Like Tree4Likes
Old 02-22-2005, 06:24 AM   #241
Trader Rating: 111 (100%+)
TTT
dragracer72nova is online now   Reply With Quote
Old 02-23-2005, 01:55 AM   #242
rayman's Avatar
Hi guys, my mo3 keeps rolling over when i installed a type s and 20t pinion. any suggestions? i have low friction shocks and use light blue springs rear and light yellow front with medium oil. they're not the super stiff onroad springs.
rayman is offline   Reply With Quote
Old 02-23-2005, 05:59 AM   #243
Much stiffer springs on front, soft springs on rear, use orings on the shock shafts (inside the shock) to reduce droop.
Check www.tamiyausa.com for their m03L article. Its not an m03 but its good advice.
MartynD is offline   Reply With Quote
Old 02-23-2005, 06:26 AM   #244
1fastdude's Avatar
Trader Rating: 15 (100%+)
Were is the article on Tamiya's website??????
Team Horizon-Team Spektrum-Tekno-Kyosho*B-FAST R/C Performance*TQ Racing Wire Products-TNT-FX.COM-Avid RC-Dynamite-*AKA*92Zero Design*
1fastdude is offline   Reply With Quote
Old 02-23-2005, 08:31 AM   #245
Turbo Joe's Avatar
Trader Rating: 41 (100%+)
Here is a link to the "articles" page...scroll down the "BMW Mini" article.
Turbo Joe is offline   Reply With Quote
Old 03-08-2005, 03:18 AM   #246
ttt
grahame is offline   Reply With Quote
Old 03-09-2005, 04:54 PM   #247
snopro31's Avatar
Trader Rating: 36 (100%+)
Wow lots of great info in here. i cant wait to run mini now.
snopro31 is offline   Reply With Quote
Old 03-10-2005, 06:50 PM   #248
sup
sup's Avatar
just built mine last week and been running for two days now with just the ball bearings as the hop up. so far, it really handles well. would do better with the car lower and oil dampers.
sup is offline   Reply With Quote
Old 03-15-2005, 12:02 PM   #249
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
im sure someone has experimented with the MO4M with sedan tires.... i know the big tires are limited to the 17T for TCS, but do they make up for it?
i just like the looks of the Alfa, and would like to run it in Memphis... but that track is usually quite large, so gearing would def be a factor....
if not, i guess its back to the MO3!
anyone know the internal ratio of these chassis? David W.? i figure if anyone knew, it would be you!
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 03-15-2005, 12:21 PM   #250
Turbo--2 weeks ago we ran a Miata with the 24mm tires on it for an Enduro. As a disclaimer up front there is no way that it will make TCS legal.
That said the car was dialed we also ran a 21T pinion to try to get our rollout equal with the sedans we raced with.
As for TCS you will have to run the 19T pinion with the 60D tires and the 17T with the 26mm tires. If the track is tightened up at all the 04M will come back in terms of value but if it is wide open then you will have to run the 03 or 03L.
Hey Dave sorry just saw the thread pop up to the top again. Looks like we are going to have a Mini revival this weekend in Vancouver for the TCS there. Troy is going up, myself and Tom from Borgfeldt should be fun. I wish I could business is just too crazy I am having a hard time just to get to club races let alone think about any big races.
UF1 Seattle - SPEEDWERKES - VBC Racing - Team ORCA
Difuser is offline   Reply With Quote
Old 03-15-2005, 01:27 PM   #251
Turbonium's Avatar
true.. i was kinda hoping with the 17T/big 26mm sedan tires it might even out, but i wasnt sure. i have the Boxster and BMW M bodies, so they would be legal on the 26mm's.
i will probably take both anyway, just in case.
any setup tips for a parking lot surface on the 04? shock and spring, mainly, for a good starting point.
thanks for the gearing help!!!
Wes
Wes
Team Novak
Old 03-15-2005, 01:58 PM   #252
just a few questions about the tyres,
on a outdoor track with stock standard mini (with swaybars),
which of the following tyres (or a combination of them) provides the best performance?
#50683 60D Radial
#50684 60D M-Grip Radial
#53254 60D S-Grip Radial
#53340 60D Type-A Slick
I'm using M-grip at front and S grip at rear and the car handles quite well. I was told if i use something more sticky at front the car will flip easily at corners.
How's the Type-A slick compare with the S-Grip? which one is more grippy? and does the Type-A last longer the S-grip?
yellow15 is offline   Reply With Quote
Old 03-15-2005, 02:02 PM   #253
Turbonium's Avatar
true... if you run too soft a front tire, they will flip if the traction is high.
if i remember right, the Type A slick is slightly smaller in diameter than the treaded stuff.....
Wes
Team Novak
Old 03-15-2005, 02:12 PM   #254
yes... so yeah i need some people here to tell me what you can run on a stock mini (with stock shocks at standard height, silver swaybars front and rear) that gives you max traction without flipping at corners.
Oh the slick is smaller in diameter? then it's no good for me as we can't change the gearing and i don't want to lose the top speed.
Can anyone confirms this?
Old 03-15-2005, 02:20 PM   #255
Turbonium's Avatar
well, i do know that the Type A slick is smaller than the kit treaded tires, for sure.
what kind of surface are you running on?
Wes
Team Novak
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 05:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-02-2011 12:08 AM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 09:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 07:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 08:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
shmit 1
