Like Tree137Likes
Old 05-06-2007, 02:16 AM   #3961
Lambatz's Avatar
Originally Posted by A-Ko
I am not up on that system. You can always verify with a voltmeter to see what where it cuts out on discharge.
Integy makes a stand alone discharger with fan reactor 20 or 30 amps. If you take it apart there is a adjustment dial where through trial and error you can get it down to .9v a cell. I actuall drilled a hole in the front for easy access...
That is a cheap ebay option if the Orion does not work out. You probably could email Team Orion or goto their website once they get it back online.
ok.. i'll try to contact team orion.
thank you very much...
Lambatz is offline   Reply With Quote
Old 05-06-2007, 01:33 PM   #3962
killingtime's Avatar
Hey guys, I need some help.
I'm looking for a good set-up for the M04 on asphalt (low-mid bite)
Any help is appreciated.
Mike Webb
rD Squared-MW Designs-C and R racing
Final Thoughts RC club R.I.P.
killingtime is offline   Reply With Quote
Old 05-06-2007, 03:54 PM   #3963
heres mine:
2 degree toe in rear uprights
super mini plastic shocks
2 hole 40 weight rear, short red springs, 2mm ride height spacer, no spacer inside.
1 hole 80 weight front, short blue springs, long spacer inside the shock (the one that comes with the shocks)
a type reinforced slicks front and rear.
hard foam inserts for the front, hpi hard molded foam in the rear (hard to find)
stock gear diff
21 tooth pinion
bearings of course
0 degree toe for the front
a standard slow servo
i also used the largest metal ring from the optional stiff servo. i just put it over the top of the standard servo saver. the rest of the optional servo saver is junk.
if the car is still tail happy put the stock rear tires on the front. i think they are m grip radials.
i think thats it.
frankrehnelt is offline   Reply With Quote
Old 05-06-2007, 04:35 PM   #3964
Thanks Frank
Have you tried the sway bars?
I had ALOT of body roll which caused either a traction roll or the rear slid out. I'll try out that set-up of yours to see if it'll help me in my problem.
Anyone else?????
Mike Webb
Old 05-06-2007, 07:23 PM   #3965
Thanks Frank
Anyone else?????
never tried the bars. they are a discontinued part and i don't think they would help.
sound like you need the m grip radial tires on the front and move the top of the rear shocks to the inner mount holes.
Old 05-06-2007, 08:31 PM   #3966
K_Spec_RC's Avatar
Send a message via MSN to K_Spec_RC
For those who have experiance on the RP30 tires, what were your impressions? I'm racing on a track with mid to low grip level.
Thanks,
Keith
HighVelocityRacing.com | TurtleTraxRaceway.com | itFitzDesign.wordpress.com | Misfitz Motorsports | Jconcepts | KO Propo | Tekin | Kyosho RB5 SP | Kyosho Ultima SC
K_Spec_RC is offline   Reply With Quote
Old 05-06-2007, 09:28 PM   #3967
Shocks are mounted on the inner-most setting already. But the use of the M Grip radials does sound promising
Mike Webb
Old 05-06-2007, 11:36 PM   #3968
Default Suzuki Swift/Ozite Carpet setups
I've just bought a new Suzuki Swift M03M and I'm looking for good starting setups to run on ozite carpet. I've heard alot of guys run at my track
S- fronts
M- backs
(im guessing these are radials, not slicks.....sorry, I'm too new to this)
Not sure what type of tire inserts, shock springs/oil weights, number of holes in pistons. I've upgraded to the super mini cva shock set.
Any and all info would be greatly appreciated guys! Thanks alot!!!
ymckman is offline   Reply With Quote
Old 05-07-2007, 04:06 AM   #3969
tony gray's Avatar
Default 2007 Victorian (Australia) State Titles Video Online
We've finished our edited package of the highlights of all 3 legs of the A Finals from last Sundays racing soon, but until then, check out this amazing footage of all of the Mini A finals at the awesome Wodonga track in Northern Victoria.
