Like Tree173Likes
Old 02-11-2007, 10:00 PM   #3226
wallyburger's Avatar
Turbonium, Tony,
Thanks for the reply and links. Very much appreciated.
wallyburger is offline   Reply With Quote
Old 02-11-2007, 10:03 PM   #3227
subman's Avatar
Originally Posted by tony gray
R10 have them in stock right now Frank.
Or rcmart.com also have some at the moment here
And painted in Camel Yellow it looks like this
Tony
Now where can I get the Colt Porsche 911GT1 or the mini monster bodies from your website
subman is offline   Reply With Quote
Old 02-11-2007, 10:08 PM   #3228
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
does anyone know where to find the Spice inserts?
tamiyarcracer is offline   Reply With Quote
Old 02-11-2007, 10:19 PM   #3229
tony gray's Avatar
rcmart have the spice inserts spice
and also the Colt 911 GT1 shells 911GT1
But Monster Mini shells are always hard to find. R10 is our usual source but they're out at the moment
tony gray is online now   Reply With Quote
Old 02-11-2007, 10:42 PM   #3230
That's another one I would have liked to get my hands on.
Hummm - maybe I should go ahead an make one?
Old 02-11-2007, 11:33 PM   #3231
tony gray's Avatar
For anyone keen to get one, my Honda Civic Type R Team Atlas Bodyshell is now up for sale on ebay... here
Old 02-12-2007, 12:16 AM   #3232
akuhon's Avatar
Originally Posted by killingtime
I run the RP30's on the rear of my mini, haven't tried them on the front (rollout reasons). Great little tire though! Just make sure the track is pretty clean though, they don't like a dirty track. If you have dust/etc... on the track I'd suggest using the HPI X-patterns.
Thanks, I'll try that. DO you have the p/n for HPI mini X-pattern ?
akuhon is offline   Reply With Quote
Old 02-12-2007, 01:33 AM   #3233
minimanintaiwan's Avatar
We have these knockoffs in Taiwan! Costs about $25US.
Tamiya mini cooper-img_2837.jpg   Tamiya mini cooper-img_2834.jpg   Tamiya mini cooper-img_2842.jpg
minimanintaiwan is offline   Reply With Quote
Old 02-12-2007, 07:55 AM   #3234
Customworksking's Avatar
Trader Rating: 73 (100%+)
Default cooper
well I went to Trackside and ran the mini in the cooper cup and wow it was on put a lap on the field every round
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 02-12-2007, 09:38 AM   #3235
djgoku's Avatar
Originally Posted by Customworksking
I run the stock gear diff and shim it tight with 5 shims 3 on 1 side and 2 on the other and it's allmost like a spool very little diff action the car ripps off the conner!!!
Iíve havenít had much fun in many races, last Saturday got the fastest lap on the A main tanks to your GREAT TIPS, tank you very much to all of you in this great forum
Muahdib4, Customworksking, Akuhon, Axle182, etc.............
Unfortunately had a crash and lost power on lap 30 and had to reset the ESC but the car was great.
I made the 4 shims on the diff: from best lap with stock diff 17.919 to 17.432 almost Ĺ second faster. Tanks Customworksking.
Lowered ride height Front to 6mm and rear 6.5 but the car was still turning over entering fast turns, the car can be lowered more?
Mounted RP tires 36īs all around with hard inserts
Our club rules only allow original dampers (friction ones) so I couldnít change springs, what we do is fill them with grease, any help with Friction Dampers?
And the best of all, the guy I was talking about lapping us like crazy won by4 laps, BUT he didnít pass the tech inspection, he was using ball diff and other hop ups not allowed in our club HE WAS CHEATING.
Tanks
djgoku is offline   Reply With Quote
Old 02-12-2007, 10:44 AM   #3236
Tanks
yes lower it all the way down to 2 to 3 mm ride heigth in the front and same in the rear glue the frt side walls and it will not roll
Old 02-12-2007, 10:50 AM   #3237
djgoku's Avatar
Originally Posted by akuhon
Anyone try Takeoff RP tires for mini ?
See this link
Any comment ?
Thx
Best tires Iīve raced, 36 all around hard incert, in a medium grip tight corner concrete track
Old 02-12-2007, 09:41 PM   #3238
akuhon's Avatar
Tanks
Glad to hear that ....
As for Friction Damper Height, you can use o-ring or plastic spacer, but you have to cut more the black rubber tube to lower the height (measure the plastic spacer you use, the number you see is the one you have to cut on the rubber tubing). Use soap and sharp knife / cutter to make precise cut .... Usually I use some oil (just a little drop) to weaken the rubber tube a bit to make better damping action. My setting usually more weak rubber on the rear than on the front. But frankly, it needs some experience to make it perfect. 4mm is the max for smooth asphalt, other conditions should be fine between 4 - 5mm height. Lower front than the rear ...
Good luck and hope you get better lap times...
Cheers,
Old 02-12-2007, 09:42 PM   #3239
akuhon's Avatar
Thanks,
I'll try it .... what's the ambient temp.when you race there ?
Old 02-13-2007, 12:52 PM   #3240
djgoku's Avatar
Thanks,
when we started 45o F by the Mains 75o F I`ve used them on high 80o`s and no heating issues
Another question is there a Tamiya replacement part for the Tubes inside the friction dampers?
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 6 (2 members and 4 guests)
Dan the Man, tony gray
