Old 02-15-2007, 10:49 PM   #3271
Scottrik's Avatar
Trader Rating: 240 (100%+)
Originally Posted by tony gray
I look at it and see hints of the early BMW 2002's as well...
Agreed. A VERY pronounced "accent line"/brow clear around the car. The headlights/headlight trim and the roofline, etc are almost like a cartoon charicature of a Corvair though.
Not sure how much you know about NSU's (or anyone else), but they marketed a Wankel (rotary) engine before Mazda did. In fact I believe I'd seen somewhere that Dr. Felix Wankel worked for NSU and that Mazda licensed the rotary design from them. NSU was folded into Audi (AutoUnion) in the '70's.
Any idea who could tell me what chassis it should fit, or price?
Scottrik
Congressmen should wear uniforms like NASCAR drivers so we can identify their corporate sponsors.
THE REVOLUTION WILL NOT BE TELEVISED -Gil Scott-Heron (1949-2011)
Scottrik is offline   Reply With Quote
Old 02-15-2007, 11:16 PM   #3272
tony gray's Avatar
And their last car was the RO80..... Sadly not much of a success which is why they fell over and died.
I reckon that shell would fit pretty much any M01/02/04 or any of the 4WD Minis. Doubt it'd go on an M03 though, I think the servo mount at the front would cause problems.
Rcmart have some Active bodies, but not the NSU.
tony gray is offline   Reply With Quote
Old 02-16-2007, 08:32 AM   #3273
Send a message via AIM to aoizip
Hi guys.
I finished building my m03m.. and i need some help.
There is a lot of slop between camber link on both front and rear. The lower arm also has some too. they pretty much just move forward and backward on the hinge pin or the flat round screw.
Do you guys just shim it out??? or just leave the way it is??
Thanks,
~Ming
aoizip is offline   Reply With Quote
Old 02-16-2007, 08:35 AM   #3274
Registered User
Bodywerx's Avatar
Send a message via MSN to Bodywerx
I had the same in the rear arms.
Make sure all the screws are tight, if they are and there is still slop. Shim them....
Bodywerx is offline   Reply With Quote
Old 02-16-2007, 12:10 PM   #3275
xrayroooahhhh's Avatar
Default Shims
Is there a kit with the appropriate shims....or could you tell me who or what I should be looking for at the LHS!! Roy
-ROOH RACING-
www.donerite.net
xrayroooahhhh is offline   Reply With Quote
Old 02-16-2007, 12:34 PM   #3276
tony gray's Avatar
Originally Posted by aoizip
Hi guys.
~Ming
After building about 50 M03's and experimenting all along... We've come to the conclusion that shimming them is a waste of time. And that applies to all the areas on an M03 that wobble about.
Just leave it they work fine as it is.
Old 02-16-2007, 01:14 PM   #3277
Registered User
Bodywerx's Avatar
Well, there you go, just leave them alone.
Old 02-16-2007, 01:33 PM   #3278
tony gray's Avatar
I remember a Corally Pro 10 car that I had a number of years back which had similar issues.
It said in the manual to NOT shim anything as it was designed that way! Sneaky Dutchmen.....
Old 02-16-2007, 07:18 PM   #3279
akuhon's Avatar
Here's my opinion :
After playing many times on many kind of tracks, I've come to the conclusion :
1. Smooth track (carpet and asphalt) : shim them all
2. moderate surface (asphalt, dusty parking lot) leave small space about 0.1mm
3. rough track (rally, gravel, con-blocks, short/golf grass) : no shim at all
When you shim them, make sure the arms are not dragging. They should be smooth movement .... Try to raise up and unhold it... It should drop easily... (don;t attach the damper yet while you try this)..
In number 1 and 2 above, for lower arm, I never use middle screw and always replace the stock suspension shaft with 53301 TL01 SS suspension shaft set
FOr number 3, lower arm use the middle screw and always replace the stock suspension shaft with 53301 TL01 SS suspension shaft set
If you have chance, replace all the screw with titanium ones....
akuhon is offline   Reply With Quote
Old 02-16-2007, 07:40 PM   #3280
tony gray's Avatar
To me doing all that pretty much defeats the whole reason for running Minis in the first place!
We've been through all that sort of stuff over the 10 years we've been running Minis and came to the conclusion that
A - Too much work
B - Much as we'd like to think otherwise, we really couldnt tell the difference!
However, if it works for Akuhon then all power to him. But its all too much work for me!
Old 02-16-2007, 11:37 PM   #3281
TENCHO's Avatar
Active Hobby recently posted a new pic of their soon to be released "Classic Beeltle" Body on their website.
see it here...
http://www.active-hobby.com/2006/new20061129.html
looks like a knock off of the tamiya body...can anyone confim what brand of chrome wheels are mounted on this thing and if they are mini sized? i can't tell from the pic.
TENCHO is offline   Reply With Quote
Old 02-16-2007, 11:45 PM   #3282
tony gray's Avatar
Nahh.. it isnt a knock off. Tamiya got it dead right, The Active one has way too long a front, check out that side profile, looks really weird....
The front screen needs to come forward to make the shell look correct.
Old 02-17-2007, 02:38 AM   #3283
TENCHO's Avatar
that VW does look funny..not really true to scale. i guess what i meant to say by knock off was that they're producing a body that tamiya just rereleased.
i wonder if they made it that way to fit the M-03, but even then, it still wouldn't be true to scale. they should have made a different body, like a Fiat Punto Sport, Peugot 206, or Renault Clio!
Old 02-17-2007, 11:17 PM   #3284
TENCHO's Avatar
ABC made a Ferrari Body for M-02
for sale on e-bay now....
http://cgi.ebay.com/Tamiya-M-02-ABC-...QQcmdZViewItem
Old 02-18-2007, 05:59 AM   #3285
t4m1y4niac's Avatar
what type ferrari is it??? just looks like Testarossa...but i'm not sure..
SABRE S4 by TOP RACING....
t4m1y4niac is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 05:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-02-2011 12:08 AM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 09:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 07:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 08:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
sakadachi
SEO by vBSEO 3.5.0
