Like Tree163Likes
Old 11-24-2014, 01:14 PM   #22471
monkeyracing's Avatar
Here you go, coolair. Their test found the motors to be fairly close, but they noted this may have been a particularly consistent batch. The green dots represent the 20 motors they teted, straight out of the box. The orange dots represent some other motors tested for comparison.
Thanks for the rcmini crew for providing the info and the chart.
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 11-24-2014, 03:26 PM   #22472
I guess it could be worse.....
Just wondering how an other lest sai 21.5 would do .. all from the same company of course...
coolair is offline   Reply With Quote
Old 11-24-2014, 04:10 PM   #22473
What is the fastest tire on carpet?
I have almost every tamiya tire and sweep 36 and 25.
One more question.
I am setting up my play mini for a friend to give it a try. It does not have the adjustable rear camber links. When I set it up with my starting ride height of 5mm front and 4.5 rear, the rear has excessive rear camber. Should I run it like that or raise the ride height to get the rear camber to a reasonable setting?
Racers: M05 race mini, TA06 Pro VTA, 417X 17.5 touring car
Vintage: Frog, Blackfoot, Wild Willy, Lunch Box x 2, M01 Mini x 2, Monster Beetle x 2, Dirt Thrasher, F150 Baja,
Modern: M05 Play mini, Wild Willy 2000, Sand Scorcher
ncpantherfan is offline   Reply With Quote
Old 11-25-2014, 04:47 AM   #22474
Can anything be done to a black can motor to improve performance?
Old 11-25-2014, 12:29 PM   #22475
Wade....'s Avatar
Sweeps 36 front 25 rear.
Gotta glue that front side wall too.
Wade Huesman, TCORC Secretary/Pencil Pusher
Wade.... is offline   Reply With Quote
Old 11-25-2014, 02:25 PM   #22476
Everything that applies to silver can applies to black can. The only difference is a few winds and some black paint.
Stab it and steer.
Old 11-25-2014, 02:49 PM   #22477
OSherman's Avatar
in past experience the black-cans were a lil more delicate to 'tweaks' (meaning that it was easy-er to overdo them). and if i recall correctly the gains were minimal comparatively. never hurts to try tho.. we all did.
•KO Propo America
•EXOTEK
OSherman is offline   Reply With Quote
Old 11-25-2014, 02:54 PM   #22478
Pygmy's Avatar
Originally Posted by Pygmy View Post
Since I'm new to on-road I've got a few questions on my Esc / Motor setup.
Esc used is the Hobbyking HK-Sens-60, motor used is the Turnigy Trackstar 13.5T with adjustable timing.
First off I'm wondering whether or not to use drag brake.
For offroad I never used it, but I think it might be useful here.
Do you guys use drag brake (and if so, how much ?) ?
Then - the motor has adjustable timing (which afaik is fixed across all rpm's), the Esc has adjustable timing (Which if I'm correct is dynamic - the timing advances with the RPM's ?)
I figure setting the timing to high in the Esc would be good - or wouldn't it ?
Also, I happen to have a spare Hobbywing Sct Pro Esc (150A) - quite a different beast than this Hobbyking 60a, but looking at the Turnigy motor specs (Max amp draw 37a) it wouldn't do any good to use the bigger, heavier Hobbbywing instead of the Hobbyking, or would it ?
Noone on help-a-noob duty today ?
"If it ain't broken, take it apart and see how it works."
LOSI Ten SCTE [ Build : http://bit.ly/VsAulx ]
Pygmy is offline   Reply With Quote
Old 11-25-2014, 03:06 PM   #22479
sosidge's Avatar
Problem is you are running a motor and ESC that is not common in Mini racing. So very few people will be in a position to advise.
Old 11-25-2014, 03:27 PM   #22480
I'll bite.
Drag brake is completely personal. Your driving style either works with it or it doesn't. The track layout makes a difference, too. On a tighter track, I'll tend to use a little more, as my hands don't react fast enough sometimes. The downside to drag brake is that if you don't control it properly, you will lose corner speed.
Start with physical timing (on the motor) and see where your temperature goes. Then, if you find you need a little more...something, mess with dynamic timing (on the ESC) and see where the temperature goes. It's best to work with one variable at a time, take notes and repeat.
Stab it and steer.
Old 11-25-2014, 03:38 PM   #22481
Pygmy's Avatar
Thanks.
Right now (no motor timing adjustment, esc timing normal) the motor doesn't get very warm at all. I'm comparing to the hobbywing 3656SD motor of my Short Course though, which gets very hot.
I'll try adjusting the motor timing, see where it gets me, and then optionally move on to esc timing.
Out of curiosity, what are common motors / escs used for the M05 ?
For local races here it's limited to the Carson Cup Machine / Tamiya Torque Tuned motors, brushed...
But since I'm not partaking in races anytime soon - I first just want to learn to drive - I went the fairly cheap brushless way as afaik brushless motors need less / no real maintenance.
Old 11-25-2014, 04:22 PM   #22482
Do you glue the rears at all?
About how far down do you glue, I guess down to the radius where the tread area is?
The sweeps are so low profile, I am surprised they roll over enough to need glue.
Old 11-26-2014, 08:05 AM   #22483
Was thinking the same thing
Do you glue the whole sidewall or about 2mm fromt where the thread starts?
Old 11-26-2014, 08:55 AM   #22484
KA2AEV's Avatar
Just glue the Front tires from from the outside to the first thread notch
and wipe off the excess
Hauler Driver, Liason, Lead Mechanic, Crew Chief, Procurement Specialist,
Conflict Resolution Specialist, Pychologist, Therapist All for Team Golddust Racing
Oh and By The Way
NBCsn and FxSports cable is growing on me too!
KA2AEV is offline   Reply With Quote
Old 11-26-2014, 10:25 AM   #22485
So not really on the sidewall...?
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
