Like Tree137Likes
Old 11-16-2014, 09:58 PM   #22381
niznai's Avatar
Or use some heatshrink over the joint if space allows.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 11-16-2014, 10:02 PM   #22382
fresnojay's Avatar
Wasted post.
Tamiya TB-02, Tamiya M-05 V2 Pro, Tamiya TA-05, Tamiya F103,
fresnojay is offline   Reply With Quote
Old 11-17-2014, 12:14 AM   #22383
Originally Posted by Pygmy View Post
Last friday somebody crashed into my car and suddenly I saw my rear wheel flying away.
It came loose with the axle *and* the two ball bearings, meaning somehow it pulled the rear bearing straight through the plastic rear hub.
Installed it again and it seems fine, but I'm kind of worried my wheel can come loose again - if it managed to pull through the plastic once it could happen again, right ?
Has this happened to anybody else or is this a once in a lifetime thing ?
(Or to rephrase - would this be the moment to buy the aluminum upgrade ? )
It happened to my son's car. I just replaced the rear upright with a new plastic one as it would almost certainly happen again at some point (the only aluminium on my M05 is the steering linkage).
tonybod is offline   Reply With Quote
Old 11-17-2014, 12:40 AM   #22384
Hi all,
Did anyone save the info from rc-mini.net before the site was taken down? It was good stuff and I'd love to find a copy.
Ryan
Ryan
Tamiya M05
Spec-R S1
filippimini is offline   Reply With Quote
Old 11-17-2014, 01:01 AM   #22385
Hi guys,
I'm considering an M-05, plenty of info here, but I have one question. I do not want the Pro II. I have all hop ups to make the regular 5 into a Pro II. But can I buy the central chassis parts of the Pro II and fit them to a regular 5, so a hard case (not stick pack) lipo will fit? A Mini at Banzai doesn't brake the bank, and with this mod I'd be able to use my racing packs.
Cheers,
Hugo
HugoW is offline   Reply With Quote
Old 11-17-2014, 01:39 AM   #22386
Originally Posted by HugoW View Post
Hi guys,
Cheers,
Hugo
In theory yes you can, but in reality the parts haven't been released yet. Someone here previously mentioned mid Nobember, but nothing yet. I also plan to change my 05 chassis.
Old 11-17-2014, 01:41 AM   #22387
Ah, that expains why I cannot find the manual on-line, yet, either.
Cheers,
Hugo
Old 11-17-2014, 01:52 AM   #22388
Is this what you're looking for?
http://www.tamiyausa.com/pdf/manuals/58593ml.pdf
Old 11-17-2014, 01:56 AM   #22389
Yes, it is. Unfortunately, the A parts in that manual are not part numbered. They do seem interchangeble with the regular A parts, 51389, looking at the pictures...
[EDIT] I think the motor mount is different, too, since it's not part numbered in the V2 Pro manual [/EDIT]
Anyone tried (and succeeded) to just cut the regular M-05 chassis to fit a lipo??
Hugo
Old 11-17-2014, 02:29 AM   #22390
Yes, motor mount mount is different. There is a ver2 motor mount. By the way, I'm looking for new shocks, will it be better to get the TRF short shocks or just get the mini shock #5400?
faifaisalfal is offline   Reply With Quote
Old 11-17-2014, 02:31 AM   #22391
TRF are the best, I heard, I have 50746.
Hugo
Old 11-17-2014, 08:51 AM   #22392
EricP's Avatar
Hi guys,
Cheers,
Hugo
This has been discussed over and over again. The only changes made were the 'main' chassis, the motor mount and the arms (and their supporting parts: spacers, different hinge pin screws, etc). Almost every other item is the same, including the steering components and the part tree which includes the rear chassis upper support pieces. Sure, you can 'convert' with the parts. Do i think its worth the trouble: not really...
For those that are interested and want spares, the 7-digit spares for the chassis and arms are on our site. The official 5-digits spares and motor mount have yet to be released.
http://www.tamiyausa.com/items/radio...-58593-0008305
http://www.tamiyausa.com/items/radio...-58593-9115399
Tea Ay Em Eye Why Ay
EricP is offline   Reply With Quote
Old 11-17-2014, 09:58 AM   #22393
monkeyracing's Avatar
You can use the old motor mount. (Though you may need to leave out the 1.6mm spacer behind the spur) All you really need are the chassis parts, lower arms and rear hinge pins.
I'm hoping to see parts soon. I need spares!
EDIT: Chassis and other spares are showing up on rcmart, stellamodels and a few other sites now. Less than $9 for the A parts. Not bad!
monkeyracing is offline   Reply With Quote
Old 11-17-2014, 10:07 AM   #22394
Is there a source for the two long screws that hold the rear lower suspension to the chassis on the M03? (No idea what the right term for it is)
I ran my M03 in snow last winter and the snow + residual water for a full year ended up rusting both of my screws to the point of seizing the suspension. Even WD40 couldn't fix it. I can't seem to find a good source for replacements, and am feeling stupid for selling of my pair of spare chassis earlier this year.
Thanks for the help!
pizzaboy192 is offline   Reply With Quote
Old 11-17-2014, 12:46 PM   #22395
Google "Tamiya 98065976". Lots available.
Stab it and steer.
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
