Like Tree115Likes
Old 04-11-2007, 02:37 AM   #3811
Patriiick's Avatar
Tech racing is not tamiya original parts so on theory you re not legal.(although that can be debated at great length).
However, you could maybe see if there is an identical part in the tamiya catalog that is the same (which might be possible since Tech racing makes somes aluminium parts for Tamiya)... and turbuckles might be just a good case of that...
Patriiick is offline   Reply With Quote
Old 04-11-2007, 07:25 AM   #3812
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
in my experience with the TCS stuff, most race directors and Tech inspectors may not worry about some of the small stuff, as long as Tamiya makes a similar product, or it doesnt really enhance performance. i have seen Lunsford turnbuckles, RPM ballcups, etc...
but keep in mind, it is all up to the Host Club and Tech guy what they let pass... best to be 100% to be sure...
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 04-11-2007, 07:44 AM   #3813
nagatahawk's Avatar
some of the small stuff can be overlooked at the TCS qualifiers, and as far as I know if you are so lucky/good enough to make it to the Japan finals, everything will have to be tamiya.
nagatahawk is offline   Reply With Quote
Old 04-11-2007, 09:02 AM   #3814
westerdude42's Avatar
I had to change links at my first TCS regional. It was no big deal but I recomend showing up with the stock ones pre-built just in case. Then it's a quick switch if you have to.
Hedgehogs rule!!!
westerdude42 is offline   Reply With Quote
Old 04-12-2007, 02:19 AM   #3815
tony gray's Avatar
Now on rc-mini TWO super-rare little Minis from ABC Hobby.
The 4WD Carrera IV and a cute little 1/20th one as well
Click here to check em out
tony gray is offline   Reply With Quote
Old 04-12-2007, 05:19 AM   #3816
Scottrik's Avatar
Trader Rating: 243 (100%+)
Tony,
On the RWD mini conversion you install "long" shocks. What should I be looking for?
Many thanks,
Scottrik
Congressmen should wear uniforms like NASCAR drivers so we can identify their corporate sponsors.
THE REVOLUTION WILL NOT BE TELEVISED -Gil Scott-Heron (1949-2011)
Scottrik is offline   Reply With Quote
Old 04-12-2007, 06:05 AM   #3817
nikkiesteban's Avatar
Send a message via Yahoo to nikkiesteban
why is my m03m swift keeps on going to left sometimes right? for example when i let go off of the throttle it will steer into left sometimes right? why is that?
nikkiesteban is offline   Reply With Quote
Old 04-12-2007, 07:20 AM   #3818
Steven Key's Avatar
I had a similar situation with turnbuckles at the National. I had raced at three Regional events with no problems but at the Nationals they made me replace my Lungsford turnbuckles with Tamiya ones before they would let me run. Forunately, my son was running the exact same car so I popped his on and was still able to make my qualifier.
Better safe than sorry.
Steven Key is offline   Reply With Quote
Old 04-12-2007, 08:43 AM   #3819
Turbonium's Avatar
yea, i would figure the Nats would be a little more strict. with all thats at stake, it would figure!
i am thinking of going again this year...
Wes
Wes
Team Novak
Old 04-12-2007, 08:51 AM   #3820
Scottrik's Avatar
What's sad is that the regional events aren't every bit AS strict. The rules are clear enough...everyone should be forced to comply with them. Kinda sucks that the message here is "cheat to get into the 'show', then be ready to revert to compliance".
Old 04-12-2007, 11:27 AM   #3821
Turbonium's Avatar
i agree... sorta. the thing is, if i dont have a local hobby shop stocking Tamiya parts, and i need something like a turnbuckle, ill use whatever i can get. the comments at the regionals i have overheard is "... as long as it isnt a performance enhancing part..." for what thats worth.
my Tamiya cars are all kept 100% TCS Nats legal, for what thats worth....
Wes
Team Novak
Old 04-12-2007, 12:04 PM   #3822
Steven Key's Avatar
Have any of you Mini drivers tried putting the M03m new front and rear suspension on an M04m.
I heard (unconfirmed) the M04m that won the nationals last year had made this switch.
What would be the advantages or disadvantages?
Old 04-12-2007, 01:09 PM   #3823
Manny's Avatar
I don't see why the M03m parts wouldn't fit. Compared to the stock set up, you would have less unsprung weight because of the smaller bearings and kingpin screws. The rear toe-in on the M03m upright gives the car more stability.
Manny is offline   Reply With Quote
Old 04-12-2007, 04:55 PM   #3824
rccardr's Avatar
My guess is...minimal performance difference. Rear toe on the M03M is 2 degrees, same as the option parts for the M03/L. Smaller bearings will be virtually no weight difference and the kingpins are about the same on my scale. But the 03M plastic front knuckles are stronger than the M03 parts and lighter than the aluminum option parts. It all fits (you've got to use the later uprights with the new knuckles but they come on the same tree) but probably not worth buying all of it expecting to see a performance gain.
The M03R parts are another issue altogether, Steve. Three mounting holes for the ball end (two give you Ackerman changes), you don't have to use that special tall ball end, and the rear uprights not only have two locations for the outer link (think roll center, baby) but they have 1.5 degree toe-in. Sweet.
I've never lost.
I've just been a little bit behind when time ran out...
RED DOT MOTORS- Fastest Titan 12T and silver can 540 motors in the known galaxy!
rccardr is offline   Reply With Quote
Old 04-12-2007, 05:29 PM   #3825
Jam-ehz's Avatar
Send a message via ICQ to Jam-ehz
I've had the M suspension on the 04, and it's been great for me.. I had the aluminum knuckles before, but I've never had to replace an upright in many a dozen races.
It's been successful on carpet in major races, I'm one of maybe 2 or 3 04's in a field of 03's in Toronto.. it managed 1st of 20, 2nd of 25, made the A out of 40 mini TCS entries. It's done well, and has taken its hits and rolls with no problems.. I think I'll end up keeping the plastic parts, no aluminum really needed.. how much more performance can you really get out of a Mini?
-=≡ Tamiya TA05 TRF415MSX F103R M-03R M-04 M-05 ≡=-
-=≡ CRC Carpet Knife 3.2 OFNA LD3 Pro Fastcats Spektrum ׀ווlı ≡=-
Jam-ehz is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 9 (3 members and 6 guests)
JUNI
