Like Tree137Likes
Old 11-28-2014, 03:47 PM   #22516
Pygmy's Avatar
Originally Posted by Jordan Anderson View Post
Is there a picture of the M05 V2 droop screws somewhere? I've looked around, but I can't find an image that shows how the droop screws on the V2 work.
Anyone got a good pic?
This is the best I can do under poor lighting conditions (ceiling light stopped working earlier this evening and camera autofocus is not impressed )
It's a basic droop screw implementation - grub screws that hit the chassis preventing the arm dropping.
Can't really see it in these pics but I've cut 2 pieces of square metal from a coke can and glued them on the plastic chassis where the droop screws hit in the hope that it'll prevent wear a little.
http://i.imgur.com/4q6Nctu.jpg
http://i.imgur.com/5tD6Lkd.jpg
"If it ain't broken, take it apart and see how it works."
LOSI Ten SCTE [ Build : http://bit.ly/VsAulx ]
Pygmy is offline   Reply With Quote
Old 11-28-2014, 05:59 PM   #22517
Jordan Anderson's Avatar
Thanks! Now I see how that's working; different from a touring car. Does the V2 have these droop screws on the both the front and rear arms?
JORDAN // EVAN RC8.2e, B5, B5M, EB48SL, SCT410.3
R/C GEARS , TRUKZ/KARZ , VRC PRO
We're not sponsored, but would recommend:
Team Associated, Tekno, A Main, Action, PM
Futaba, Schelle, Avid, Proline, Lunsford
Jordan Anderson is offline   Reply With Quote
Old 11-28-2014, 11:08 PM   #22518
caltek1's Avatar
Trader Rating: 35 (100%+)
Yes. Front and rear.
caltek1 is offline   Reply With Quote
Old 11-29-2014, 10:22 AM   #22519
marcos graveyar's Avatar
Send a message via AIM to marcos graveyar
Here is what I have done, I found that the droop screw was almost all the way through the suspension arm when the droop was set so I added a piece of metal between the chassis and the droop screw. I found an old Bosch jigsaw blade with the teeth removed and cut to size fitted the bill nicely, this was then epoxied to the chassis.
This is it unloaded:-
And under load :-
The tiewrap is purely a belts and braces thing.
Similar metal pieces were fitted to the front.
marcos graveyar is offline   Reply With Quote
Old 11-30-2014, 08:41 AM   #22520
jcr
Originally Posted by filippimini View Post
This has been answered a number of times. I haven't done it myself, but this is what others have said.
Converting m05 to m05 pro ver2:
- A parts are a direct changeover
- motor mount should also be changed to m05 ver 2 type. (Although some don't bother)
- arms can also be changed to take advantage of the droop adjustments.
- if you want to run a standard square pack but don't want to use tape, m03 C parts can be used to hold the battery. Some small modification is required.
- use a small amount of foam inside the A part of the chassis to help stop the battery moving around.
Hope this helps.
So if I want to convert M05 to M05 V2 I will need technically 58593 but I should also 54606 (lower arms) and 54609 (motor mount)? All the internal gears and screws will fit wth no problem?
How big of a square pack can you run in the V2?
jcr is offline   Reply With Quote
Old 11-30-2014, 10:09 AM   #22521
fresnojay's Avatar
Jcr, I run a 6500 75c full size in my v2. It is heavier than I like but fits fine. Weighs in at about 1352 so I have to put it on a diet at some point.
Jason
fresnojay is offline   Reply With Quote
Old 11-30-2014, 10:31 AM   #22522
Hi, I'm building a M03 reversed (RWD). The wheelbase is 210mm. I was looking at the HPI #7211 Porsche body, but I don't know if it will fit properly. I'm open to suggestions for other 210mm bodies if the Porsche is a no go. Thanks, Don
DLS II is offline   Reply With Quote
Old 11-30-2014, 10:32 AM   #22523
jcr
Jason
what is the battery opening dimensions? Just wondering if my TC batteries will fit.
Old 11-30-2014, 11:21 AM   #22524
fresnojay's Avatar
JCR, They should with no issue. The one in my mini is also the same I run in my TA05. In the TA05 the battery takes up the entire tray. The opening measures 51mmx26mm in the chassis of the V2.
Jason
Tamiya TB-02, Tamiya M-05 V2 Pro, Tamiya TA-05, Tamiya F103,
Old 11-30-2014, 11:26 AM   #22525
jcr
Jason
Thanks, now I really want to consider it at 51mmx26mm that will for sure fit my TC batteries. I hate trying to find stick packs in lipo.
What is the main difference between the motor mount? Debating about getting it or not.
I guess everything else internally is the same?
Old 11-30-2014, 11:52 AM   #22526
sosidge's Avatar
If all you want to do is run a square pack, 54605 A parts is all you need. Bear in mind that if you run a standard servo you will need to find a couple of m3x18 screws. No need for the new motor mount.
I have my doubts over the benefits of the new arms beyond simplicity, I haven't heard anything good about the droop screw implementation and you will need to find loads of hardware to run the droop screws anyway.
Old 11-30-2014, 01:39 PM   #22527
jcr
OK thanks then I'll most likely just get the 54605 Parts. But what is the benefits of the new motor mount? Since I will have the car completely apart I can decide if I want to put it in or not.
Old 11-30-2014, 02:06 PM   #22528
sosidge's Avatar
New motor mount is milled to move the motor inboard by an extra mm or so. Also the heatsink posts mount closer to the chassis compared to the v1.
Old 11-30-2014, 04:24 PM   #22529
monkeyracing's Avatar
So I had a pretty awesome day. A friend had this painted up for me. Great surprise!
monkeyracing is offline   Reply With Quote
Old 11-30-2014, 05:08 PM   #22530
KA2AEV's Avatar
Wayyy too cool Jim
Hauler Driver, Liason, Lead Mechanic, Crew Chief, Procurement Specialist,
Conflict Resolution Specialist, Pychologist, Therapist All for Team Golddust Racing
Oh and By The Way
NBCsn and FxSports cable is growing on me too!
KA2AEV is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
ErikJan
