Like Tree196Likes
Old 12-09-2014, 09:39 PM   #22561
monkeyracing's Avatar
Reading a great magazine review of Tamiya's hot new ride, the M-03L!
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 12-11-2014, 10:52 AM   #22562
firefoxussr's Avatar
Originally Posted by eR1c View Post
I have the Porsche body and an M05, wheelbase is not an issue. I believe there would be no issue w/ the M03 ...my ONLY concern would be the front shocks towers being too tall on the M03?? ...for the HPI Cup Racer (which that Porsche body was made for) the front shocks are in a "lay-down" format to accommodate the lower front end of the Porsche body.
I can verify for you tonight ...going to a friend's house who has an M03 ..will bring my Porsche body and will give more details on fitment.
don't put the HPI Lancia Stratos on whatever you do! LOL so tight on the nose.
Bought a Cup Racer just for that sweet body!
Parking lot heroes: M06, TA05sw, XV01, XRay T1, SC10B
Partially disassembled: HPI Cup Racer, FGX, M04, TA02, TA05 IFS
Newest acquisitions: A210SS Exige, HPI MX-5, Tamiya F40
firefoxussr is offline   Reply With Quote
Old 12-11-2014, 11:29 AM   #22563
Jordan Anderson's Avatar
When building the Tamiya 54000 dampers for an M06, how many O-rings or mm of spacers do you put inside the shock under the piston to limit down travel? Also, how many on the outside to limit up travel?
I know you need to use the longer piston rod for the rears, but the different instructions (M06 pro vs. M06R vs. 54000) seem to vary on travel limiters...
JORDAN // EVAN
R/C GEARS , TRUKZ/KARZ , VRC PRO
Jordan Anderson is offline   Reply With Quote
Old 12-11-2014, 12:31 PM   #22564
axle182's Avatar
Trader Rating: 18 (100%+)
Send a message via MSN to axle182
Jordan I build my front and rear shock, make sure the shock is at full extension, and measure full outside to outside of the ball cups. Then put it on the chassis. Set your ride heights. Now decide whether you want 0/1/2/3mm of droop. I usually run 1mm droop. I then adjust my ride height again to be 1mm higher to simulate the droop height. I re measure the shock outside to outside, and that difference is what I need to install under the piston. Because you will require difference amounts of spacers front to back, its always a good idea to mark them with a sharpy. You only need to do this with ONE front and ONE rear shock.
Id recommend using hard washers or spacers, not the o-rings.
Aaron "AJ" Freind
axle182 is offline   Reply With Quote
Old 12-11-2014, 01:09 PM   #22565
KA2AEV's Avatar
Okay problem!
In my main drivers M05 I had installed a Ball diff awhile ago that was working
great
However
During a recent race right at the hotlaps for the Main, he broke the Dogbone plastic piece that holds the Dogbone in the knuckle for the Ball Diff, basically destroying
the notched part on the ball diff.
Heres the problem, I don't remember which Ball Diff can go into the 05 without
Drilling out the chassis (which I didn't do)
Anyone have any suggestions for a replacement?
I think it may have been the TA03? or something like that!
Mike
Hauler Driver, Liason, Lead Mechanic, Crew Chief, Procurement Specialist,
Conflict Resolution Specialist, Pychologist, Therapist All for Team Golddust Racing
Oh and By The Way
NBCsn and FxSports cable is growing on me too!
KA2AEV is offline   Reply With Quote
Old 12-11-2014, 01:57 PM   #22566
Ok, thanks
JORDAN // EVAN
Old 12-11-2014, 02:16 PM   #22567
axle182's Avatar
Originally Posted by KA2AEV View Post
Okay problem!
great
However
Mike
Yes TA03 will work fine. From memory, all mini diffs fit the 05 and 06. its the 03 that needs mods to fit the 3 racing gear diff.
Aaron "AJ" Freind
Old 12-11-2014, 03:55 PM   #22568
KA2AEV's Avatar
Okay Axle
Thanks for the info
Im kicking myself for forgetting which one we put in there
Now hopefully Tamiya will get off their butts and release the 15' schedule for
the TCS and I can have this fixed before then!
Thanks again
Oh and By The Way
Old 12-11-2014, 07:12 PM   #22569
Customworksking's Avatar
Trader Rating: 73 (100%+)
i miss my cooper
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 12-11-2014, 08:42 PM   #22570
miles514's Avatar
Originally Posted by miles514 View Post
whats the best inserts for 60D s grips on a large medium bite indoor tracks? thanks!
Im asking again...
AE SC10 FT, RC10 Worlds Car, 3Racing Cactus, HPI Rally, Tamiya MF01X Jimny, Tamiya M05 Pro V2, Tamiya group C, Wild Willy 2, CC-01 Bronco, F103 Le Mans, F104Wgp, Subaru Brat, Wild One, Sand Scorcher.
miles514 is offline   Reply With Quote
Old 12-12-2014, 03:14 AM   #22571
marcos graveyar's Avatar
Send a message via AIM to marcos graveyar
On our carpet I use the Spice123 molded insert with the M-Grip or S-Grip tyre.
If i need more rear end grip I'll use the Kawada TUM41S insert.
I glue the sidewalls of the front tyres only.
Hope this helps.
marcos graveyar is online now   Reply With Quote
Old 12-12-2014, 05:47 AM   #22572
Im asking again...
Hi Miles, Tamiya hard sponge.
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
http://www.youtube.com/user/rccartips/
http://www.facebook.com/RCCarTipsFan
rccartips is offline   Reply With Quote
Old 12-12-2014, 06:24 AM   #22573
Rodarbal's Avatar
Trader Rating: 38 (100%+)
Send a message via Yahoo to Rodarbal
In the USVTA forum, rcpaintinpete posted up this little contraption this morning, a rev limiter from GForce:
http://www.redrc.net/2014/12/gforce-...d-controllers/
Coming soon from GForce is the Rev Limiter module to limit the maximum RPM of electric brushless motors. Looped between the motor, controller and receiver the device limits the maximum RPM of sensored brushless motors in four steps between 10,000 and 17,000 RPM. Micro switches and status LEDs help to check the setting, making the module ideal to equalise the performance of brushless motors for entry level and stock racing classes. The 2S LiPo-compatible Rev Limiter comes in a lightweight case, it measures 22x15x10mm and comes pre-wired with universal connectors and including a sensor wire.
If it works, would a lot of clubs take to this device? Would TCS?
RJ Labrador
Off Road Big: Mugen, Mugen & Mugen
Off Road Little: XRay & XRay
Rodarbal is offline   Reply With Quote
Old 12-12-2014, 08:59 AM   #22574
I'm big on spec racing, but I know 10 minutes after it's adoption, someone will claim it's been hacked and that's why they lost.
Old 12-12-2014, 09:23 AM   #22575
axle182's Avatar
Ahh aint that the honest truth of ALL spec racing. You have to get used to the noise from the complainer camp lol. They will complain no matter what. You change the rules for them, they find the next excuse. Sad really. Best to just go with a formula that works, stick to it, keep costs as low as feasible and pretend to listen to the complainers.
Aaron "AJ" Freind
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
marcos graveyar
