Like Tree23Likes
Old 01-18-2007, 10:44 AM   #3016
muahdib4's Avatar
Send a message via Yahoo to muahdib4
Originally Posted by Difuser
Wow this thread moved on a bit last night.
On the TRF shocks I like them because the shock is more precise. With the teflon piston fitting alot tighter to the shock body. While I agree that CVA's work close to the same and are lighter, the tolerance and resulting weight of oil having to be run stiffer I just flat do not like. I run generally around a 30-40wt oil period. I will vary the piston hole to get the balance and weight shift to where I prefer. With the CVA you have to run around an 80wt to get close to the same but with the blowby and the larger hole it just is not the same.
For the tires I do not have heaps of carpet experience here. David Weir who posted above is the man there. He is a regular at Trackside along with one whose hat is always there in the Nationals game. What I have found in the past is the the worse the tire the better the grip. I found the Mgrip tire on the rear and an S or A to be the hot ticket at Worlds. This was on the M04M. For insert I liked the black foam front and rear. It just sucked I found this in the last Main as the track changes so much over the 4 days that it is very tough to understand the car.
With Trackside allowing compound this might change a touch but it should be pretty similar.
As for my pedigree I am just an over the hill racer/business owner that still likes to offer the info I have learned racing. I like to think it helps others meet their goals. No Ego here and I certainly don;t need brownnosing. Madjack pointed out a fact nothing more, not all the people posting here know that in the last 15 posts or so you have 3 of the last 4 Mini National Champ winners from 2002 to present here offering help for those who want it.
Any of you going to be at 'Birds come over and say hello. Look for the Slapmaster Team in 12scale
Cool, thanks for the info and I wasn't trying to stir up trouble and everyone is very helpful.
I think I just got a bad taste in my mouth from a few folks in another forum regarding ROAR rules changes being considered that would have made everything I own unuseable and forced me to spend hundreds of $$$ to get new stuff and I was told that since a sponsored national champion supported the change that I should just shut up. Since then, I've been a little quick on the draw and perhaps I should just calm down...
KCRC - Kansas City Remote Crawlers
Team Chucklenuts Racing
Midwest R/C Rally Confederation
KC/RC Drift Movement
muahdib4 is offline   Reply With Quote
Old 01-18-2007, 04:42 PM   #3017
minidriver's Avatar
Many thanks for the compliment, diffuser.
Yep, IMO, M's in the rear is the ticket for either M03 or M04 on carpet. Generally I use a decent air gap in the rear, thus I tend to favor the now discontinued black shaped m inserts (I still have a couple pair, I keep reusing them). A close equivilent is to take a 24mm black sedan shaped insert and cut it down in length to match the now discontinued mini insert. Width is fine.
On carpet, when traction can get quite high and can induce roll over tendencies, I think the key is a very full tire up front - a trick I learned from Diffuser. No air gap, solid sidewall tire (by stuffing the tire with insertS)- keeps the front tire sidewall from flexing over, which is what seems to induce the roll.
minidriver is offline   Reply With Quote
Old 01-18-2007, 06:22 PM   #3018
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
Originally Posted by Tomoyuki
Well i havent bought any shocks yet.. so i mite go wif plastic oil shocks first... anyway wad should the M03M front suspension conversion consist of?
51238, and 8 qty 10mm x 5mm bearings (51239)
This converts front and rear Suspension. The rear has 2 degree of toe, where as stock does not.
tamiyarcracer is offline   Reply With Quote
Old 01-18-2007, 06:34 PM   #3019
Originally Posted by Steven Key
I have a couple questions for all you Mini experts.
1. Are the suspension parts #50736 (TL01 B Parts) the same as the Suzuki Swift #51238 (M03m F Parts)?
2. Are the rear blocks on the #50736 parts tree the same as #51238 and do they have 2 degree toe in?
Nothing about the Swift (51238) is similar to the older uprights (50736). the 51238 are all the suspension parts that they upgraded on the swift, get the 51238 and some 10 x 5 bearings and your set.
