Like Tree19Likes
Old 12-23-2006, 12:11 AM   #2701
tony gray's Avatar
Sure will, they'll go straight on....
Just make sure you use the Short tuned spring set with them, and we actually remove the spring tension adjuster as well to get the length down shorter.
tony gray is offline   Reply With Quote
Old 12-23-2006, 12:15 AM   #2702
f2000racer's Avatar
THanks!
I'll try that.
Tamiya F103RM
Tamiya Mini
Tamiya TA05
f2000racer is offline   Reply With Quote
Old 12-23-2006, 07:44 AM   #2703
minimanintaiwan's Avatar
Or use TRF short springs (53630/soft - 53633/ex-hard. These are shorter and u dont have to remove the tension adjuster. The tension adjuster is the great feature of tis damper set. You can adjust height to the fraction of a mm with it.
Tamiya mini cooper-img_2934.jpg   Tamiya mini cooper-img_2936.jpg   Tamiya mini cooper-img_2943.jpg
minimanintaiwan is offline   Reply With Quote
Old 12-23-2006, 10:24 AM   #2704
A question for the masses: I know the answer to this question is in the back pages, but I couldn't find it.
Q: Is there a gear set (ie: gearbox), optional, aftermarket or parts from another Tamiya car that can be used in a M03 to raise the final drive ?
Graphitedust is offline   Reply With Quote
Old 12-23-2006, 11:41 AM   #2705
tony gray's Avatar
Tobee Craft make a set of alternative spur gears (36/35/34) that will raise the final drive. They are notoriously hard to find though. Jasons Store on ebay sometimes has them but not at the moment. Rainbow Ten also carry them sometimes.
Eagle Racing make a single set of replacement gears as well, which are basically the equivalent of running a 21T pinion. And also hard to find. RC Mart have them now and then but also dont have them right now.
Neither set of gears are legal in racing I hasten to add.
Old 12-23-2006, 07:38 PM   #2706
tony gray's Avatar
Another big page of updates today..
A fairly comprehensive listing of all the official Tamiya Hop-ups for the M03 series. I cant guarantee that they're all there (I didnt do spacers and washers and screws etc) but 99% should be listed there.
If there's something else you feel should be there, please let me know.
An after market listing is in the works too..
http://www.rc-mini.net/MiniWeb1/Parts_Listing.html
Old 12-23-2006, 08:05 PM   #2707
Customworksking's Avatar
Trader Rating: 71 (100%+)
Arrow thanx
thanx for the list I see 1 thing i don't have
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 12-24-2006, 09:49 AM   #2708
madjack's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to madjack
nice quick ref. tool Tony, thanks
madjack is offline   Reply With Quote
Old 12-24-2006, 05:57 PM   #2709
Tony the TL01 SS hingepins will fit. The Mantaray ball diff will fit. There are 2 versions of the light weight king pin. A steel and an Al version.
Sydewynder is offline   Reply With Quote
Old 12-24-2006, 07:50 PM   #2710
tony gray's Avatar
The susp shafts (53301) I plain forgot...
Manta Ray diff (53070)... Hmm I suppose I should add that too even though it weighs a ton.
And the kingpins... I'll have to check on that. Somewhere in the dark recesses of my memory is something that tells me that the 53157 king pins (the alloy ones) aren't suitable for some reason....although for the life of me I cant remember why?
Old 12-25-2006, 11:33 AM   #2711
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
Tony, @ The Tamiya World Championshis this year they had a conversion kit that used TL01 arms on a M04. Have you ever tried this, or have a starting set up.
tamiyarcracer is offline   Reply With Quote
Old 12-25-2006, 11:37 AM   #2712
tony gray's Avatar
Sorry mate, but our M04 experimenting has been minimal to say the least. We've really only had a little play with them and that's that.
However, one of our guys is starting to play with his a bit over Xmas so I'll run that idea past him to play with with.
But I cant help wondering what it would achieve anyway? A really wide M04? And what shell would even fit on it?
The latest update to rc-mini is up now.
What are we doing with these Minis? Check out the site here to find out!
Old 12-25-2006, 03:16 PM   #2713
defMondo's Avatar
hmmm interesting, so someone was running an M04 with TL01 suspension arms?
Or did someone just have a car built like that?
TP
defMondo is offline   Reply With Quote
Old 12-25-2006, 03:18 PM   #2714
TP
No, it was a kit you could by to change an M04L to put TL01 arms and run a Porsche TA02 body on it.
Old 12-25-2006, 03:20 PM   #2715
tony gray's Avatar
News to me... That'd have to be the Porsche TA02SW body then? Not exactly an easy one to find I'd reckon?
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 6 (2 members and 4 guests)
badboy, Rich Panganiban
