Like Tree200Likes
Old 01-18-2007, 08:20 AM   #3001
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
Originally Posted by Scottrik
OK--this is probably about a stupid question/problem, but here goes. I haven't used a stick pack in almost twenty years. So, stupid me figures a stick pack is a stick pack, right? I just received a couple Racer's Edge 3600 packs and guess what...they don't fit in my MO4...not even close. It's about 1/4" too long. The ends of the pack are capped w/plastic caps, and the "wire end" cap can be compressed a bit (MAYBE 1/8")...what to do?
I had sure hoped to run the car(s) this weekend at our race.
**edit**
I happened to think I had an older stick pack in the basement that came with my TXT I bought a couple years ago. It's a Duratrax 1500 pack and it fits like a dream. I know cells have gotten a BIT longer, but I'd never realized they'd gained .1" or so. I also see by the rules that these more recent cells are TCS legal:
1) how do I get 'em to fit within the rules, or
2) what seems to be the cut-off, mah-wise, before the cells grew too big? 3300? 3000?
Thanks,
Scottrik
i have been running 4200s in mine... you can usually cut the holders a bit if needed. or, maybe cut the plastic ends on the stick packs.
when i built my sticks i just left off the endcaps altogether, and just used the shrinkwrap.
Wes
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 01-18-2007, 08:32 AM   #3002
Scottrik's Avatar
Trader Rating: 245 (100%+)
Thanks Wes, but I REALLY don't want to cut the holders as by my reading of the TCS rules this is not strictly legal. May seem cs, but if them's the rules... And I don't think taking the plastic ends off the pack will gain me all I need. Just estimating, it gets me about half-way there.
Anybody?
Thanks,
Scottrik
Congressmen should wear uniforms like NASCAR drivers so we can identify their corporate sponsors.
THE REVOLUTION WILL NOT BE TELEVISED -Gil Scott-Heron (1949-2011)
Scottrik is offline   Reply With Quote
Old 01-18-2007, 08:33 AM   #3003
Steven Key's Avatar
1) Nope, they look more like the uprights for the Mini standard suspension, but certainly not the M-03M F parts. The main giveaway is that the front knuckles don't have 2 steering mount holes (though you can't really see that in the pics), and the M-03M rear uprights look more like uprights on the regular Lightweight Suspension, they're much narrower.
Jam-ehz, thanks for the reply. I understand what you are saying. It saved me the trouble of checking this out for myself.
Steven Key is offline   Reply With Quote
Old 01-18-2007, 08:38 AM   #3004
CSeils's Avatar
Trader Rating: 48 (100%+)
Scottrik
Don't use the body clip battery end holders, tape your batteries to the extensions. all you need to do then is to center your pack.
You can never go wrong with a Hooters Mini. But Mini Hooters are bad.
--- USVTA National Points Series Member #122 ---
[email protected] - http://www.rctech.net/forum/painting-designs-graphics-photography/279695-usvta-trans-am-decals.html
CSeils is offline   Reply With Quote
Old 01-18-2007, 08:45 AM   #3005
Scottrik's Avatar
Is taping the battery in TCS-approved? If so, that'd work.
Centering-wise, I've got a fixed end on the left side of the chassis and it looks like the battery will hang just a skosh (MAYBE 1/8") to the right. Then again, this is opposing the motor weight hung off to the left so maybe...?
Scottrik
Old 01-18-2007, 08:57 AM   #3006
SteveM's Avatar
Trader Rating: 141 (100%+)
Taping the cells is permitted as per the TCS rules.
Scottrik
SteveM is online now   Reply With Quote
Old 01-18-2007, 08:58 AM   #3007
Customworksking's Avatar
Trader Rating: 73 (100%+)
Scottrik
Taping is ok my batt hangs out as well I hang it out a bit more on the op side of the motor ... when's your TCS race i will be @ trackside In March
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 01-18-2007, 09:11 AM   #3008
CSeils's Avatar
I'll use the body for reference. As long as I'm close too or not rubbing against the body, I'm fine.
Old 01-18-2007, 09:17 AM   #3009
Originally Posted by SteveM
I'm using whatever oil came with the CVA shocks. My setup is the same except I'm running HPI X-Pattern tires and/or RP30 and RP36.
Steve, are you using the HPI's for Fastcats club racing? Because they arent tcs legal. And I asked if they are legal for fastcats and I believe the answer I recieved was no.
Cheers,
Carthik
SeaKayCarthik is offline   Reply With Quote
Old 01-18-2007, 09:22 AM   #3010
minidriver's Avatar
Scottrik
A better solution than taping for M03 based minis is to go to home depot/lowes and buy a package of rubberized non slip pad that they sell in the tape department. This is the stuff that you buy to place on the bottom of somthing to make it not slide on a table. Comes in a 3" square piece, precut to 1" widths. It is about 3/16" thick, with one side having double faced tape for application to any surface. Costs all of about $2.50 a package that would do a half dozen cars.
