Tamiya mini cooper
R/C Tech Elite Member
Where did you find this bargain?
only rule about fans is that there is a limit of two (2) fans that can be used in the vehicle. and i believe there a size restraint (30mm max)
other than that you can use any brand and use any type/brand of fan mount (home made included).
I've made mounts for a few things using bits of lexan. You want it to be a little heavier gauge, so the roof section from off road cars or sheets you buy at your hobby shop are best.
Hey does anyone know when the M05VII "R" will be available? I saw that some places in the UK are selling it.
it would have been cheaper if I was willing to wait 1-2 weeks for it to arrive from elsewhere or from another shop
I bought the newly released CC01 pajero custom low rider black
maybe I should do an unboxing video
Hey Dan, great info!! BTW where is Spec-R located? Is this a Chinese company? I have no idea. Regardless, please keep me posted on the pricing and availability.
Any double deck CF m-chassis (especially 4WD), please keep me posted. You guys know I have a thing for CF m-chassis.
I expect no less from modern RC companies.
I like the steering setup and motor mount setup over the Sabre.
This is RP-033 but there is a slightly smaller one available RP-031 which is slightly more than half the price of the larger one.
Yeah, Spec R is either a Chinese or Taiwanese company. They make affordable kits with "reasonable" quality. But not sure how it will compare to TOP quality. Price should be pretty affordable($140-160 USD range??)
Are you aware of any special wiring rules, or just the size???
you can wire it however you like. must run off of the main battery. (can not have its own battery)
Hi all,
Need the advice of the experts.
Recently started RC again and bought a M-05 Version II Pro.
Currently running a standard diff with some additional putty in there. Problem is that this doesn't keep stable. Diff always becomes softer after a few runs.
I've noticed that quite a lot of M-chassis owners use a spool or high viscosity oil in their diff.
What are the advantages and disavantages on doing this.
Any recommendations.
The stock diff is garbage.
Whether you put putty or hi-vis oil, it will just spin out. You can create a friction diff by adding washers, but that just stresses out the components and doesn't work as well as a proper hi-vis oil.
Getting a ball diff is a slight improvement, but you still have a lot of maintenance to contend with.
There are spools available which use trf 417 out-drives, though the general consensus is that the sealed gear diff with 500K is a good starting point.
Why not I'll also disagree with you on the ball diff maintenance. I've run it 5 years before and have never had to do any maintenance on it. It might be crunchy as hell but again, no maintenance and the car is still competitive.
But yes, the 3racing gear diff is da bomb with 500k. For guys who think they need more, I would suggest you might have a point and shoot driving style that expect the car to punch out of the corner as in my opinion it's faster to try a different line that can carry more corner speed around a corner and then accelerate and you find the 500k oil to be fine. Just my opinion.
Ivan
I like the MR diff too.
I've not been very lucky with ball diffs. The bell washers wear out after a while and no further tightening the screw/nut helps. I don't use a very tight setting for my driving so it can last a while, but I too prefer gear (oil) diffs.
I recently won the R-Car class at the Kamloops WCICS with a rusty/crunchy tamiya diff in my TA01 - but only because I wanted to prove a point.
It can be done, but it takes more skill and concentration than I am often willing to exert.
I'm not lazy. Just....biased.....towards enhancements, so that I may focus on other matters
