Like Tree200Likes
Old 04-04-2007, 05:09 PM   #3766
Tim K's Avatar
Cool!
Bet you can't wait to build it ... I'll be interested to hear your thoughts on the M03R, build quality, likes/dislikes, etc ... keep us posted!
Looks like you have the limited edition white handled box! or I have the limited black handle edition
Tim K is offline   Reply With Quote
Old 04-04-2007, 07:27 PM   #3767
muahdib4's Avatar
Send a message via Yahoo to muahdib4
Originally Posted by Tim K
Cool!
Now I just have to decide if I want to build it with the kit screws..the stainless hex screws I have, the blue aluminum screws or the titanium...hmmm. Problem is...I still need to finish the build of my M03M that's still only 70% complete. Well...I'm off work Friday so maybe I'll get them both done then...
KCRC - Kansas City Remote Crawlers
Team Chucklenuts Racing
Midwest R/C Rally Confederation
KC/RC Drift Movement
muahdib4 is offline   Reply With Quote
Old 04-04-2007, 09:34 PM   #3768
sim600's Avatar
Trader Rating: 15 (100%+)
Send a message via ICQ to sim600
Or you can just build the M-03M with the R version rear hubs, turnbuckles, steering uprights and heatsink.
ModRC.com
sim600 is offline   Reply With Quote
Old 04-04-2007, 11:55 PM   #3769
muahdib4's Avatar
True enough...but I need a shelf queen...here's pics...no electronics yet...details tomorrow.
Tamiya mini cooper-m03r-006.jpg   Tamiya mini cooper-m03r-010.jpg   Tamiya mini cooper-m03r-009.jpg
Old 04-05-2007, 12:12 AM   #3770
Scottrik's Avatar
Trader Rating: 245 (100%+)
Nah--that's the beauty of shelf-queens, they don't need expensive electronics.
Those 'R' kits look plenty bling, but I'm thinking I'll pass. For the same money I'll get a car that has more "go fast" than "looks trick". And has a body, etc...
Nice looking piece though.
Scottrik
Congressmen should wear uniforms like NASCAR drivers so we can identify their corporate sponsors.
THE REVOLUTION WILL NOT BE TELEVISED -Gil Scott-Heron (1949-2011)
Scottrik is offline   Reply With Quote
Old 04-05-2007, 07:49 AM   #3771
muahdib4's Avatar
Alrighty, my review of the M03R so far...
About the smoked-chrome...messy. Like someone else has already said, little chrome flakes will be everywhere.
Shocks, wow. I had never used the Super Mini CVA shocks so I didn't know what to expect. I've always used the TRF shocks. Though the material is way to brittle to take more then a few good hits on the boards, they look great and feel good too. The action is nice, easy to bleed with no leaks and they went together quick and easy. If I didn't love my TRF shocks, these shocks would have me using the Super Mini CVA's as an alternative on a budget. They just look trick...they even have internal spacers and pistons that are clear blue..really great looking.
New Blue Hub Carriers...I LOVE THESE. They look nice and once I get a set of them for my other 2 Mini's I'll actually try them out and see how the 1.5 degree rear hubs work.
The rear camber adjustment...I like it but wish it was on the front too. It's not that I really would want more ways to adjust the car because part of the fun in Mini is not having to adjust everything...but it allow for just popping the end off a ball-stud rather then using a screw driver or hex-wrench. It would make it much quicker to change front end parts or get to the axles and driveshafts.
Fit and Finish: Everything went together fine. Just like every Mini...quick and easy. It looks GREAT.
Complaints: No Universals, and that's really about it. I like the gear diffs so I don't need a ball diff, there isn't that much difference anyway. All it needs are Universals and I'd LOVE this car..right now, I only love this car. Also a more durable finish and shocks ends that aren't so brittle.
Now for the big question...would I recommend it??? The honest answer to that is...it would depend. If you want maximum bling right out of the box...then yes. If you want something durable that you can race every weekend...then no. The M03M with a few select hop-ups would be the better choice. Don't get me wrong, I love this for the 'bling' but it really isn't a true racer. It's far to pretty with brittle shock-ends and the smoked-chrome finish that would flake off every time you smack a board. It is the best looking car I own though and I'll play with it a little on the carpet...but it'll never see asphalt.