Take two 1.5" long strips of this and apply it to the underside of both of the battery slot extensions. Now your stick pack will slide in but only with great effort, as this reduces the slop in the battery compartment. (When you go to put your battery in, it looks like you are using some pectoral strength builidng gadget!) Holds the battery in just fine without the need for any tape or other holding devices. I have yet to have a battery come loose or even move in racing using this system, regardless of how hard I might get hit. One application will problably last for 3-4 months, then just replace when needed (as eventually the effort of sliding the battery in and out will cause an edge of the material to come unstuck).
Even better, however, is that in contrast to taping your battery in (which pulls the battery up against the battery pods, raising the center of gravity), this forces the battery to it's lowest possible position, lowering the center of gravity and improving the handling. This system also allows you to precisely center side to side the battery in the slot, and I find that self constructed battery packs (not factory premades) are a bit too long to center using the Tamiya battery holding system. With my solution, that is no longer a problem, center it where ever you like, and you don't even need the L-shaped pieces at the end of the battery slot extensions.
For those of you how are at Trackside, you are welcome to come by and see it in action, and I have some of the rubber stuff in my pit box.
minidriver is offline   Reply With Quote
Old 01-18-2007, 09:22 AM   #3011
SteveM's Avatar
I'm in Ottawa and run with the R/C Ottawa club. Our rules are based on the Canadian TSC rules but we allow any brand of body and tires. The Tamiya bodies are very expensive compared to HPI and others and we want to keep costs as low as possible to grow the class. Same with the tires. I have a set of RP30 and RP36 that also work very well.
Cheers,
Carthik
Old 01-18-2007, 09:57 AM   #3012
madjack's Avatar
Trader Rating: 20 (100%+)
Send a message via Yahoo to madjack
Originally Posted by muahdib4
This thread has been pretty good about not doing this kind of things so let's end it right here. This is a public thread and everyone is allowed to give their opinions. Just because someone has won a national race or is even World Champion of all things R/C...doesn't make that opinion more valid than another. I've been on other threads where people shoved their noses halfway up the keister of some sponsored national winning driver and just told everyone to go along with their opinion because they were a better driver. That's not the way to be. I'm sure that Difuser won't have his feelings hurt if someone offers a differing opinion. He seems like a pretty down-to-earth person from the posts I've read.
Clearly, given the short length of my first post I was merely agreeing with Difuser’s opinion regarding his choice of shocks. (because of my lack of interest in debating the efficiency of the plastic vs. alloy shock as it relates to the inherent flex in the M03, M04 chassis)
While I can appreciate your desire to keep the thread positive, I’m unclear about what “doing this kind of thing” means? If I have offended anyone’s fragile sensibilities, I’ll make sure to practice safe posting in the future. Regarding the reference of nasal locations on other threads….if you are referring to me personally, I’ll have to say you’re the first to make that statement to describe my personality.
The latest TRF shocks are excellent products, hence the reason you have seen the majority of other RC manufacturers base their recent shock design on the Tamiya product. My opinion
madjack is offline   Reply With Quote
Old 01-18-2007, 10:08 AM   #3013
Lightbulb tape
I also use the foam tape to lower it ...works for me ! will be @ trackside in March
Old 01-18-2007, 10:08 AM   #3014
muahdib4's Avatar
Send a message via Yahoo to muahdib4
I was simply referring to discounting someones opinion based on the fact that they hadn't won a national competition. Which it seemed like you were doing. If that wasn't the case then I apologize. It's just that I've seen several people do that in other threads.
KCRC - Kansas City Remote Crawlers
Team Chucklenuts Racing
Midwest R/C Rally Confederation
KC/RC Drift Movement
muahdib4 is offline   Reply With Quote
Old 01-18-2007, 11:33 AM   #3015
Wow this thread moved on a bit last night.
On the TRF shocks I like them because the shock is more precise. With the teflon piston fitting alot tighter to the shock body. While I agree that CVA's work close to the same and are lighter, the tolerance and resulting weight of oil having to be run stiffer I just flat do not like. I run generally around a 30-40wt oil period. I will vary the piston hole to get the balance and weight shift to where I prefer. With the CVA you have to run around an 80wt to get close to the same but with the blowby and the larger hole it just is not the same.
For the tires I do not have heaps of carpet experience here. David Weir who posted above is the man there. He is a regular at Trackside along with one whose hat is always there in the Nationals game. What I have found in the past is the the worse the tire the better the grip. I found the Mgrip tire on the rear and an S or A to be the hot ticket at Worlds. This was on the M04M. For insert I liked the black foam front and rear. It just sucked I found this in the last Main as the track changes so much over the 4 days that it is very tough to understand the car.
With Trackside allowing compound this might change a touch but it should be pretty similar.
As for my pedigree I am just an over the hill racer/business owner that still likes to offer the info I have learned racing. I like to think it helps others meet their goals. No Ego here and I certainly don;t need brownnosing. Madjack pointed out a fact nothing more, not all the people posting here know that in the last 15 posts or so you have 3 of the last 4 Mini National Champ winners from 2002 to present here offering help for those who want it.
Any of you going to be at 'Birds come over and say hello. Look for the Slapmaster Team in 12scale
UF1 Seattle - SPEEDWERKES - VBC Racing - Team ORCA
Difuser is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 05:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-02-2011 12:08 AM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 09:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 07:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 08:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
