Like Tree104Likes
Old 11-22-2014, 11:15 AM   #22456
firefoxussr's Avatar
Default Was this foolish?
I was cleaning my M05 racer with brakekleen.... and this happened:
It wasn't noticeably broken before.. I don't think at least!
My question is:
did the Brakekleen just out and out melt the plastic parts?
or
did it find any fractures from racing crashes?
Parking lot heroes: M06, TA05sw, XV01, XRay T1, SC10B
Partially disassembled: HPI Cup Racer, FGX, M04, TA02, TA05 IFS
Newest acquisitions: A210SS Exige, HPI MX-5, Tamiya F40
firefoxussr is offline   Reply With Quote
Old 11-22-2014, 02:13 PM   #22457
I have been reading about set ups and I keep seeing talk about sweeps tires. Are people useing sweeps on carpet? I have tried them and I roll the car in every corner if I carry any speed. If they are faster, I will try them again and work on my setup a little more.
I have tried sweeps, m grips, s grips type b slicks, and type a slicks.
I am currently running type b in front and type a in rear, full sauce on front and rear. This is on a M05 V2 with a full size Lipo. I haven't purchased a shortly yet, smc doesn't have the good ones back in stock yet. Car turns in hard, doesn't push through corners and has good pull out as long as I do my part.
Always reading and trying some of the things I learn. This has to be the best car thread on rc tech.
Racers: M05 race mini, TA06 Pro VTA, 417X 17.5 touring car
Vintage: Frog, Blackfoot, Wild Willy, Lunch Box x 2, M01 Mini x 2, Monster Beetle x 2, Dirt Thrasher, F150 Baja,
Modern: M05 Play mini, Wild Willy 2000, Sand Scorcher
ncpantherfan is offline   Reply With Quote
Old 11-22-2014, 04:35 PM   #22458
KA2AEV's Avatar
My question is:
or
That's a real good possibility that the Brakekleen did do it
Why did you spray the entire chassis anyway?
Try getting some scrap plastic that you got and spray it
and see if you get the same reaction
Hauler Driver, Liason, Lead Mechanic, Crew Chief, Procurement Specialist,
Conflict Resolution Specialist, Pychologist, Therapist All for Team Golddust Racing
Oh and By The Way
NBCsn and FxSports cable is growing on me too!
KA2AEV is offline   Reply With Quote
Old 11-22-2014, 04:46 PM   #22459
sosidge's Avatar
Not all brake cleaners are safe on plastic.
Gluing the sidewalls may help.
Old 11-22-2014, 08:03 PM   #22460
monkeyracing's Avatar
I had a black M03 chassis turn whitish/grey and get brittle in spots, after using a cleaner on it. Can't remember which, but it was probably brake cleaner an industrial silicone spray I found at my job. I only use a non-chlorinated brake cleaner now, that claims to be safe on plastics. I still avoid getting it on the chassis though.
Speaking of brittle, anyone else notice how thin the bottom of the 05 V2 is under the gearbox? Hasn't broken, just very thin!
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 11-22-2014, 08:41 PM   #22461
fresnojay's Avatar
Monkey I have and already have a crack in mine. I had horrible luck with my v1 right before regionals this year and is partly why I never made it. Mine is cracked but hanging in there thanks to the bumper. I plan on ordering some replacements here soon once they are state side.
Jason
fresnojay is offline   Reply With Quote
Old 11-23-2014, 02:49 PM   #22462
What is the fastest tire on carpet?
I have almost every tamiya tire and sweep 36 and 25.
One more question.
I am setting up my play mini for a friend to give it a try. It does not have the adjustable rear camber links. When I set it up with my starting ride height of 5mm front and 4.5 rear, the rear has excessive rear camber. Should I run it like that or raise the ride height to get the rear camber to a reasonable setting?
Old 11-23-2014, 05:22 PM   #22463
eR1c's Avatar
The chassis is very brittle ...you really have to be extremely careful what solvents, glues, and greases touch that plastic.
Brake Cleaner can now be added to the list of no no's for the Tamiya plastic chassis.
Also NEVER use any threadlock as it too will make the plastic break apart (i learned the hard way). By the way, I was using threadlock on a metal to metal piece but some of the thread lock seeped onto the plastic ...all it took was a fraction of a drop.
sorry for your lose, yet the good news is a complete chassis can be had for about $12!
eR1c is offline   Reply With Quote
Old 11-24-2014, 04:54 AM   #22464
Originally Posted by OSherman View Post
dont know what your rules are... but i think we are finally realizing that the 'silvercans' and 'blackcans' (sealed brushed motors) have finally come to a crossroads as far as racing goes... the performance and stress that todays cars and batteries are trying to achieve are just not friendly to such motors. put a 21.5 brushless motor in there and you will rarely 'need' a fan (i can only speak for asphalt racing) but i would imagine one fan pointing at the endbell should be more than enough cooling effort..
On my old V1 i would run a novack balistic 17.5 and it was way slower thant the black can...
coolair is offline   Reply With Quote
Old 11-24-2014, 05:00 AM   #22465
Pygmy's Avatar
Isn't that just a case of taking your black can's RPM, dividing that by your battery's voltage to give you the kV of the brushless motor you need to match the speed ?
"If it ain't broken, take it apart and see how it works."
LOSI Ten SCTE [ Build : http://bit.ly/VsAulx ]
Pygmy is offline   Reply With Quote
Old 11-24-2014, 09:02 AM   #22466
OSherman's Avatar
crank the timing on the Ballistic... it will come alive. altho, ive heard that particular motor may not be the best brushless choice for minis.
•KO Propo America
•EXOTEK
OSherman is offline   Reply With Quote
Old 11-24-2014, 09:27 AM   #22467
for now will keep the black can as every one else is running the same motor...cant say lost cus the motor isnt as fast..
win or loose will be due to setup and the driver..
Old 11-24-2014, 09:41 AM   #22468
I guess you never saw the rcmini black can comparison chart. They're rather variable from one to the next. I can post it, if you'd like.
Old 11-24-2014, 10:04 AM   #22469
The moore i read the moore smarter I is...
is there a maintenance or any way to get the best performance from these motors?
Old 11-24-2014, 11:54 AM   #22470
I was only cleaning a nook out that was full of debris and grease. Sprayed more than I thought. Anyway curiously the parts I had replaced were not affected. The original ones did. This is a second hand car, perhaps it was crashed before my ownership too. Either way its just 2 parts racks...a whole $12 to repair :-)
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
pyro18t
