Like Tree170Likes
Old 12-12-2006, 09:26 PM   #2551
minidriver's Avatar
Originally Posted by falconcg
I am having problems programming my TEU-101BK ESC (Tamiya).
When I start it, the light flashes twice and when I click on the setup, then the light flashes non-stop.
What should I do? Is it because I have a old batterie (1500mah NiCd)?
Check to make sure you have it wired correctly. It is not the same as your typical modern ESC. I gave the one I got in my kit (I never actually used it) away to a friend who had the same problem. Turns out that with the Tamiya esc you have to plug that one connector it into the battery slot in your radio receiver to make it work. Most ESC's don't require that, as they have a BEC (battery elimination circuit), but the TEU101BK doesn't, thus the extra connector.
minidriver is offline   Reply With Quote
Old 12-13-2006, 01:02 AM   #2552
Trader Rating: 52 (98%+)
Default what shocks to use
I just bought a used mini, it came w/ blk plastic oil shocks. I am thinking about going to alum shocks. which one should I get? I have a set of 415 shocks but they are very long, can I use that? also which spring do I use, the short or the regular? Thanks
straightaway is offline   Reply With Quote
Old 12-13-2006, 02:52 AM   #2553
Target's Avatar
The black plastic oils should be fine if the are set up correctly, that said i run the trf dampers with 5mm fuel line internally to reduce travel/droop. I also run the short springs to help get the ride height down.
check out http://www.rc-mini.net/MiniWeb1/M03_Race_3.html
Target is offline   Reply With Quote
Old 12-13-2006, 06:04 AM   #2554
minimanintaiwan's Avatar
Code:
2859293
Got a Island wide mini class meet this sunday. must use m03 chassis, 20T pinion, supplied motor (checkout post#2498), and supplied chevron Monster"m" body (knockoff).
Excuse the CDNflag, we are the only two foreigners racing!
Tamiya mini cooper-img_2821.jpg   Tamiya mini cooper-img_2824.jpg   Tamiya mini cooper-img_2825.jpg
minimanintaiwan is offline   Reply With Quote
Old 12-13-2006, 06:05 AM   #2555
Old 12-13-2006, 01:15 PM   #2556
Tim K's Avatar
Cool body!
Which Island? how many mini drivers will turn up?
Tim K is offline   Reply With Quote
Old 12-13-2006, 06:11 PM   #2557
TENCHO's Avatar
which island you ask? minimanintawain....taiwan is the island. I wish i could attend that M03 race event!
TENCHO is offline   Reply With Quote
Old 12-13-2006, 06:18 PM   #2558
Speed Demon's Avatar
Originally Posted by minimanintaiwan
Code:
2859293
Dude,,
What body is that? Any Part# for it?
The body is freakin cool!!!!
CUSTOM CRAWLER & ROCK STACKER
Speed Demon is offline   Reply With Quote
Old 12-13-2006, 07:16 PM   #2559
Target's Avatar
Originally Posted by Speed Demon
Dude,,
chevron Monster "m" body, The only place i have seen them is rainbow ten but they dont have them in stock at the moment.
Steve.
Old 12-13-2006, 08:58 PM   #2560
Steve.
It's actually a locally made/copied version of the Chevron Monster "M" . A RC shop in Taipei had it made for all mini class competitors in upcoming race. In total there will be about 30!! of these Monster "M"s crashing around the course.
TimK: Its on the tiny island country of Taiwan. About 30 mini class entrants
SpeedDemon: Sorry, no part no. Its special made for the race and they dont sell online or overseas.
I'll post pics after the race this weekend.
Old 12-13-2006, 09:12 PM   #2561
Dorigecko's Avatar
Send a message via MSN to Dorigecko
Chevron bodies in my opinion aren't that good in modelling terms. If you were choosing a mini body, I'd suggest something from ABC (http://abchobby.com/abcframeeng/cont/01mini.html).
Dorigecko is offline   Reply With Quote
Old 12-13-2006, 10:04 PM   #2562
anybody knows what kind of modification needed to fit this body to Tamiya M03?
Old 12-13-2006, 10:11 PM   #2563
Scottrik's Avatar
Trader Rating: 244 (100%+)
Reverse the wires to your motor so you can make it RWD.
I'd guess the M04 chassis would be more appropriate.
Scottrik
Scottrik is offline   Reply With Quote
Old 12-13-2006, 10:19 PM   #2564
tony gray's Avatar
M04 is too long....
You'll struggle to get the Corolla Levin onto an M03. The servo mount will hit at the base of the windscreen around the cowl area.
You'd have to cut a hole to let it poke out a bit. Not sure how big a hole but it might end up looking pretty average I'm afraid... And a big risk if you get it wrong..
tony gray is offline   Reply With Quote
Old 12-13-2006, 10:33 PM   #2565
Default M03M clear bodies
Do you guys have any links of places I can buy bodies for the M03M chassis. I live in Canada. I would buy either from Canada, US or Hong Kong. I never bought from Australia so I don't know about shipping and duty fees.
Thanks, Chris.
falconcg is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
