTHER THAN THE PRICE?
ACERRACING.COM/BEARINGS.HTML
BOCABEARING.COM/
THANKS................
Old 06-17-2005, 05:54 PM   #395
BOCABEARING.COM/
Yes, $40 dollars that you can't spend on good batteries......
Quality..... The real question is putting $100 bearings on a $94 car?
RC Tech member #11
Old 06-19-2005, 11:02 AM   #396
Default ACER\BOCA BEARINGS
I WILL TAKE THAT AS A NO............
Old 06-19-2005, 11:06 AM   #397
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
The asnwer is yes there is a difference
The Ceramics are lighter, and they are free.
I would spin my rear tires on the M03L and the would spin free for almost 3 minutes. So there was virtually no drag. I would say the ceramics ar twice as free as a cleaned out Tamiya bearing
tamiyarcracer is offline   Reply With Quote
Old 06-19-2005, 03:55 PM   #398
Redline unless you are trying to win Nationals or a trip to Japan I would not bother. While Troy's car is real free 1 board and you give up that freeness in sitting there. But here is the positive if you nose in and stay on the throttle you can do a killer burnout
UF1 Seattle - SPEEDWERKES - VBC Racing - Team ORCA
Difuser is offline   Reply With Quote
Old 06-20-2005, 08:32 AM   #399
Hey I found a new Mini cooper S body. made to fit the m-03L chassis. by a company called Kamtec Based in the UK. I got the body off of Ebay for 17 pounds wich is just under 30 bucks with shipping. So this will be painted like my daily driver and my standard cooper body will get painted like one of the mini race cars.
here is the links www.kamtec.co.uk
Ebay item # 1652979
Old 06-20-2005, 08:34 AM   #400
oops I posted the wrong link
ebay item # 5982999487
Old 06-20-2005, 08:59 AM   #401
Kail's Avatar
anyone can advise me on the tyre combi used on an Mo3 on carpet tracks?
thanks
Kail is offline   Reply With Quote
Old 06-20-2005, 09:12 AM   #402
Yes they have some interesting body shells, shame they are in the UK. I'd like to see what will actually fit the m chassis cars.
I have a bolink classic beetle shell, I have to get painted one of these days to fit my m03
MartynD is offline   Reply With Quote
Old 06-20-2005, 10:00 AM   #403
rccardr's Avatar
Kail- Try M-Grips up front with a firm full-size sedan insert (like a Tamiya black) and S-Grips out back with a 60D foam insert. That should do the trick.
Later
Doc
I've never lost.
I've just been a little bit behind when time ran out...
RED DOT MOTORS- Fastest Titan 12T and silver can 540 motors in the known galaxy!
rccardr is offline   Reply With Quote
Old 06-20-2005, 10:42 AM   #404
Kail's Avatar
Thanks! But how do u stuff full size sedan inserts in? cutting them to correct size n regluing the inserts with ca?
Old 06-20-2005, 11:25 AM   #405
I have had good luck with inserts for the 1/18 off road trucks. plus they were 2 bucks for 4. I used the hard inserts. I have read they info about the full size stuffing but have not tried it. something along the line of tapeing the dia downand stuffing and restuffing until it all lines up then glueing. it talks about the stuffing the full sized inserts on the tamiya ste op page for the m-03L
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
