Like Tree198Likes
Old 12-10-2006, 05:57 PM   #2536
Default Programming problems with the TEU-101BK
I am having problems programming my TEU-101BK ESC (Tamiya).
When I start it, the light flashes twice and when I click on the setup, then the light flashes non-stop.
What should I do? Is it because I have a old batterie (1500mah NiCd)?
falconcg is offline   Reply With Quote
Old 12-10-2006, 11:18 PM   #2537
akura2's Avatar
Send a message via AIM to akura2 Send a message via Yahoo to akura2
Originally Posted by tamiyarcracer
The major difference betwen the Miata/Alfa and the Beetle.
Miata is a M04m the Bettle is a M04L (it uses the chassis spacer.) I think that is really all, maybe the tires are different compounds between the kits.
Basically is ts a BMW M Roadster or Honda S2000 with Mini size tires instead of sedan tires.
Thanks... but I was asking what the difference between the M03 and the M04... not the difference between M04m and M04L
anybody?
akura2 is offline   Reply With Quote
Old 12-11-2006, 12:14 AM   #2538
H I
H I's Avatar
Trader Rating: 18 (100%+)
anybody?
M03=FWD M04=RWD
Is that what you wanted to know? I don't think TAMIYA makes Alfa or Beetle in M03, only on M04s.
falconcg, have you got instracion? It's been long time since I used them but I think you:
1. turn radio on
2. turn car on
3. press set up button once with out throttle (light flush)
4. full throttle and press button again (light flush differently)
5. full brake and press button again.
6. switch off car or just drive away.
H I is offline   Reply With Quote
Old 12-11-2006, 12:47 AM   #2539
flying G.E.O.'s Avatar
Originally Posted by sup
sorry for the late reply. i was 8th (i think). i do hope we have more mini races in the future though. anyway, i will drop by to say hi when we have a next mini race. thanks and see you around!
I think there are plans to have races at PS1 next year since the track is really suited for smaller sized rc. Hopefully we can meet again there.
www.3dgallery.co.nr
flying G.E.O. is offline   Reply With Quote
Old 12-11-2006, 02:27 AM   #2540
racenut's Avatar
Trader Rating: 15 (100%+)
Hey GEO, you forgot the TIR track, Best for mini!!!
racenut is offline   Reply With Quote
Old 12-11-2006, 09:29 AM   #2541
Jam-ehz's Avatar
Send a message via ICQ to Jam-ehz
anybody?
The M-04's components are much lower than the 03's. Since the motor is mounted in the rear, that leaves room in the front for the servo to be mounted within the body pointing down, not mounted on top pointing forward.
The design does look much cleaner and lower than the M-03, and in terms of performance, mine basically acts like a touring car with 2WD, but strictly indoors on carpet. Outdoors it can be a handful if it's not a decent surface and you're heavy on the throttle.
Since everything's so low, it also allows for more sportier bodies (Miata, for example) to be mounted.
Tamiya mini cooper-tamiya-m-04m-1.jpg   Tamiya mini cooper-tamiya-m-04m-2.jpg   Tamiya mini cooper-tamiya-m-04m-3.jpg   Tamiya mini cooper-tamiya-m-04m-miata.jpg
-=≡ Tamiya TA05 TRF415MSX F103R M-03R M-04 M-05 ≡=-
-=≡ CRC Carpet Knife 3.2 OFNA LD3 Pro Fastcats Spektrum ׀ווlı ≡=-
Jam-ehz is offline   Reply With Quote
Old 12-11-2006, 11:32 AM   #2542
fraz's Avatar
Send a message via AIM to fraz
Default Diff question
Hey all, I broke down and got a mini. I got the m-03m and something is wrong with the diff. The drive train is free and smooth but the diff action is chunky. Let me elaborate. Take the diff out of the car, insert outdrives, smooth as silk. Put diff in car, tighten chassis halves, and the diff is nearly locked up. Loosen the chassis screws a bit and there is some diff action but it is not great. Looking for thoughts and suggestions.
Now that I have typed this, I have a funny feeling one of the case bearings to support the outdrives isn't seated completely. I'll check tonight.
fraz is offline   Reply With Quote
Old 12-11-2006, 12:00 PM   #2543
AdrianM's Avatar
Fraz - Take your chassis halves apart and really press your diff output bearings into the chassis halves. They can take a bit of force to make them seat all the way in. I bet thats it.
Adrian Martinez
Old 12-11-2006, 02:38 PM   #2544
Thanks H I but I have tried everything in the manual and the ESC still doesn't work. The light flashes non-stop even when finished programming. Maybe the ESC is defective or something like that. I'll try to get a hand on another cyclone (that's what I have in my FK'04). Those Novaks are problem free ESCs.
Old 12-12-2006, 02:26 AM   #2545
minimanintaiwan's Avatar
Default shims
hi all, anyone know how many mm shim set i need to get rid of the slop between wheels and hub carrier? M03M. I beleive its 5mm, please corrrect if im wrong.
Also what aluminum servo stays can be used? Can I use the short ones (53596).?
minimanintaiwan is offline   Reply With Quote
Old 12-12-2006, 06:49 AM   #2546
AdrianM's Avatar
Take Off TT302 is a set of 5mm ID shims. You get 10 ea. in 0.1mm, 0.2mm and 0.3mm for $5.99.
I also used the thick wheel hub crush sleeves out of Schumacher U2153 ($8.99) parts bag plus one 0.2mm shim inside each of the front and rear hubs. This makes it impossible to overtighten the wheels and bind the bearings.
I am sure Tamiya makes a crush sleeve that would work too...I just don't have them handy...lol!
Adrian Martinez
Old 12-12-2006, 03:49 PM   #2547
Thanks but was looking for a tamiya hopup part. Something i can get locally. (Taiwan)
Old 12-12-2006, 04:45 PM   #2548
TENCHO's Avatar
minimanintaiwan....use the TG10 aluminum servo posts. They are a little bit longer and will work better on the M03. if you use short ones, you will have to use spacers to fill the gaps....trust me.
see http://minirally.cool.ne.jp for a good picture
TENCHO is offline   Reply With Quote
Old 12-12-2006, 05:19 PM   #2549
fraz's Avatar
Thanks Adrian. My hunch and yours were correct. One of the bearings needed some tough love to seat properly. Now all is silky smooth.
That reminds me, I need to holler at you about a Keyence case issue.... YGPM in a couple minutes.
Old 12-12-2006, 05:32 PM   #2550
AdrianM's Avatar
No problem. If you cant find what you need Take Off is a Japanese company and have distributers all over the place in your area.
Adrian Martinez
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
