Like Tree168Likes
Old 04-23-2005, 07:06 AM   #301
Some Bolink bodies fit as well.
I have a VW Beetle (old style) body that fits the M03 perfectly
MartynD is offline   Reply With Quote
Old 05-20-2005, 06:33 AM   #302
TTT
adavid is offline   Reply With Quote
Old 05-20-2005, 09:58 AM   #303
Nova F1 Racer's Avatar
R/C Tech Charter Subscriber
THX Andy....
This is DICK!!! And you're NOT!
RC Tech member #11
Aussie Rules Footy, Brisbane LIONS!!
[url]http://www.pitter-pat.com/[/url] for pet care needs in Northern Virginia
Nova F1 Racer is offline   Reply With Quote
Old 05-20-2005, 10:36 AM   #304
CSeils's Avatar
Trader Rating: 48 (100%+)
Default Need Help
I have a suspension question for anyone that can help.
I lowered my suspension on my M03L in the front to about 1.5mm - 2 mm and 4mm in the rear. As I was doing so, I noticed that my camber in the front is now at a -5 degree. This cones my front tires and I think it affects my handling.
Is there any way to bring the camber back to a -1 or make it adjustable?
CSeils is offline   Reply With Quote
Old 05-20-2005, 10:52 AM   #305
Not unless you can make some real short camber links....
I do not believe there is a solution available over the counter .... The link is so short, making one from a turnbuckle and ball ends may well be impossible...
Old 05-20-2005, 11:18 AM   #306
OVA
OVA's Avatar
Trader Rating: 76 (100%+)
Default Re: Need Help
yes it can be done..i did it before the TCS up dated the Mini Rules
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 05-20-2005, 11:20 AM   #307
CSeils's Avatar
How?
Old 05-20-2005, 11:21 AM   #308
OVA
OVA's Avatar
You can buy the short Tamiya ball end to make this works...
I'm saying No cutting
Old 05-20-2005, 01:15 PM   #309
asw7576's Avatar
After the mod... don't throw away the original camber link. You need them to enter TCS or Asia Cup legally.
CSeils : your car is very low ride height ? 2mm is ultra low
Old 05-20-2005, 01:20 PM   #310
asw7576's Avatar
Originally posted by Robertw321
Yes, mine squeal like a stuck pig. Tire squeal is the deformation of the tire tread. It also sounds cool to spectators.
Mine too, especially at tamiya home track - aliso viejo
Old 05-20-2005, 01:37 PM   #311
CSeils's Avatar
Okay, heres the problem.
I keep rolling my mini. I'm using m-grips on the front and s-grips on the rear. 80w F white spring / 50w R blue spring. I've tried sway bars in both the front and rear, on and off.
It was suggested by some of the guys at the track that I add spacers inside my shocks to limit the travel of the front piston to 2mm and the rear to 4mm, this is supposed to tighten up the front and rear by keeping the cars CG lower. Problem is, I still roll and the camber in the front seems to high.
Are there any other suggestions to accomplish this? or what else can I do?
If anybody has an idea to correct this, let me know.
Old 05-20-2005, 01:38 PM   #312
minidriver's Avatar
Default alternative bodies for mini
The old Tamiya Honda S800 roadster body originally for the M01 chassis also fits the M03 (but not the M03L). It's a cool looking body, typical Tamiya quality and detail I just happen to have a very small quantity of these bodies, brand new in box, available for sale. $35.00 plus shipping, PM me if you are interested.
minidriver is offline   Reply With Quote
Old 05-20-2005, 01:40 PM   #313
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
ill take one of those David.... i am doing a bit of collecting the Mini bodies. so far, just the Z3 and Boxster, but looking for more!
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 05-20-2005, 01:53 PM   #314
NOZ69's Avatar
Default Re: Bodies Available?
Originally posted by rctoyguy
What bodies (other than the original Mini) are available or will fit the M03 and M03L chassis?
This is a picture of a mates... the body is made by "Frewer" it`s an Australian RC body maker.
Cheers
FT TC4, LRP TC Sphere, LRP X-11 13.5
SC10 4x4
M03M Suzuki Swift
Power by Feral
Sanwa MX-3 FHSS
NOZ69 is offline   Reply With Quote
Old 05-20-2005, 02:24 PM   #315
moot's Avatar
thats some pretty stiff suspension. i run the trf shocks with the 3 hole pistons,with 50w in the front with yellow springs.in the rear its the 3 hole pistons again and 25w oil with standard 'chrome' springs.i only have 2 o-rings in the shocks because i find the car works better with down travel.my ride height is 3.5mm in the front and 4.5mm in the rear.i run front and rear sway bars and 2 degree toe in the rear.with hpi x patterns or foams i have never traction rolled.
moot is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
