Like Tree173Likes
Old 03-28-2007, 08:15 AM   #3691
Jam-ehz's Avatar
Send a message via ICQ to Jam-ehz
Those dampers should all have the same tube size and volume (including the TRF's), so just use the same stuff as the plastic ones.
-=≡ Tamiya TA05 TRF415MSX F103R M-03R M-04 M-05 ≡=-
-=≡ CRC Carpet Knife 3.2 OFNA LD3 Pro Fastcats Spektrum ׀ווlı ≡=-
Jam-ehz is offline   Reply With Quote
Old 03-29-2007, 04:51 AM   #3692
Trader Rating: 26 (100%+)
Send a message via AIM to cheesecake
so wich one is a better chasis to drive the fwd or the rear im not sure wich one i want
cheesecake is offline   Reply With Quote
Old 03-29-2007, 05:10 AM   #3693
muahdib4's Avatar
Send a message via Yahoo to muahdib4
FWD is easier to drive but according to TCS rules, the RWD chassis are allowed to use a 21T Pinion so they're a little faster but are a handful to drive. My recommendation would be a FWD. Champ got in pre-orders of the M03R today...YAAAAHHHHH.
KCRC - Kansas City Remote Crawlers
Team Chucklenuts Racing
Midwest R/C Rally Confederation
KC/RC Drift Movement
muahdib4 is offline   Reply With Quote
Old 03-29-2007, 05:57 AM   #3694
Send a message via AIM to minijosh Send a message via Yahoo to minijosh
I've never raced mine but it makes sense that a front wheel drive car will handle better because of the weight and power in the front pulling the car the corners instead of the rear wheel drive pushing the car. Pushing would be fun for drifting. As long as you can take the turns quickly and don't lose any speed you should be able to take the rear wheel drive cars with ease. They'd have to slow down to make the turn and you shouldn't have to.
http://rccarparts.biz/
Joshua T
minijosh is offline   Reply With Quote
Old 03-29-2007, 07:40 AM   #3695
nagatahawk's Avatar
I choose the mo4 rear drive because the whole field will be mo3s, I want to be different and I like the challenge. I will try to make the car push, I hope, so I can drive harder into the turns. I hope I don't get spun.
nagatahawk is offline   Reply With Quote
Old 03-29-2007, 11:49 AM   #3696
Jam-ehz's Avatar
Throttle control is key for the M-04.. if you're on low-traction parking lot or just bashing anywhere for the fun of it, go with the M-03, as it can be driven anywhere without worrying about traction.
If you're indoors or have a clean grippy track or surface outdoors, the M-04 rocks.. it doesn't flip like the M-03 can and handles like a touring car since the CoG is much lower.
The M-03 gives assurance that you won't spin out when accelerating, which can be important when nerves can get the best of you
My M-04 is a carpet monster, and with care can do well outdoors, but I'm getting an M-03 for this outdoor TCS season, as our surfaces are less than optimal for RWD..
Old 03-29-2007, 01:24 PM   #3697
Tim K's Avatar
Found this on my surfing rounds, box art for the M03R
Tim K is offline   Reply With Quote
Old 03-29-2007, 03:11 PM   #3698
muahdib4's Avatar
Cool, Champ has the pre-orders in...and it's on it's way.
Old 03-29-2007, 10:32 PM   #3699
Just checked out a new carpet track in my area. Does anyone have a baseline carpet set-up they would be willing to share? Most likely will be running Tamiya tires and the mighty Mabuchi....
I'm an experienced racer, but totally new to carpet. Any help or generalities are appreciated!
Graphitedust is offline   Reply With Quote
Old 03-29-2007, 10:42 PM   #3700
K_Spec_RC's Avatar
Send a message via MSN to K_Spec_RC
Tower says theyre getting the MO3R in Late March... and its Definatly late march... how much longer?
HighVelocityRacing.com | TurtleTraxRaceway.com | itFitzDesign.wordpress.com | Misfitz Motorsports | Jconcepts | KO Propo | Tekin | Kyosho RB5 SP | Kyosho Ultima SC
K_Spec_RC is offline   Reply With Quote
Old 03-30-2007, 12:07 AM   #3701
tony gray's Avatar
Depending on how keen you are to save weight..
This is the part number for the Swift Lightweight Body Set.
TAMIYA, 49420 - SUZUKI SWIFT SUPER 1600 LIGHT WEIGHT BODY
tony gray is offline   Reply With Quote
Old 03-30-2007, 01:48 AM   #3702
minimanintaiwan's Avatar
Ours have arrived! Picking it up today. they came straight from a dealer in Japan and therefore bypassed local Tamiya head office (they dont even have it yet!).. I love Taiwan!
minimanintaiwan is offline   Reply With Quote
Old 03-30-2007, 05:14 AM   #3703
muahdib4's Avatar
Yep, and mine shipped from Japan yesterday...THANK YOU RC-CHAMP!!!! Masa and the boys really take care of people.
Old 03-30-2007, 05:31 AM   #3704
muahdib4's Avatar
A lot will depend on the grip on carpet and different things work for different people. On my SWB M03 I run...
TRF Shocks (optional) Super CVA Mini Shocks work great too
Ride height: 3.5mm front and rear
Shock Oil: 35 weight front and rear
Springs Front: White Tamiya Short Tuned (not from set)
Springs Rear: Red Tamiya Short Tuned (not from set)
Tires Front: S-Grip
Tires Rear: M-Grip
Stabilizer Front: Silver
Stabilizer Rear: NONE
Differential: Gear Diff works great on Carpet. Shim it with 4xMA9, that's the large washer in the kit...put 2 on EACH side of the diff and tighten it down. There should still be a little diff action but it will be really tight allowing for better acceleration out of corners. Run the Diff dry with MAYBE a quick squirt of silicon oil but just a little.
With Tires, experiment there. My setup is working for me but another guy at the track runs M-Grips up front and Type A slicks in the back and that works well for him. Some of that will depend on your driving style. Same with springs. Some use the Blue Tamiya Short Tuned (not from set) in the front instead of the harder white.
Old 03-30-2007, 07:24 AM   #3705
minidriver's Avatar
They just changed it to Mid April - dang!
minidriver is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