Also not mentioned, 50736 has 0 degree rear uprights. Most people have to get the hop up part when they run the older suspension. with the swift suspension (51238) you do not need to purchase toe in rear uprights, as rear on this tree has 2 degree
Old 01-19-2007, 06:08 AM   #3020
Steven Key's Avatar
tamiyarcracer, thanks for the reply, the parts do look simliar on the picture now I know they arent'.
For those of you how are at Trackside, you are welcome to come by and see it in action, and I have some of the rubber stuff in my pit box.
Dave, I will have to come by next Tuesday and check out your rubber stuff. Sounds like a really good idea.
Steven Key is offline   Reply With Quote
Old 01-19-2007, 06:39 AM   #3021
MrLesac's Avatar
Trader Rating: 26 (100%+)
Send a message via AIM to MrLesac
hey, i made something that my be useful to mini painters.
Kevin --- Facebook.com/FormulaGraphics---
Exotek
Formula Graphics
MrLesac is offline   Reply With Quote
Old 01-19-2007, 07:24 AM   #3022
muahdib4's Avatar
That rocks..now if we only had one for the real Mini....
Old 01-19-2007, 07:39 AM   #3023
MrLesac's Avatar
i think there is one under the painting and design forum, under the templates topic. if there isnt let me know, and i can make one
Exotek
Formula Graphics
Old 01-19-2007, 07:47 AM   #3024
muahdib4's Avatar
You know, I had no idea that was there...thanks.
Old 01-19-2007, 12:05 PM   #3025
HotrodHopkins's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to HotrodHopkins
yeah, i had scoobydoo make one for the tamiya rover cooper and the Beamer version. Nice job there MrLesac!
SHAUN HOPKINS a.k.a NoRod Hopkins
-1990 Chevrolet K1500 Silverado TBI350 "Heavy Half". 1971 Chevrolet Nova
-My lug nuts require more Torque than your Honda makes.
HotrodHopkins is offline   Reply With Quote
Old 01-19-2007, 12:11 PM   #3026
wallyburger's Avatar
Default battery pack Question
Hey fellas,
What packs would you recommend for on road bashing and long run times for an M03?
Cheers.
wallyburger is offline   Reply With Quote
Old 01-19-2007, 12:27 PM   #3027
MrLesac's Avatar
we can run about 16 minutes on our spec venom 3000 packs we have to run at our track with the kit motor.
running an unmatched 4200 i can get over 20 minutes of run time
Exotek
Formula Graphics
Old 01-19-2007, 12:36 PM   #3028
muahdib4's Avatar
Originally Posted by wallyburger
Hey fellas,
Cheers.
Team Orion 3200 Lipo will give you the best run times and will also not require discharging...cooling or any other battery maintainance. Guys at our track are using roughly 600mah over a 5 minute race so that should equate to 30+ minutes of runtime. Plus, they are lighter and offer more consistent performance AND they won't need replacing in a few months.
Old 01-19-2007, 01:01 PM   #3029
CSeils's Avatar
Trader Rating: 48 (100%+)
Quick question on the gear diff.
Now, before everyone tells me to get a ball diff...I already have one. I've heard that some guys occasionally use the gear diff on carpet. What I want to know is if I use the gear diff, how tight should it be? Locked? Just able to rotate? Just curious.
You can never go wrong with a Hooters Mini. But Mini Hooters are bad.
--- USVTA National Points Series Member #122 ---
customracingstickers@gmail.com - http://www.rctech.net/forum/painting-designs-graphics-photography/279695-usvta-trans-am-decals.html
CSeils is offline   Reply With Quote
Old 01-19-2007, 01:06 PM   #3030
Wicked-Wayz's Avatar
Trader Rating: 19 (100%+)
Send a message via ICQ to Wicked-Wayz Send a message via AIM to Wicked-Wayz Send a message via MSN to Wicked-Wayz Send a message via Yahoo to Wicked-Wayz
Just able to rotate I think carl. I think per the rules it can't actually be locked. Maybe someone else knows exactly.
Peace Aaron(W-W)
Schacht Design Works Trackside Hobbies Dirtheaven CRC Hobbies MidWest Tri-Clone RC Scoring Pro LiveRc.com 92 Zero Designs
Wicked-Wayz is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
