Tamiya mini cooper
#3452
Originally Posted by Core Creations
It would have to be no load. A brand new Johnson motor will pull over 1.3amps easily with a break in fan on it.
The majority of motors checked at the last 2 years TCS events have been between .8 and 1.1 amps
The most I have ever seen on a silver can is 1.15 amps and that motor was nothing special. I think last years TCS champion drew .9amps when checked if i remember.
The Peak and the Much More give the same readings
#3453
Originally Posted by StoneMan
It's checked with no load
Then perhaps a better rule would be an rpm limit at 7 volts.
I know a more efficient motor will draw less amps.
#3454
I just run by the rules that Tamiya USA publishes...racing is racing.
#3455
Originally Posted by tony gray
Latest update on rc-mini.
Is it the first? It just might be...
Check out the site for our awesome new M03 SWB REAR WHEEL DRIVE conversion that you can do yourself for no bucks! Yes you read right, it's Rear Wheel Drive...
#3456
Absolutely no way can you run in TCS....
Its a club-level car (maybe) only. We only did it to prove it could be done!
#3458
Still curious how that thing handles.
#3459
Can anyone tell me...is the ABC Datsun 510 body done representing the car with "bubble-type" fender flares as-raced by BRE, etc "in the day" or is it "flat-sided" as the street cars? I'm seriously looking at buying one, but at the prices they're going for I want to be certain I'm getting what I really want. It appears I'm already having to compromise on wheelbase...
Many thanks for any input,
Scottrik
Scottrik
#3460
Originally Posted by SuperEk4
how abt open race like intellect cup?
Scott, I saw a 510 shell a long time back and from memory it had the squared off fender flares. I also note that its now listed as 'discontinued' on ABC's website...
Dave, aiming to give the RWD car a squirt this coming Sunday at our club meeting....update to follow Sunday night!
Tony
#3461
Hi,
This there any good discharger for pack batts i am using spintec v1.
It seems pack batt do not have much choices.
I have also a lot of ppl teaching me different things abt charging & discharging batts. Can any expert advise me
I just brought a few bnew batts I.D 4200. How many times must i charge n discharge till they become optimal performance(for race)
i m racing mini only so no match cells
#3462
HOW TO REMOVE SLOPS FROM THE ARMS? ETC?
#3463
Not necessary to do so. The car works fine as it is. Trying to get rid of all the slop doesnt really achieve anything and wastes a whole lot of time...
Don't bother.
Don't bother.
#3464
apply super glue in the hole insert pin, remove pin, and clean up. David Jun suggested this on the old TA03
#3465
Latest Update to our website.
Finally, the Drive Test on our RWD M03 conversion.
Do you need to build yourself one? Click here to find out
