Like Tree23Likes
Old 01-09-2007, 04:42 AM   #2881
Registered User
Bodywerx's Avatar
Send a message via MSN to Bodywerx
Originally Posted by wallyburger
Here's a sampling of my past body work...smaller scale of course...
[IMG]
I have an 'itch' for this part of the hobby.
Wally, who makes those bodies for the micros?
Bodywerx is offline   Reply With Quote
Old 01-09-2007, 06:59 AM   #2882
Core Creations's Avatar
Trader Rating: 92 (100%+)
Send a message via AIM to Core Creations
I need a good carpet setup for medium traction carpet for the M03M. And will thicker oil help the car transition better?
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 01-09-2007, 07:17 AM   #2883
FreqETag's Avatar
Seconded.
FreqETag is offline   Reply With Quote
Old 01-09-2007, 09:52 AM   #2884
mach51's Avatar
Trader Rating: 30 (100%+)
haha, I came in here to ask about a carpet setup for the M03...
mach51 is offline   Reply With Quote
Old 01-09-2007, 10:06 AM   #2885
SteveM's Avatar
Trader Rating: 128 (100%+)
I'm running the SWB M03 on my club's carpet track with the following settings;
-Tamiya CVA super mini shocks, 2-hole pistons, supplied shock oil, 6mm spacers inside on the shock shafts. Part #50746
-Black (soft) sway bars on front and rear. Tamiya #53343
-Springs are blue (hard) up front with red (soft) in the rear. Tamiya #53333
-Universal Shaft Set. Tamiya #53597
-Tires are HPI X-Pattern belted radials on HPI rims.
-Pinion is a 20T
-Hollow carbon gear shaft set. Tamiya #53390
-Body is HPI VW Beetle
-Steering servo is JR270
-ESC is a Novak Atom
-Receiver Novak XXL
-Silver can Mabuchi motor
-Tamiya aluminium motor heat sink
-Stock rear carriers (zero degrees)
-Stock kit gear diff
I use compound on the rear tires only as my track already has lots of traction already and I do not experience any traction rolling. Turn-in is pretty quick but that is controllable. Swap out the body and tires for Tamiya items and be TCS legal.
SteveM is online now   Reply With Quote
Old 01-09-2007, 10:08 AM   #2886
mach51's Avatar
i bought mine used, its got sort of a black can motor, the class im going to run in is supposed to be the stock motor. The blackish can is closed end bell but i dont know anything else beyond that.
Old 01-09-2007, 10:11 AM   #2887
SteveM's Avatar
The kits come stock with a silver can closed end-bell Johnson or Mabuchi motor. The black can motor you have is the Sport Tuned version by Tamiya and is a bit faster than the silver version.
Old 01-09-2007, 10:30 AM   #2888
Sorry, I need to clarify...I need a carpet setup while staying TCS legal...thanks.
Old 01-09-2007, 10:56 AM   #2889
Registered User
Bodywerx's Avatar
TCS legal setup
M03-M Swift with the following settings;
going to try the yellows on the front as I am having too much wheelspin.
-Tires are Tamiya 60D Treaded tires on Tamiya Swift rims.
-Pinion is a 20T
-Body is Tamiya Swift
-Steering servo is Futaba S3003
-ESC is a Futaba MC230
-Receiver Novak XXL
-Stock M03-M rear carriers (2 degrees)
-Stock M03-M front knuckles
Old 01-09-2007, 10:57 AM   #2890
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
what i ran at the Novak mainly consisted of:
M03M chassis, without any extension...
TRF short dampers, 2-hole pistons, i think 70/50 oil... maybe 3-4 orings in each to reduce droop
short white front springs, short yellow rear
S-grip in front, M-Grip rear
silver sway front, black on rear
it was pretty decent to drive, could be tippy if pushed too hard, but drove well with the old skool Mini, as well as the Worm!
Wes
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 01-09-2007, 11:54 PM   #2891
tony gray's Avatar
OK, the thing that everyone seems to get REALLY confused with on a Mini are the various wheelbases. Go here now for the answer!
tony gray is offline   Reply With Quote
Old 01-10-2007, 01:05 AM   #2892
I have question on these. I am looking at getting the Suzuki Swift for myself and son. Will these accept regular size electronics? Also what would be a good servo. Also are you running stick packs or can I use the side by side 3800's I currently have? Thanks for the help.
Kevin
KevinL is offline   Reply With Quote
Old 01-10-2007, 01:15 AM   #2893
mild seven's Avatar
Trader Rating: 62 (100%+)
Send a message via MSN to mild seven
yes normal sized electronics can be used. the side x side packs wont fit u have to use stick packs. i just use a standard futaba servo and that works just fine.
hope that helps
mild seven is offline   Reply With Quote
Old 01-10-2007, 01:17 AM   #2894
akuhon's Avatar
Kevin
All regular size electronic (ESC, Servo, Rx) will fit.
Good servo depend on you need .... mine use futaba 9550 digital and lighter.
You can use side by side pack but you have to cut some plastic part on the chassis to fit this kind of pack, and I think it's illegal for TCS unless you're running outlaw class like me which allow chassis modification.
akuhon is offline   Reply With Quote
Old 01-10-2007, 01:19 AM   #2895
Thanks for the info, where can I find the rules for TCS?
Kevin
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