And big congrats to Ash Peeler for taking out the title too...Yet another title for rc-mini.net, and Ash's first.
Click here to see it on youtube.
tony gray is offline   Reply With Quote
Old 05-07-2007, 07:43 AM   #3970
madjack's Avatar
Trader Rating: 20 (100%+)
Send a message via Yahoo to madjack
Originally Posted by tony gray
We'll be doing a nice little edited package of the highlights of all 3 legs of the A Finals from last Sundays racing soon, but until then, check out this untouched footage of all of Leg 3 of the Mini A finals at the awesome Wodonga track in Northern Victoria.
Tony, great video link!
What rules does this series require? (motor, tire, body etc.)
madjack is offline   Reply With Quote
Old 05-07-2007, 02:44 PM   #3971
tony gray's Avatar
Essentially everything Tamiya...but you are allowed to use aftermarket (rubber) tires.
Bodies are Mini or Swift only, but can be from any manufacturer.
Motors are Sport Tuned. Even though they look a lot quicker!
Old 05-07-2007, 05:36 PM   #3972
sorry, was confused. the tires are S grip radials.
Old 05-07-2007, 05:38 PM   #3973
S- fronts
M- backs
i have the letters wrong
they are type A reinforced slicks. m04 will use them for rears
S grip radials are treaded tires. m04 can use them in the front to tame the turn in of the car.
m03 you might swap front to back.
Old 05-08-2007, 06:58 AM   #3974
Jam-ehz's Avatar
Send a message via ICQ to Jam-ehz
Living proof that the M-03L can still rock!
I've only raced the M-04 before, and knew traction was going to be bad, so I bought my friend's M-03L a week before last Sunday's TCS here in Toronto.. set it up, swapped the drivetrain for my ultra-free M-04, and let'er rip.. in a sea of Swifts (3 mains of minis), some being really fast, I held onto TQ first round but couldn't keep it up after whacking a few corners and traffic in my second Q... time ran late so we only could get 2 Q's in..
I Q'd 4th in the end, 1-2-3 were M-03M's, but I came back and won the A main after finding my ultimate setup.... had to use S-grips in the front, one Type-A in the rear left, and an S-grip in the rear right! it was incredibly loose traction, but the right turns skipped while the left turns slid, so that was my solution to the problem! Used fluorescent red springs with a sway bar to keep the rear planted..
Regular suspension, alu. front uprights, normally-built ball diff, BMW Cooper body all work just fine.. but I do have a LW Swift body in the package, ready for paint, and LW suspension to strip from my M-04, gonna give it a try too.. but for those without an M-03M, don't give up! I've found that my saving grace was the square sides of the 03L body.. it let me get off from my side faster than the marshalls could get to it.. the others seem to have a tapered top and those wheel wells, keeping the wheels from touching the ground as well as the L does..
Oh, the car that came up just short of beating me (14yr. old started 5th, got ahead of the pileup while I was punted to the back, I kept on reeling him in, getting whacked by traffic, twice before he whacked a dot in the last 15 secs, letting me squeeze by) was a shortbase M-03! Those track dots are just evil, especially for minis!
The track was so loose, the top 19T GT1 racer did 21 laps (I managed 20), while the top minis were pulling 19-20 lap paces.. Slow is fast!
-=≡ Tamiya TA05 TRF415MSX F103R M-03R M-04 M-05 ≡=-
-=≡ CRC Carpet Knife 3.2 OFNA LD3 Pro Fastcats Spektrum ׀ווlı ≡=-
Jam-ehz is offline   Reply With Quote
Old 05-08-2007, 07:02 AM   #3975
madjack's Avatar
Thanks Tony.
"Sport Tuned" as in the Tamiya closed end-bell black can motor we use here in the states at the TCS Nats? (and yes they do looks very quick!)
also what is the tire/insert of choice?
Thanks in advance,
John
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
