Like Tree81Likes
Old 10-13-2014, 11:53 PM   #22216
monkeyracing's Avatar
Originally Posted by Madulla View Post
Jim you can use 3racing Sakura Zero diff parts/rebuild kits
Ordered a few replacement bits and the hardened outdrives, too. Thanks.
Originally Posted by niznai View Post
Sort of. The Xray outdrives are 7mm id whereas everybody else has 6. That is because their driveshafts have a 7mm ball end, hence the blades are a bit larger and may slide around on the Tamiya ball ends.
You're right. They do have a little play in them. Best I could find locally, though. Waiting on the mailman to bring me the good stuff.
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 10-15-2014, 01:04 PM   #22217
How is everyone mounting motor fans on their m05 v2? It seems to run a little warmer than the v1.
Racers: M05 race mini, TA06 Pro VTA, 417X 17.5 touring car
Vintage: Frog, Blackfoot, Wild Willy, Lunch Box x 2, M01 Mini x 2, Monster Beetle x 2, Dirt Thrasher, F150 Baja,
Modern: M05 Play mini, Wild Willy 2000, Sand Scorcher
ncpantherfan is offline   Reply With Quote
Old 10-15-2014, 01:35 PM   #22218
bd581's Avatar
Originally Posted by monkeyracing View Post
Anyone know where to get rebuild parts for the 3Racing gear diff, or even just the blades for the outdrives? Seems to be out of stock or discontinued everywhere I usually look. How about any other blades that will fit?
EDIT: Discovered something interesting about my M05 tonight. The gearbox actually gets tighter as it heats up during a race. Before the race, smooth as silk. After a race, noisy with extra friction. Let it cool, loosens up. Very weird. Seems the tolerances are much tighter than in the past. I may file a tiny bit of material from the bosses where the gear shafts mount. to see if that alleviates a little pressure.
I noticed the same thing, but wasn't 100% sure what it could be.
After a race, quick check and it felt like something was binding up.
Usually only a few minutes between classes, so I don't get much time to look, by the time Mini class comes around its all good. My assumption was must have had a small rock somewhere and its fallen out while I was looking for the problem. Next race, same thing, get home with more time to look, and its perfect.
Really hard to find a problem that doesn't exist
Brad
Xray T4 '16, Xray X1, Tamiya M05 Ver.II Pro.
X-ray XB4 '16, TLR 22 3.0, TLR/Exotek 22T 2.0, Mugen MBX7R Eco.
bd581 is offline   Reply With Quote
Old 10-15-2014, 02:18 PM   #22219
Best solution I've found is let it cool. Weird.
What's a "smore rack"? Sounds either delicious or pornographic.
EDIT: Just ran the car on a stand for half an hour. Even at low speed with no load, things heat up a tiny bit and begin to bind. I have a sneaking suspicion it's the motor plate. They did take a fair bit of material out of it for the new design. Next time the car is apart, I'll try it with the V1 motor plate.
Stab it and steer.
Old 10-15-2014, 02:35 PM   #22220
eR1c's Avatar
you don't know what a Smore Rack is?
http://www.beyondthekitchensink.com/...re_to_love.jpg
-don't worry the URL is safe for work.
eR1c is offline   Reply With Quote
Old 10-15-2014, 03:49 PM   #22221
I must admit to a degree of disappointment.
Stab it and steer.
Old 10-15-2014, 06:28 PM   #22222
bd581's Avatar
LOL
Its a thing caused by typing too fast before someone sees me on forums at work!
Brad
Old 10-16-2014, 06:54 AM   #22223
chef88's Avatar
Trader Rating: 48 (100%+)
Default Droop
Thought I saw somewhere on this thread that TQ racing had droop screw strips that protected the chassis from digging in.
There was a pic.... do believe as well.
Wondering where that was & if they are still available.
Has anyone used these with any success?
X -Ray X1.TRF 101
Rebel 12, T4 2017.
Maryland Funster/ Beneteau 373.
180 Raceway/ Johns Mobile Raceway.
chef88 is online now   Reply With Quote
Old 10-16-2014, 02:14 PM   #22224
KA2AEV's Avatar
Oh Man, here we go again
Hauler Driver, Liason, Lead Mechanic, Crew Chief, Procurement Specialist,
Conflict Resolution Specialist, Pychologist, Therapist All for Team Golddust Racing
Oh and By The Way
NBCsn and FxSports cable is growing on me too!
KA2AEV is offline   Reply With Quote
Old 10-16-2014, 06:04 PM   #22225
You can make you own out of steel from a can or a razor blade. A Dremel, a little talent, a dab of epoxy and you're set.
What? Who could possibly take that the wrong way?
Stab it and steer.
Old 10-17-2014, 04:37 AM   #22226
Robert_K's Avatar
So, did anyone test an M03 vs a M05V2 back to back? Which is faster?
In previous tests the M05V1 was slower on carpet vs the M03
Regards Robert
Sponsored by: Schumacher Racing and Dualsky
Supported by: Shepherd Benelux and Thunder Tiger.
Robert_K is offline   Reply With Quote
Old 10-17-2014, 07:46 AM   #22227
marcos graveyar's Avatar
Send a message via AIM to marcos graveyar
This what you're after ?
http://www.tqrcracing.com/shop/produ....asp?p_id=1615
marcos graveyar is offline   Reply With Quote
Old 10-17-2014, 09:01 AM   #22228
Trader Rating: 27 (100%+)
Regards Robert
I ran both cars back to back this summer on the asphalt. Both cars ran identical laps times, but felt completely different.
The M03 was a very direct feeling car. It drove like a Cadillac and turned really well. It wouldn't do anything stupid while driving it.
The M05v2 is a nimble little beast. It does carry more corner speed but because of the reduced chassis roll, I had to find other ways to make it turn. The car transitions much more quickly that the 03, but can get a little happy in the back end and want to step out on occasion.
We all have a lot of time in the 03's and I think with a little more time running the v2 we will get faster than we were with the 03s.
Former RC fanatic just trying to keep up......
BSR Tires / Spektrum RC
Jamie Hanson is offline   Reply With Quote
Old 10-17-2014, 09:02 AM   #22229
Check with Mark T. I think he tried these, but they were too thick.
Old 10-17-2014, 09:10 AM   #22230
Trader Rating: 69 (100%+)
Right on Jamie! I did not prefer the spec r down stop discs. I preferred the razor blade pieces. Please wear eye protection while breaking razor blades. Also use two pliers and nip the pieces into the sizes that are needed. Please be careful and I do not condone or recommend this. only professional razor blade breakers shall do this mod. seriously.
Markus is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