Old 04-05-2007, 06:21 PM   #3772
Default fiat abarth wheels
Anyone out there with a source or set of the old campagnola wheels from the tamiya kit? Building a high detail abarthTC1000 and wheels do matter !
thanks
catcars is offline   Reply With Quote
Old 04-07-2007, 10:35 PM   #3773
K_Spec_RC's Avatar
Send a message via MSN to K_Spec_RC
I'm pretty new to Mini and setups all together... So I have a question or two to ask. I'm getting a lot of wheel hop in the rear of my Mini... Any idea what I can do fix it? Also, would a fiberglass roll over antenna be worth looking into? I know they work well for a 1/12th scale car.
thanks,
Keith
HighVelocityRacing.com | TurtleTraxRaceway.com | itFitzDesign.wordpress.com | Misfitz Motorsports | Jconcepts | KO Propo | Tekin | Kyosho RB5 SP | Kyosho Ultima SC
K_Spec_RC is offline   Reply With Quote
Old 04-07-2007, 10:44 PM   #3774
tony gray's Avatar
Lower ride height is your first port of call, 3-4mm is good.
A large part of it is from tyres, more grip brings more hop. Less grip and you'll get slide, too much grip - traction roll! You need to find that balance between excessive slide and hop.
Dumping the car right down is your first move and then start to play with the tyres.
If you're running an internal spacer inside the shock, taking that out (what we call super-droop) may stop the hopping but you HAVE to run the short spring set for this to work.
I think you'll find most tracks dont allow roll-over antennas any more... They certainly dont here where we run. Not necessary on a Mini anyway.
tony gray is offline   Reply With Quote
Old 04-08-2007, 12:28 AM   #3775
BoneCrusher's Avatar
Default Newbie needs help
Hi All,
Read countless pages in this post, learned a lot, but still gonna ask a very long question.
I want a MINI! I was planning to buy the M03R but after doing some research, I realize that the M03M may be the better choice for me because:
1. The M03R is more for looks and the M03M is built to run
2. The M03M comes with ESC and a Swift Body and is a better value
3. I’m a beginner and I’m bound to crash A LOT and wreck that beautiful faux chrome
Okay, I’m looking to order everything (hop-ups/spare parts/bling) I need from either Rainbow10 or RC-Champ, please tell me if I
a. NEED IT
b. WOULD BE GOOD TO HAVE IT
c. BUY IT IF I GOT EXTRA CASH
d. WASTE OF MONEY
· 58368 M-03M SUZUKI SWIFT SUPER 1600 x1
· 50793 M03 C Parts (Sus. Arm) (C1-c22) x1
-just incase I break them
· 53341 Black Wheels (2 pcs) x8
· 50683 M-Chassis 60D Radial Tires (2 pcs) x2
· 50684 M-Chassis 60D M-Grip Radial Tires (2 pcs) x2
· 53254 M-Chassis 60D Super Grip Radial Tires (2 pcs) x2
· 53340 M-Chassis 60D Reinforced Tires Type-A (2 pcs) x2
-full range of tires for all road conditions
· 53255 M-Chassis 60D Inner Sponge, Hard (4 pcs) x1
· 50686 M-Chassis 60D Inner Sponge Set (4 pcs) x3
- okay, I don’t know the difference and I want to make 4 set of tires
· 50354 16T, 17T AV Pinion Gear Set x1
· 50355 18T, 19T AV Pinion Gear Set
· 50746 CVA Super Mini Shock Unit Set (2 pcs) OR 53155 Low Friction Aluminum Damper Set (2 pcs) x2
- I think the aluminum ones are stronger and look better
· 53008 1150 Sealed Ball Bearing Set (4 pcs) x1
· 53030 850 Sealed Ball Bearing Set (4 pcs) x1
· 53015 3x8mm Titanium Tapping Screw (10 pcs) x1
· 53017 3x15mm Titanium Tapping Screw (10 pcs) x1
· 53095 3x10mm Titanium Tapping Screw (10 pcs) x1
- do these make the car stronger? Or lighter?
· 53056 Pin Type Wheel Adapter x1
· 53132 R/C Fluorescent Color Antenna Pipes (4 pcs) x1
· 53163 On-Road Tuned Spring Set OR 53333 Touring Car Tuned Spring (short) x1
· 53205 M-Chassis Universal Shaft Set [CAN NOT FIND FROM RAINBOW10] x1
· 53267 TA03 Ball Differential [CAN NOT FIND FROM RAINBOW10] x1
· 53218 1/10 Touring Car Hard Joint Cup Set (for Gear Diff.) x1
- do I need one for a Ball Diff?
