Like Tree81Likes
Old 01-09-2015, 08:26 AM   #22666
Neils74's Avatar
Originally Posted by KA2AEV13771028
Neils, check out the Brownies racing thread on here, the shop is over here in SI just a short hop
Over the Vz and he stocks everything for Tamiya and if he doesn't have it he can get it
We also race right on the beach at Midland Park during the summer
As well as go to a couple of tracks over in Jersey and just over the boarder in Pa
Pm me if you need any more info/help
Mike
Thanks Mike. I'm glad a brick and morter store like Brownies still exists
Neils74 is offline   Reply With Quote
Old 01-09-2015, 08:44 AM   #22667
Neils74's Avatar
Originally Posted by bertrandsv87 View Post
These rims are the best, but you'll need lots of CA glue on the sidewalks to make them slide on the walls rather than catching and breaking... FbF boards are also unforgiving......
Thanks for the tip. Is there a particular CA/superglue that you recommend, that doesn't go brittle and or destroy the rubber etc?
Old 01-11-2015, 07:46 AM   #22668
just bought a new m5 and broke both box factory front wheel axle..2nd one was a very light friction roll ..anyone else run across this
omaharich68 is offline   Reply With Quote
Old 01-11-2015, 09:13 AM   #22669
KA2AEV's Avatar
Was that a new Ver 2 or the standard 05?
Hauler Driver, Liason, Lead Mechanic, Crew Chief, Procurement Specialist,
Conflict Resolution Specialist, Pychologist, Therapist All for Team Golddust Racing
Oh and By The Way
NBCsn and FxSports cable is growing on me too!
KA2AEV is offline   Reply With Quote
Old 01-11-2015, 10:21 AM   #22670
Ver 2
Old 01-12-2015, 02:36 AM   #22671
marcos graveyar's Avatar
Send a message via AIM to marcos graveyar
Have never broken a wheel axle in all the years I've been racing Mini's, I suspect a substandard part, perhaps a call to Tamiya would be worthwhile, especially seeing as both axles broke.
marcos graveyar is offline   Reply With Quote
Old 01-12-2015, 10:51 PM   #22672
monkeyracing's Avatar
I've come to the sudden realization that my M04 needs a 10.5T motor in it. Don't have a class for it, but it needs to happen.
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 01-13-2015, 01:30 PM   #22673
eR1c's Avatar
that will be one fasssssst mini!
eR1c is offline   Reply With Quote
Old 01-13-2015, 02:24 PM   #22674
eR1c's Avatar
I have a quick question,
Our club raced w/ the Tamiya Silvercan motors last season and are switching to 21.5t brushless this season. I thought that the silvercans were typically about 27turn, so I was expecting that switching to 21.5t brushless would be a lot, LOT quicker. I haven't had a chance to actually drive my car as I just installed the electronics last night (and am at work today). Giving my car full throttle the front wheels didn't seem to balloon up like I was anticipating (the way I see them on my 1/10th touring car and SCTruck). The wheels seem to spin only mildly faster to me. Granted I get that my TC car is running 17.5 w/ higher gearing and my SCT ..well that is a beast. But was maybe expecting a little more? Also I don't free rev my cars typically, this was during setup where it is required to full throttle forward, reverse etc w/ the esc I have (for calibrating).
I realize that the gearing on the Minis is fixed and thus your not going to get crazy top end speeds, but does this sound correct that a 21.5t is mildly faster than a stock silvercan? ...just wondering if I need to go through and check all my controller settings, esc setting and/or adjust the timing on my motor, etc to find where speed may be not at full potential. ...although everything seemed dialed in from what I recall last night.
Old 01-13-2015, 02:31 PM   #22675
Wade....'s Avatar
Yea sounds about right. Jack the timing to get max speed and reduce the torque.
Wade Huesman, TCORC Secretary/Pencil Pusher
Wade.... is offline   Reply With Quote
Old 01-13-2015, 02:33 PM   #22676
eR1c's Avatar
Thanks Wade,
...just wanted/needed a sanity check before I go out w/ this setup and start the new season in a few months.
Yeah, i plan on adjusting the timing (if rules allow, not sure that I can do much w/ the ESC ...as we have to run it stock -but will check it out).
Old 01-13-2015, 02:49 PM   #22677
Turns between brushed and brushless don't really translate. There are wires and magnets, but the job is handled differently. A 27t brushed motor is "sort of" equivalent to a 21.5t brushless. Add timing to the BL motor andall bets are off. In almost all cases the brushless will have more torque.
Stab it and steer.
Old 01-13-2015, 03:27 PM   #22678
eR1c's Avatar
Thanks,
This all makes sense. Yes it did seem to have a bit more torque than my brushless ..maybe it was just a feeling I had, but it did appear to move a bit stronger w/ more ooomph.
Old 01-13-2015, 03:59 PM   #22679
OSherman's Avatar
Just out of curiosity, Which BL motor brand did you decide to go with in your mini for the new season?
•KO Propo America
•EXOTEK
OSherman is offline   Reply With Quote
Old 01-13-2015, 05:33 PM   #22680
hispeedguy's Avatar
Trader Rating: 34 (100%+)
We ran the Mini class for the 1st time at our local track (CRC Raceway & Hobbies). Although not a huge class, we had a solid group each week for club races. We allowed either stock silver can OR 21.5 blinky. What we typically found was the 21.5 cars had gobs of torque in the twisty infield but lacked the top end the silver can cars had on the longer straights. In the end, laptimes were about the same.
With that being said, I ran an M06 (rwd) for the 2nd half of the season and that car, with a Tekin Gen2 21.5 had both torque and top end. Mostly due to increased traction w/ motor hanging in back of the rear wheels.
The season is over, so for next year we're planning on allowing either motor combo again.
I must say, I had a great time racing the Mini's. Just plain fun and great scale looks.
Originally Posted by eR1c View Post
Thanks,
www.RCSoup.com www.cowrc.com
hispeedguy is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
fritzthecat
