Like Tree137Likes
Old 11-26-2014, 12:06 PM   #22486
Pygmy's Avatar
I've glued the whole sidewall and that works perfectly.
"If it ain't broken, take it apart and see how it works."
LOSI Ten SCTE [ Build : http://bit.ly/VsAulx ]
Pygmy is offline   Reply With Quote
Old 11-26-2014, 12:35 PM   #22487
OSherman's Avatar
I've glued none of my sidewalls and it works perfectly... (have yet to run my car on carpet)
•KO Propo America
•EXOTEK
OSherman is offline   Reply With Quote
Old 11-26-2014, 05:58 PM   #22488
Default ,
OK I ran my car today with the sweeps, 33 front, entire side wall glued, 25 rear, no glue. 50 weight shock oil front and rear, front shocks on the outer most position. Red rear and yellow front springs, and rear sway bar.
1.5 deg rear toe hubs, 1 deg rear camber. Front has 1 deg toe out, 1-2 deg front camber.
Car wanted to push wide in the corners, I want a little more initial turn in, it did not try to roll once. I am still a little over a full second slower than the fastest guy. I don't know where to find it.
ncpantherfan is offline   Reply With Quote
Old 11-26-2014, 06:28 PM   #22489
anyone tried spool on the M05? its not easy to open the frame , so I hope to get some advise before that huge surgery
aeroace66 is offline   Reply With Quote
Old 11-26-2014, 06:41 PM   #22490
It isn't too bad getting to the gears, I can change a stripped spur in less than 10 min.
If you want to try, pack the diff with play dough. Unlike jbweld, play dough can be removed without damaging any of the gears. I have used a locked diff many times, the biggest difference in you can loose a little steering but imho I think it pulls a little better out of the corners. As pool will put more stress on the gears. If you hit something and the front tires stop suddenly while under power the spur gear can get damaged fairly easily. This is how I got good at changing the spur.
Old 11-26-2014, 07:02 PM   #22491
that's positive, i think when play on carpet lose some steering but fast get out the hairpin is the key, i got the 3racing spool ,just need someone convince me to put it on
Old 11-27-2014, 06:45 AM   #22492
KA2AEV's Avatar
Okay Panther I'm going to go against my best judgement and probably break some rule
On here but I'll tell you exactly how to make up that second against your fast guy.
Practice, practice and practice some more.
That fast guy has been driving awhile at that track and has been doing the
Same thing while you have been tearing your car apart and rebuilding it
Hauler Driver, Liason, Lead Mechanic, Crew Chief, Procurement Specialist,
Conflict Resolution Specialist, Pychologist, Therapist All for Team Golddust Racing
Oh and By The Way
NBCsn and FxSports cable is growing on me too!
KA2AEV is offline   Reply With Quote
Old 11-27-2014, 07:22 AM   #22493
On asphalt I have a setup where my times are very close to everyone, I could stay on the pace and usually finished second. This is my first experience on carpet and when my fast laps are that far off pace I can't help but think it a better setup would get me at least close to his times. I am finishing behind guys I was always faster than on asphalt. I am struggling to find the same comfort and consistency on the rug.
Old 11-27-2014, 07:53 AM   #22494
monkeyracing's Avatar
Has anyone seen Bob (Granpa) recently?
monkeyracing is offline   Reply With Quote
Old 11-27-2014, 08:38 AM   #22495
axle182's Avatar
Trader Rating: 18 (100%+)
Send a message via MSN to axle182
My setups on carpet make the car very nimble/twitchy and aggressive. On carpet, the car that can rotate the fastest and maintain great corner speed will always win. Anyone 'Sweeping' the corner, is loosing time.
Here are my thoughts -
- I haven't tried sweeps, but sounds like you have too much grip in the back and not enough in the front. I run Tamiya tires, S grips both ends, and FULL sauce on all tires, leaving it on longer on the front. Try running a more med tire on the back, and play with softer tires in front.
-I glue from the small rib on the sidewall to about 1-2 mm up onto the edge of the outside tread. I haven't found a need to glue over the entire side wall. FRONT TIRES ONLY
-50 Shock oil isn't bad, I am usually around 35-40 though.
-Play with shock position, I didn't notice much difference with mine.
-Swap springs front to back. I had a lot of success with red front and blue rear. Sometimes I run White rear if the track has good grip.
-Rear Sway Bar - good. Put the harder one on, I think it was the silver one.
-rear Hubs - Good.
-Camber and Toe - Seems about right
Glueing the tires, put minimal amount onto the actual tread. Add a little more, to stop the car from 'bucking' up onto two wheels. If u put on too much, you will loose too much front grip. The super fast cars around here, will buck up onto two wheels a little when driven in anger. Its a very fine line, and ive had to use a dremel with a sanding disk to fix my tires.
We run 3 racing gear diff with 500,000 oil. Lasts forever and has good turn in and drive out of the corners.
Wheelbase - I prefer Med. Long WB takes too long to rotate, and SWB can work well, but a little too sketchy when driven very hard.
Also ensure you have a tonne of steering throw, and minimal bump steer.
Shocks - Play with droop (limiters inside the shock if you don't have the V2!) I run minimal droop on all four corners. And get your ride height down close to the min allowed at your track also.
Hope that helps
Aaron "AJ" Freind
axle182 is offline   Reply With Quote
Old 11-27-2014, 08:41 AM   #22496
Jordan Anderson's Avatar
Originally Posted by Wade.... View Post
Sweeps 36 front 25 rear.
Gotta glue that front side wall too.
Are the Sweeps a lower profile tire and/or do they have a smoother tread to sidewall transition than the Tamiya mini tires?
JORDAN // EVAN RC8.2e, B5, B5M, EB48SL, SCT410.3
R/C GEARS , TRUKZ/KARZ , VRC PRO
We're not sponsored, but would recommend:
Team Associated, Tekno, A Main, Action, PM
Futaba, Schelle, Avid, Proline, Lunsford
Jordan Anderson is offline   Reply With Quote
Old 11-27-2014, 09:31 AM   #22497
do most people use the plastic parts for your speed control and receiver or just put them on directly on the frame sideways..
coolair is offline   Reply With Quote
Old 11-27-2014, 09:33 AM   #22498
axle182's Avatar
Directly to the chassis.
Aaron "AJ" Freind
Old 11-27-2014, 09:45 AM   #22499
Yeah. They're 55mm. Tamiyas are 60mm. 55s corner incredibly well, but you lose some top end.
Old 11-27-2014, 09:50 AM   #22500
received my v2 yesterday..... came with the lwb new style mini body.
will be looking for a med body.. hoew are the crx or crz rated fir racing..?
Also all the tire are glued front and back.. the complete sidewall but nothing on the edge of the tread... can these be used on carpet front and back?
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 7 (0 members and 7 guests)