· 53301 TL01 Stainless Steel Suspension Shaft Set x1
· 53339 CA Cement (for rubber tires) x1
· 53346 Quick Release Battery Holder x1
- I think I read that I shouldn’t get this
· 53390 Hollow Carbon Gear Shaft x1
· 53417 Rubber Tire Application Primer x1
· 53439 Anti-Wear Grease x1
· 53448 4mm Hard Lock-Nut & Spacer Set x1
· 53596 TA04 Aluminum Servo Stay Short x1
· 53344 M03 Aluminum Heat Sink x1
All this at Rainbow 10 is a little over $400 Canadian (around $350 US), I think shipping should be around $50 and then there’s the STUPID Canadian duty tax I’m guessing will be gouging me about another $50…and I haven’t gotten a quite from RC-Champ yet. I think all this is still way cheaper than getting this at the local hobby store.
Can’t find on Rainbow 10 but how about these parts:
· 53379 Light weight differential balls
· 53343 Sway bars
- OIL weights for front and rear shocks?
· Any Aluminum parts: Front and Rear C Hubs, Knuckles, or Arms??? and if so, any generic parts recommendations? Are the Standard ones fairly strong enough for a lot of crashes and pretty cheap to replace?
· Which servo should I get?…how much approx?
· What Batteries…How much?
· Bumper plate/foam…part number please?
· Aluminum 4mm Ball connectors….part number and for looks only?
· HPI Honda Civic Body #7024…..I love this body!!!!!!!!!!!!!!!!!!!!
Oh and motors...I got 27T and 19T...can I run these in my Mini?
I don’t mind buying the M03R…If someone recommends me do so, what parts do I NOT need?
I just want to race for fun. On road in the summer (when the snow melts here in Canada hopefully soon!!!) and on carpet indoor in the Winter. I’m bound to break things…I did a lot of that on my X-Ray T2R, but at least had lots of fun doing it!
I got the radio and receiver…Am I missing anything? I appreciate everyone's advice in advance!
Ivan
ARC R10, 12R5.1, Tamiya Mini, MTS FFv2 Pro, Exotek F1
carcar.ca
BoneCrusher is offline   Reply With Quote
Old 04-08-2007, 01:07 AM   #3776
K_Spec_RC's Avatar
even though I am quite new to Mini's, I have done alot of research on them. I can tell you now that you probably will not neeed half the stuff listed there. You can only use Tamiya pinions with the minis. You can only use the Tamiya motors (should come with the kit) 53390 Hollow Carbon Gear Shaft x1 (from RC mini) "you dont need them" I have read that you can just run the gear diff and be just as competitive as with the ball dif. I'm not sure about your black wheels, but again, you can only use Tamiya wheels. There are a few choices there (Rover, BMW Cooper, and the stock swift ones) I dont know about the Titainium screws, but I imagine they would not make a big diference. These are just my thoughts. but I could be wrong... Anyone wanna back me up?
Old 04-08-2007, 01:17 AM   #3777
muahdib4's Avatar
Originally Posted by BoneCrusher
Hi All,
a. NEED IT
d. WASTE OF MONEY
· 53343 Sway bars
Ivan
The only things I would say you "NEED" is nothing...the Mini's will run good right out of the box. Things you will "WANT" are going to be: Oil-Filled Shocks (CVA Super Mini's or TRF Special Dampers if you want bling), Universal shaft set, Short tuned springs (the ones you buy in sets of two only), an assortment of tires (skip the standard radials), and "MAYBE" the swaybars. Beyond that...the rest isn't that useful. They can all be stuff to play with later but stick with the essentials. You won't be running 27T or 19T with the Mini...they're both really to much motor and aren't allowed in most Mini classes. You'll be using either your stock Silvercan that comes with the kit or maybe the Sport-Tuned motors. You really need to just check out Tony's site.... www.rc-mini.net .... that will answer a lot of your questions, if not all of them.
Old 04-08-2007, 01:38 AM   #3778
NT
NT's Avatar
Trader Rating: 21 (100%+)
Have a good read over RC MINI and then you'll realise that other than buying the mini kit, some different tyres (60D's would be my suggestion) maybe a ball diff (but not really needed) and a 2 pair of Mini CVA Oil Shocks - i wouldn't worry about all the other stuff!
Definately read the website though - from top to bottom - and see how you go after that There are huge amounts of hop-ups available, but honestly, not many of them have much of an impact on the general handling of the car!
NT is offline   Reply With Quote
Old 04-08-2007, 01:43 AM   #3779
808TXT1's Avatar
The mini's are making a comback...
Where online can I get another body other than the MINI COOPER for the M03 chassis???
thanks
808TXT1 is offline   Reply With Quote
Old 04-08-2007, 05:34 AM   #3780
tony gray's Avatar
SWB, MWB or LWB?
Check our site for a list of what fits what...
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 05:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-02-2011 12:08 AM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 09:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 07:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 08:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
