Like Tree1Likes
Old 02-15-2007, 07:25 AM   #3256
Registered User
Bodywerx's Avatar
Send a message via MSN to Bodywerx
Holy crap, that is good then.
Bodywerx is offline   Reply With Quote
Old 02-15-2007, 08:36 AM   #3257
nagatahawk's Avatar
ok, I will either get the stock mo3 kit or wait for the r kit to come out. thanks guys.
wn
nagatahawk is offline   Reply With Quote
Old 02-15-2007, 08:42 AM   #3258
Jam-ehz's Avatar
Send a message via ICQ to Jam-ehz
I'm sure we'll be seeing some used M-03 kits posted on the Buy/Sell area within the next few months, people will likely be dropping their existing semi-hopped chassis for the R kit's alloy uprights and the chance for a fresh set of parts.
-=≡ Tamiya TA05 TRF415MSX F103R M-03R M-04 M-05 ≡=-
-=≡ CRC Carpet Knife 3.2 OFNA LD3 Pro Fastcats Spektrum ׀ווlı ≡=-
Jam-ehz is offline   Reply With Quote
Old 02-15-2007, 08:55 AM   #3259
sosidge's Avatar
Questions on the ABC Genetic and the Atlas belt version...
Has anyone tried running these on standard touring tyres? Any clearance issues, can the ride height be made sensible?
Also, what current bodies suit full-size touring tyres. I used to have an HPI Golf which cleared them, HPI Civic was almost there, I suppose the Yokomo Stratus would be hard to find now?
Old 02-15-2007, 12:57 PM   #3260
tony gray's Avatar
The Northcraft 'comic' bodies are designed for Touring Car tyres on Minis and look pretty cool.
Active Hobby also make a couple that will suit the big wheels.
Dont know about putting the big wheels on either of those cars though. We havent tried it.
The Active Hobby Mini Fan 4WD Mini comes standard with big wheels though so that might be an alternative.
tony gray is offline   Reply With Quote
Old 02-15-2007, 04:56 PM   #3261
djgoku's Avatar
Default A faster Servo can produce traction roll?
I have a Futaba S9451 Servo on my mini, the servo speed can make the car traction roll?
I have it set at 100% speed on the radio
I was thinking of changing to Futaba S9550?
what kind of servos do you guys have?
Regards
DJGOKU
djgoku is offline   Reply With Quote
Old 02-15-2007, 05:02 PM   #3262
SteveM's Avatar
Trader Rating: 126 (100%+)
I have a Futaba S148 in one of my M-03 cars and a JR Z4750 in the other.
SteveM is online now   Reply With Quote
Old 02-15-2007, 06:52 PM   #3263
minimanintaiwan's Avatar
Regards
DJGOKU
We use the S9451 and S9550. there's really no performance difference between the two. if you want a smaller lighter servo then go for it but it will not influence your traction rolling. Try lowering ride height, wheel spacers on the rear wheels, Place your electronics inside the chassis, hard inserts and glued well to tire walls and don't hit those corners too hard!
good luck
minimanintaiwan is offline   Reply With Quote
Old 02-15-2007, 07:25 PM   #3264
akuhon's Avatar
when we started 45o F by the Mains 75o F I`ve used them on high 80o`s and no heating issues
Another question is there a Tamiya replacement part for the Tubes inside the friction dampers?
Thanks.
As for the tubes, I'm afraid no. But if they don't check, you can go to hardware store and find a hose for pumping the tires .... it should have smaller diameter hole.... Check by compressing the tube and find the soft to medium, not the hard one. Next, try to bend it. If it comes back quick to it's original shape...you've find the right one...... .... be sure to get the same color as the stock tubing from tamiya.....
Good luck ....
akuhon is offline   Reply With Quote
Old 02-15-2007, 07:30 PM   #3265
akuhon's Avatar
Originally Posted by nagatahawk
I am considering a mini mo3 or mo4 for tcs racing, and I see that there is a mo3r coming from Tamiya. However it has plastic clear shocks, no cvds ball diff nor anti roll bars. Would it be wiser to build up an mo4 with the above hop ups?
I this mo3r really worth it?
For shelf queen : YES
For racing : Absolutely NOT !!, reason : chassis become heavy... (IMHO)
Old 02-15-2007, 09:38 PM   #3266
Customworksking's Avatar
Trader Rating: 70 (100%+)
Regards
DJGOKU
wish A servo could stop a mini from rolling ide go to tcs with a box of em and make a killing but it's not the case its all setup
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is online now   Reply With Quote
Old 02-15-2007, 10:09 PM   #3267
Scottrik's Avatar
Trader Rating: 240 (100%+)
Tony--have you seen/owned any of these bodies? Very interested in the NSU TT from Active Hobby. Any idea how one from the US would buy one of these?
Many thanks,
Scottrik
Congressmen should wear uniforms like NASCAR drivers so we can identify their corporate sponsors.
THE REVOLUTION WILL NOT BE TELEVISED -Gil Scott-Heron (1949-2011)
Scottrik is offline   Reply With Quote
Old 02-15-2007, 10:20 PM   #3268
tony gray's Avatar
I've got ALL of the Northcraft shells, and a couple of the Active Hobby ones too. But not the NSU TT (man that's an ugly mother...)
No-one will keep that in stock, but either Rainbow Ten or rc-champ will do a special order for you.
Old 02-15-2007, 10:29 PM   #3269
Scottrik's Avatar
Yeah, not amazingly handsome...think early Corvair, but smaller. Hopefully it fits the M02 or M04 chassis as the original is rear engine/rear drive. When they were raced "in the day" they had the lid propped up like the Abarths they raced with. They were also reasonably successful.
Scottrik
Old 02-15-2007, 10:38 PM   #3270
tony gray's Avatar
I look at it and see hints of the early BMW 2002's as well...
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 05:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-02-2011 12:08 AM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 09:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 07:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 08:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
