Like Tree136Likes
Old 04-26-2007, 08:45 AM   #3886
muahdib4's Avatar
Send a message via Yahoo to muahdib4
Originally Posted by nikkiesteban
i ordered super mini cva shocks for m03m and i ordered set of spring here's is the part number for spring set #53333. do you think it will fit when i lower down the ride height? coz i think the springs i ordered is not the shortest springs for m03. here take a look at this spring #53749 this is much shorter i think.
Those will work and are the short springs. The only problem I've found with those is that they are REAL soft. The springs I would recommend are part #'s:
53630, 53631, 53632 and 53633. They are only sold in sets of 2 and are shorter and stiffer then the ones in set #53333.
KCRC - Kansas City Remote Crawlers
Team Chucklenuts Racing
Midwest R/C Rally Confederation
KC/RC Drift Movement
muahdib4 is offline   Reply With Quote
Old 04-26-2007, 10:23 AM   #3887
sportpak's Avatar
Trader Rating: 26 (100%+)
Hey dudes, I'm running a Futaba servo. The stock servo saver and turn buckles are in place also. I've found a ton of slop on the links at the servo. The shoulder screws allow a bunch of movement. I've wrapped a small rubber band from one side, around the back of the saver, to around the other to help keep the links from slopping around so bad. Helps it track straighter. What servo savers and link ends are some of you running. I'm gonna do some real links to make adjustment easier and want to change the saver and link ends too while I'm at it.
-Tamiya TA05-R - Tamiya M05 - Summit Raceway Ft. Wayne, IN
www.summitrcraceway.com
sportpak is offline   Reply With Quote
Old 04-26-2007, 10:35 AM   #3888
muahdib4's Avatar
I use the 5mm low friction adjustors for my ends (part #53601) and the titanium turnbuckles 3x32mm (part #53527). As for the servo saver...I just lock it down real tight and I don't get much slop.
Old 04-26-2007, 11:20 AM   #3889
sportpak's Avatar
Thanks man. I'll look into that stuff. I really dislike the stock servo saver. I'll have to play around with it a little more.
Old 04-26-2007, 04:17 PM   #3890
nikkiesteban's Avatar
Send a message via Yahoo to nikkiesteban
thanks but do you think the 53333 will work if i will lower down my ride height to the fullest with bottoming the chassis?
nikkiesteban is offline   Reply With Quote
Old 04-26-2007, 07:54 PM   #3891
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
YES! they are the shortest springs tamiya has.
tamiyarcracer is offline   Reply With Quote
Old 04-26-2007, 09:24 PM   #3892
Regional Moderator
BHenderson's Avatar
Send a message via AIM to BHenderson Send a message via MSN to BHenderson Send a message via Yahoo to BHenderson
I know this is last minute but just found out today that currently we have 56 entries in Mini for our TCS race in Memphis TN. If you are not doing something this weekend and are close enough to drive, bring it.
BHenderson is offline   Reply With Quote
Old 04-26-2007, 09:27 PM   #3893
Scottrik's Avatar
Trader Rating: 243 (100%+)
Wow!! That's a LOT of support. Congrats, you guys must put on a great show to attract that many racers for one class. Please be sure to let us know how it goes.
Scottrik
Congressmen should wear uniforms like NASCAR drivers so we can identify their corporate sponsors.
THE REVOLUTION WILL NOT BE TELEVISED -Gil Scott-Heron (1949-2011)
Scottrik is offline   Reply With Quote
Old 04-26-2007, 09:32 PM   #3894
Regional Moderator
BHenderson's Avatar
Scottrik
I like to think we put on a good show, this year we are cooking up some Memphis style BBQ for everyone at the race, last year was free hamburgers, chips and drinks for everyone. Here's the link to the discussion about the TCS race in our forum:
TCS RACE DATE---April 29th 2007
Old 04-27-2007, 08:01 AM   #3895
sportpak's Avatar
Wish I could make it. Next year I plan on making it. A friend and I almost have a Mini program started here at home. I'll have a year of RD and maybe can bring some friends next year.
Ben
Old 04-27-2007, 08:23 AM   #3896
if the car keeps on rolling/flipping what could be the cause? if i immediately turn into corners sometimes the car will flip/roll and the marshal will get the car . any solutions?
what should i do to my setup? do stabilizers really work? should i put some? where front or rear?
Old 04-27-2007, 08:40 AM   #3897
Patriiick's Avatar
Most likely too much body roll.
Assuming you have the right tires, put harder springs all around, thicker oil and add a roll bar on front to start with.. that should really help
Patriiick is offline   Reply With Quote
Old 04-27-2007, 08:43 AM   #3898
Rysuleod's Avatar
The springs muahdib4 told you are the shortest springs. They will allow you to get the super low ride height. The 53333 set will NOT allow you to have the super low ride height.
53333 set 23mm
53630, 53631, 53632 and 53633 are 20.6mm
I run the 20.6mm springs with no ride height spacers on carpet and that gets me down to about 4mm ride height in front and a little more in back.
Rysuleod is offline   Reply With Quote
Old 04-27-2007, 10:08 AM   #3899
minimanintaiwan's Avatar
You maybe traction rolling. Tires too grippy. Use less grippy tires. Make sure inserts are firm and full. Loose inserts will cause tires to fold over and traction roll. Make sure tires are glued very very well. This also stops the folding over. Lower your CG. All wiring/electronics in the chassis. Widen your wheelbase using wheel spacers. Use the TRF springs 53630-633 as mentioned to lower chassis.
minimanintaiwan is offline   Reply With Quote
Old 04-27-2007, 10:15 AM   #3900
Core Creations's Avatar
Trader Rating: 94 (100%+)
Send a message via AIM to Core Creations
Don't underestimate driving style...you need to enter corners differently with a FWD. Smooth is the name of the game, maximizing your corner speed.
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
