Like Tree198Likes
Old 01-21-2015, 04:28 AM   #22711
DesJardins's Avatar
Originally Posted by DesJardins View Post
I see the TRF Works Damper Set for M-chassis(#84318) is showing Discontinued through Tamiya USA... Is there an updated set or what are people switching to?
Just wanted to post back that it's Tamiya #54000 incase others are looking
Tamiya: M-05 v2 Pro
All Spektrum, Tekin, Savox, Orion & ProgressiveRC
DesJardins is offline   Reply With Quote
Old 01-21-2015, 09:04 AM   #22712
madjack's Avatar
Trader Rating: 20 (100%+)
Send a message via Yahoo to madjack
Post Kill Shot
OK Mini junkies, for those running the killshot in 21.5 mini TCS applications, have you found the Kill Shot 21.5T (High RPM) or the combo of the Kill Shot High Torque (21.5T) with the 12.3 high RPM rotor to be more effective with TCS rules?
madjack is offline   Reply With Quote
Old 01-21-2015, 10:29 PM   #22713
hello
i have a mini m-05 spec pro (not much info on this older chassis)
and looking for some setup on carpet help/tips
this is what i have so far?
I will be running 40wgt oil in the shocks
im sure it has kit springs (white springs with yellow&blue) not sure what gos where
cf front shock mount. stand the front shocks straight up and down?
lean rear shock in?
put a little putty in dif? or sticky tack?how much?
it has a aluminum 3deg rear block ...good or bad?
the aluminum motor counter weight ...good bad?
on of my fellow races said to add 30 graming in the front bumper...would i still do that with all this extra aluminum
im thinkingh of ordering swaybars for it
anyways any more help would be great
thanks
TeamThibault is offline   Reply With Quote
Old 01-22-2015, 11:43 AM   #22714
DesJardins's Avatar
Only regret was not ordering the Aluninum Battery Mounts for the shorty Lipo
Tamiya: M-05 v2 Pro
Old 01-22-2015, 01:30 PM   #22715
madjack's Avatar
Cool
anyone... Bueller... Bueller...
Old 01-22-2015, 03:48 PM   #22716
DesJardins's Avatar
Tamiya: Aluminum Racing Steering Set
Tamiya: Aluminum Steering Link
Tamiya: Touring Car Tuned Spring Set (Short)
Tamiya: M-05 v2 Pro
Old 01-22-2015, 04:05 PM   #22717
monkeyracing's Avatar
Only regret was not getting the lightweight aluminum battery holders right away to run a shorty pack without cutting the stock tabs.]
Nice, clean stock bui...HEY! GRASS! It's like you live on a golf course and I'm on ice planet Hoth.
monkeyracing is offline   Reply With Quote
Old 01-23-2015, 06:04 AM   #22718
KA2AEV's Avatar
What? No Tauntauns to keep you warm?
Hauler Driver, Liason, Lead Mechanic, Crew Chief, Procurement Specialist,
Conflict Resolution Specialist, Pychologist, Therapist All for Team Golddust Racing
Oh and By The Way
NBCsn and FxSports cable is growing on me too!
KA2AEV is offline   Reply With Quote
Old 01-23-2015, 08:17 AM   #22719
eR1c's Avatar
Not sure about your Kill shot question. I'll be running a kill shot 21.5 high rpm this coming season ...so will know more but not for a few months at least.
eR1c is offline   Reply With Quote
Old 01-23-2015, 02:23 PM   #22720
DesJardins's Avatar
Haha, I'm loving the artificial turf in the backyard!
No yard work for this guy ;0)
The Spektrum SR2000 DSMR Micro Race Rx is a perfect fit
Tamiya: M-05 v2 Pro
Old 01-24-2015, 03:26 PM   #22721
DesJardins's Avatar
Tamiya Aluminum shocks installed & really dropped the ride height!
One ridiculous thing is the fact that the ball mounts for these upgrade shocks were threaded completely different... Good job Tamiya
Tamiya: M-05 v2 Pro
Old 01-25-2015, 10:38 AM   #22722
marcos graveyar's Avatar
Send a message via AIM to marcos graveyar
Did you build the shocks with the spacers as per V1 or without as per V2.
marcos graveyar is offline   Reply With Quote
Old 01-25-2015, 11:07 AM   #22723
DesJardins's Avatar
I did put the o-ring inside because with the stock shock build the shocks were so long that even the droop screw didn't lower the chassis enough.
It's sitting at about a 6mm ride height now
Tamiya: M-05 v2 Pro
Old 01-26-2015, 01:14 AM   #22724
Are they the 54000 M-Chassis shocks or are they Touring Car shocks ?
What length did you build them to ?
I put a metal spacer/plate between the droop screws and the chassis to stop the screws digging in to the plastic. I made them up from an electric Jig Saw blade, just ground off the teeth and then made them to size. I epoxied them in place.
At least now the droop screw doesn't have to protrude too far through the suspension arm.
I'm running 4.5mm ride height with 3mm of droop on the rear of the car at the moment. 1mm higher at the front.
Old 01-26-2015, 09:16 AM   #22725
DesJardins's Avatar
Yes they are the 54000 M-chassis shocks.
It's sitting at 5mm front & 6mm back with very little droop around 1-1.5mm
I'll check the shock length measurements as those are written down at home
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
