Like Tree200Likes
Old 11-12-2014, 09:24 PM   #22351
I have a question about springs.
I have the short white springs that come with the trf kit. The ones with a red, yellow or blue dot on them. Are these different to the all red, yellow or blue? What other springs are there, if any?
Ryan
Ryan
Tamiya M05
Spec-R S1
filippimini is offline   Reply With Quote
Old 11-13-2014, 12:38 AM   #22352
monkeyracing's Avatar
Ryan
The rule of thumb with Tamiya springs is
red = soft,
yellow = medium,
blue = hard.
They've made springs that are white with dots of colour, black with dots of color, or solidly coloured. Generally, the springs that are shorter, like the ones you have. are about the same and very good quality.
Tamiya also made a slightly longer, fluorescent coloured set of springs for the mini. They are always on the softer side compared to the other sets.
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 11-13-2014, 03:46 AM   #22353
So to clarify;
White with a yellow dot would be the same as black with a yellow dot which would be the same as solid yellow?
Ryan
Ryan
Tamiya M05
Spec-R S1
Old 11-13-2014, 10:20 AM   #22354
Raman's Avatar
Trader Rating: 56 (100%+)
So to clarify;
Ryan
So long as the springs are the same height, the short White with dot, short black with dot, are the same as the fluorescent short.
The idea behind the White with dot etc is to make it harder for your competition to know what you're running.
Raman is offline   Reply With Quote
Old 11-13-2014, 11:14 AM   #22355
fresnojay's Avatar
I thought each type was a different compression rate all together? I have seen many say that white w/dot then followed solid color then by black w/dot. I can say by looking at the white w/dot and black w/dot that the wire thicknesses are different which would in all my other hobby experiences means different compressing rates.
So this sound right or no?
Jason
fresnojay is offline   Reply With Quote
Old 11-13-2014, 05:18 PM   #22356
Raman's Avatar
Jason
Keep in mind the White with dot and fluorescent have paint on them, where as the 42168 black with dot seem to be anodised. That will change the thickness of the wire. Also the black 42168 are slightly longer than the other short springs. They're labelled short touring springs.
I don't know of any other black short springs with dot. If you do, please post part number
Old 11-13-2014, 07:07 PM   #22357
mick355's Avatar
Trader Rating: 14 (100%+)
Guys. Here is what I've found. There is quite a difference.
Hope it's useful
Yokomo BD7'2015 Bmax2MR Factory Edition
Tamiya M05
Bezerk RC Chassis, Hobbywing, Futaba
**BRCCC www.brccc.org**
mick355 is offline   Reply With Quote
Old 11-13-2014, 08:43 PM   #22358
fresnojay's Avatar
The 42168 are the ones I am referring to. The ones I have appear to be painted just like the others. Here is a side by side pic of all 3 types of red springs. The Flouro red came with my 54000 shocks and the white/red came with my v2 pro.
Old 11-13-2014, 10:06 PM   #22359
Laguna Bozo's Avatar
3 Tamiya red springs. 3 different lengths. 3 different compression rates. Gotta love Mini racing!
Craig Richter
Laguna Bozo is online now   Reply With Quote
Old 11-14-2014, 01:49 AM   #22360
marcos graveyar's Avatar
Send a message via AIM to marcos graveyar
Spring rate comparison chart.
http://www.petitrc.com/reglages/1-10...ingChartv2.pdf
marcos graveyar is offline   Reply With Quote
Old 11-14-2014, 03:04 AM   #22361
caltek1's Avatar
Trader Rating: 36 (100%+)
Ride also make M chassis size springs which are black with red, yellow and blue dots similar to the Tamiya springs with a different compression rate.
caltek1 is offline   Reply With Quote
Old 11-14-2014, 08:14 AM   #22362
eR1c's Avatar
HA, -this has frustrated me in the past too.
eR1c is offline   Reply With Quote
Old 11-14-2014, 09:11 AM   #22363
Raman's Avatar
The 42168 are labelled short TC springs. As you can see they are slightly taller than the mini springs and shorter than standard tc springs.
The flourescent red in your picture appears to be a standard tc length spring. I own the flourescent red shorts, and theyre the same height as the White with dot
Old 11-14-2014, 03:58 PM   #22364
fresnojay's Avatar
It is the same size as the blacks. They came with the Ted 54000 mini shocks. I also have a set of the white with red dot the same length that also came on those shocks.
Jason
Tamiya TB-02, Tamiya M-05 V2 Pro, Tamiya TA-05, Tamiya F103,
Old 11-14-2014, 05:12 PM   #22365
Thanks guys, so we agree that they are all different, but we still don't seem to be any clearer on how they compare. I wish tamiya had this info available.
Ryan
Tamiya M05
Spec-R S1
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
