Like Tree200Likes
Old 01-20-2007, 07:48 AM   #3046
Originally Posted by DrKucho
hi guys, i found someone talking about the speed tuned gear set for tamiya minis, what is the part number? i cant find it anywhere ... ??
from what I know its not tamiya that makes the gears, thats probably why you cant find part numbers.
SeaKayCarthik is offline   Reply With Quote
Old 01-20-2007, 08:14 AM   #3047
found a tobee at rc-mini.net , is that the only one option?
DrKucho is offline   Reply With Quote
Old 01-20-2007, 08:15 AM   #3048
SteveM's Avatar
Trader Rating: 141 (100%+)
Eagle Racing makes an after market set of gears to use with the metal diff gears. Integy have them listed on their web pages.
Tobee also list different spur gears for the M03 and they seem to have 35, 36 ans 37 tooth spurs that can be swapped out. Lots on eBay.
SteveM is offline   Reply With Quote
Old 01-20-2007, 08:56 AM   #3049
Core Creations's Avatar
Trader Rating: 95 (100%+)
Send a message via AIM to Core Creations
In what situations would you want more air gap?
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 01-20-2007, 08:56 AM   #3050
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
Originally Posted by SeaKayCarthik
Ok, I will use 24 then. What type touring car insert (soft or hard)? What is tribo btw?
I was thinking this for my indoor carpet setup, any comments/suggestions?
front
-type A 60D tire
-hard 60D insert
-hard 24mm touring insert
rear
-type A 60D tire
-hard 60D inesert
-soft 24mm touring insert
would that work? I dont want to lost too much on the handling but would prefer if my A's dont wear out so fast.
Carthik
you will find that the S grip, and the M grip Radials, even the kit radial will work better for you on carpet. I found the A tires to just to spin al lthe way down the straight.
tamiyarcracer is offline   Reply With Quote
Old 01-20-2007, 09:23 AM   #3051
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
i agree on the M's and S's, but my experience with A's differs in that they hooked up great with compound, but couldnt keep it from traction rolling, no matter what i tried, sways, oil, springs....
i think the fastest laps at the recent Novak were done with Ms and Ss, sways, and a ball diff... Matts Suzuki was awesome!
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 01-20-2007, 02:17 PM   #3052
muahdib4's Avatar
Send a message via Yahoo to muahdib4
Just got the Short Tuned Spring set and I also ordered all the Short Tuned springs individually and I noticed that the individually packaged ones are quite a bit shorter than the ones that come as a set. Does anyone know if the spring rates or ratings are different from the Tuned Spring set to the individual packaged ones? I planned on starting with the whites up front and the yellows in the rear and then tuning from there to find out what works best for me but I'm not sure which yellows to use.
KCRC - Kansas City Remote Crawlers
Team Chucklenuts Racing
Midwest R/C Rally Confederation
KC/RC Drift Movement
muahdib4 is offline   Reply With Quote
Old 01-21-2007, 09:45 AM   #3053
minimanintaiwan's Avatar
Default 3racing motor fan
hey check this out, a motor fan for a M03M. Just wondering where'd you mount it?
http://www.racing11.net/shop/product...oducts_id=3029
TonyG - great work on the Orion Carbon Lipo. What charger are you using for it? is it possible to protect underside of battery where its exposed on the two sides. ? is it possible to design a carriage type holder like just flipping existing holder so battery sits within? now that you got free weight to play with it might be worth experimenting.
minimanintaiwan is offline   Reply With Quote
Old 01-21-2007, 10:04 AM   #3054
SteveM's Avatar
It would mount to the servo mounts on top.
Old 01-21-2007, 10:09 AM   #3055
tony gray's Avatar
We used a cheap 'Swallow' charger on the Lipo but we've also used the ICE as well.
Hadn't thought about other ways of mounting the pack, we just stuck it in and it seemed to work so we left it at that!
That 'motor mount' fan thing?.... Well its a fan yes, but from what I can see it doesnt actually mount to the motor at all? Would you agree Steve? Looks like it just sits over the top of the motor.
tony gray is offline   Reply With Quote
Old 01-21-2007, 10:24 AM   #3056
SteveM's Avatar
I agree. It looks like it mounts above the motor by way of the servo mount screws. It might work well enough but I'd be worried about the extra weight up that high.
I've not had much luck with 3Racing fans. I bought a clamp-on heat sink with cooling fan for my XXX-S sedan and had two blades on the fan break the first time I used it.
Old 01-21-2007, 05:45 PM   #3057
would that fan be tcs legal (canada)? how much does it weigh?
still need tire setups! so no-one really reccomends A's?
Old 01-21-2007, 05:55 PM   #3058
Registered User
Bodywerx's Avatar
Send a message via MSN to Bodywerx
No it is not TCS legal, as it is not a Tamiya part.
TCS only alows Tamiya parts.
Bodywerx is offline   Reply With Quote
Old 01-21-2007, 05:58 PM   #3059
CCristo's Avatar
Trader Rating: 55 (100%+)
Default Servo Stays
Does anyone know the part # for the long TG10 aluminum servo post/stays? I
Chris Cristo
Pro-Line RacingHobbywingMIPBOOMrcFutabaPT RC Racing Oils
CCristo is offline   Reply With Quote
Old 01-21-2007, 05:59 PM   #3060
I think i remember reading before (couple years) that any manufacturer heat sink is allowed. so people started running (I think) those heatsinks with fans on them. Thats why I thougth this would be legal, but I guess its not a heatsink.
Carthik
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 05:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-02-2011 12:08 AM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 09:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 07:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 08:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
