Like Tree100Likes
Old 03-06-2007, 01:38 AM   #3481
westerdude42's Avatar
Originally Posted by tony gray
I'm intrigued myself.... I cant see how it would work at all!
The only similarities I think are the suspension bits?
If its easy then I spent 3 hours chopping up a FWD for nothing!
It's just a chassis switch. It took 2 Tamiya parts trees to do it. Oh and you have to switch to a 20 tooth pinion. The car is running the TCS regional here in 2 weeks and it's been very quick.
Hedgehogs rule!!!
westerdude42 is offline   Reply With Quote
Old 03-06-2007, 05:28 AM   #3482
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
Originally Posted by nikkiesteban
can i convert my m03 into m04?
50849 Gear case
50850 Body posts
50851 chassis
6275048 bumper foam
you should have everything else.
tamiyarcracer is offline   Reply With Quote
Old 03-06-2007, 09:29 AM   #3483
Originally Posted by tamiyarcracer
50849 Gear case
50850 Body posts
50851 chassis
6275048 bumper foam
Thanx Troy.
Hedgehogs rule!!!
Old 03-06-2007, 11:21 AM   #3484
Customworksking's Avatar
Trader Rating: 73 (100%+)
you can go to the old suspension.
http://www.tamiyausa.com/product/ite...oduct-id=50736
you will need 4 11mm x 5mm bearings as well
cool I have my old m03L with zero hubs I will try em
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 03-06-2007, 03:05 PM   #3485
nikkiesteban's Avatar
Send a message via Yahoo to nikkiesteban
50849 Gear case
50850 Body posts
50851 chassis
6275048 bumper foam
thanks you very much tamiyarcracer.
how about the bearing in my m03m. will it fit in m04 chassis? and do i have to buy extra bearings?
nikkiesteban is offline   Reply With Quote
Old 03-06-2007, 03:29 PM   #3486
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
that brings to mention.... will the 03M-version suspension be TCS legal on a M04? not that i run the rwd car much at all, just curious in case it comes up.
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 03-06-2007, 10:39 PM   #3487
chicmagnet's Avatar
Does anyone here knows the part number of the m03 spool diff??? tnx!!
STRAIGHT LTD.
chicmagnet is offline   Reply With Quote
Old 03-06-2007, 10:46 PM   #3488
tony gray's Avatar
Ummm, there's no such thing....
Gear diff, or ball diff. That's your choice with a Mini! Unless you build your own one.
tony gray is offline   Reply With Quote
Old 03-07-2007, 01:43 AM   #3489
what will be the effect if i will lock my differentials?
Old 03-07-2007, 01:49 AM   #3490
akuhon's Avatar
Actually, there's ... but unfortunately it's not an option part for M03 or any other chassis...
It's a spare part include in a kit ... just find the TAMIYA VW TOUAREG ...It's an off-road type vehicle and it includes the spool diff kind of.
But if you're unsure, just d/l the manual from tamiya web site and see.
I don't know if you can order it, just ask Masakiyo from RC CHamp, probably he can help you ...
akuhon is offline   Reply With Quote
Old 03-07-2007, 01:49 AM   #3491
Tim K's Avatar
Your top speed will be the same, but your acceleration out of slow corners should be faster ... and your left hand front wheel nut will be more prone to coming loose, so check it after every run ... this can also happen for nearly locked diffs as well.
Tim K is offline   Reply With Quote
Old 03-07-2007, 01:54 AM   #3492
Tim K's Avatar
akuhon - you speak of the mythological plate that wedges in between the planetary(?) gears on the gear diff (I think) ... I have seen the drawing but not the part - do you have one?
Old 03-07-2007, 02:00 AM   #3493
akuhon's Avatar
No, I don;t have ..... just take a look at the manual of the VW Touareg on Tamiya web site ....
Old 03-07-2007, 02:07 AM   #3494
akuhon's Avatar
This is what I'm talking
See the G5 part ... that's all we need to lock the diff .... (make it as spool, right) ...
Old 03-07-2007, 02:23 AM   #3495
Tim K's Avatar
Yep, that's it - G5.
Have you seen the new 3 Racing blue alloy diff? it has some tricky device in it, looks like it could be lockable ...
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
PizzaDude
