Like Tree198Likes
Old 11-15-2014, 01:25 AM   #22366
sosidge's Avatar
Simplest solution is to choose one set of the Tamiya springs to work with and build your setup around them. I use the short blacks, so even though they are a different winding to other springs, I know which are harder and softer.
Old 11-15-2014, 06:41 AM   #22367
KA2AEV's Avatar
I know this is way off topic for this but does anyone run gt-3 in the tcs on here
I'll take it off the list if anyone can answer my quick question
Mike
Hauler Driver, Liason, Lead Mechanic, Crew Chief, Procurement Specialist,
Conflict Resolution Specialist, Pychologist, Therapist All for Team Golddust Racing
Oh and By The Way
NBCsn and FxSports cable is growing on me too!
KA2AEV is offline   Reply With Quote
Old 11-15-2014, 09:26 AM   #22368
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Mike
Mike - shoot me a pm or email and I'll see what I can do to help you out
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 11-15-2014, 01:21 PM   #22369
might change to the M06.. but i read that ithas a lot of understeer...
coolair is offline   Reply With Quote
Old 11-15-2014, 03:10 PM   #22370
kwkride's Avatar
Mine is pretty well balanced. Being correct wheel drive, you are better off with a little understeer than oversteer though.
Jim
"If God had meant for us to drive through the front wheels, he never would have allowed us to invent the ring & pinion"
kwkride is offline   Reply With Quote
Old 11-15-2014, 06:26 PM   #22371
Any weight added in the frontor anywhere else?
Old 11-15-2014, 07:23 PM   #22372
kwkride's Avatar
Any weight added in the front or anywhere else?
I wasn't talking weight balanced. I guess I should have said neutral handling. It's definitely heavier in the rear. Mine is the M06R and the kit came with some weights that are on the rear axle.
Jim
Old 11-15-2014, 10:55 PM   #22373
fresnojay's Avatar
Had the first run on my new V2 and oh God what was I thinking. I tried some ideas and I paid for it. Time now to pull out the old V1 setup sheet and start with a setup that does work.
Jason
Tamiya TB-02, Tamiya M-05 V2 Pro, Tamiya TA-05, Tamiya F103,
fresnojay is offline   Reply With Quote
Old 11-16-2014, 06:27 AM   #22374
monkeyracing's Avatar
Setup is the same v1 to v2. It's just accomplished a little differently - droop screws instead of internal shock spacers, for example. Running a short pack is what makes the difference and makes the setup work better.
monkeyracing is offline   Reply With Quote
Old 11-16-2014, 02:07 PM   #22375
Pygmy's Avatar
Last friday somebody crashed into my car and suddenly I saw my rear wheel flying away.
It came loose with the axle *and* the two ball bearings, meaning somehow it pulled the rear bearing straight through the plastic rear hub.
Installed it again and it seems fine, but I'm kind of worried my wheel can come loose again - if it managed to pull through the plastic once it could happen again, right ?
Has this happened to anybody else or is this a once in a lifetime thing ?
(Or to rephrase - would this be the moment to buy the aluminum upgrade ? )
"If it ain't broken, take it apart and see how it works."
LOSI Ten SCTE [ Build : http://bit.ly/VsAulx ]
Pygmy is offline   Reply With Quote
Old 11-16-2014, 02:29 PM   #22376
Pygmy's Avatar
Oh and for other beginners like me who just start reading this thread :
I built the kit M05 Pro V2, put in on the carpet and in almost every corner the rear would spin out / break loose to put me in a nice 180 / 360.
I thought I'd need to fix that by buying / using tire traction compound on the rear and/or using less droop on the rear.
People at the track told me the first thing I needed to do was actually to put CA-glue on the side wall of the front tires - a lot, right up until where the tire goes completely horizontal.
Somehow this wasn't very intuitive to me - I figured I had a problem with the rear, so how was glue on the front tires going to fix my spin-outs ?
So they convinced me to use their glued tires just to try it out - and boy was I convinced immediately - suddenly I could actually drive complete laps without any spins or oversteer !
Theory as was explained to me is that it took just enough traction away from the front wheels while cornering, that the rear doesn't need to break out. But enough traction left to actually take the corners.
I assume the experienced drivers here will probably correct anything in this post if I'm wrong, but all I want to say is -
if you have problems with the rear breaking loose while cornering, try gluing your front tire-walls before you try anything more expensive / difficult
Old 11-16-2014, 03:42 PM   #22377
fresnojay's Avatar
Pygmy, it's funny you posted this as this is exactly what I dealt with yesterday at the track. Interesting but does follow the typical mini train of thinking. Everything that seems counter intuitive seems to be what works.
Jason
Old 11-16-2014, 05:54 PM   #22378
Well, after screwing up my 3Racing diff while rebuilding it last week, I decided to chuck a Tech Racing spool in my M05. It disintegrated during my first heat on Saturday morning. I threw in a fresh, properly built TA03 ball diff. It lasted beautifully through 3 more qualies, but gave up the ghost during the mains this afternoon. I still managed a 3rd place in the B, with one wheel "sort of" drive! It's a bad week to be a differential near me.
So, got home and got a totally unrelated idea: What do you do with your old hard case, stick pack lipos when they're no good anymore? I usually pop them open, soak the innards in salt water for a few weeks and keep the shell. I can't stand the idea of throwing them out for some reason. Anyway, I needed a power distribution block and I've got all these binding posts and bits of copper hanging around, so I made what i needed. I'll probably replace the binding posts with something that can handle more power soon, but it's not bad for a first try.
Old 11-16-2014, 06:51 PM   #22379
fresnojay's Avatar
Monkey, Glad I am not the only one that had that problem this weekend. That was my other issue with the V2 yesterday. My puttied gear diff went from locked up proper to feeling like a normal gear diff then back again off and on all day. So that too is on the list of things to take care of on the new car.
Jason
P.S. How did the TA03 diff give out?
Old 11-16-2014, 07:51 PM   #22380
Just took it out. Diff is fine. The pin in the CVD joint gave up, gave the dog bone room to move and the outdrive slid out. I guess the notched CVD pins are only bulletproof if you make sure they stay tightened down. My bad! Too much fun, not enough attention to detail.
Stab it and steer.
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
