Like Tree21Likes
Old 10-30-2006, 06:03 PM   #2206
sup
sup's Avatar
if the m03m front suspension is really from the ta04, then maybe there are caster blocks available for it? ..just thinking out loud, i never had a ta04.
sup is offline   Reply With Quote
Old 10-30-2006, 08:49 PM   #2207
Jam-ehz's Avatar
Send a message via ICQ to Jam-ehz
Well, the 03M design is based on the TA04/LWS, but are not physically compatible..
-=≡ Tamiya TA05 TRF415MSX F103R M-03R M-04 M-05 ≡=-
-=≡ CRC Carpet Knife 3.2 OFNA LD3 Pro Fastcats Spektrum ׀ווlı ≡=-
Jam-ehz is offline   Reply With Quote
Old 10-30-2006, 09:33 PM   #2208
akuhon's Avatar
Originally Posted by sup
akuhon,
nice body! can i ask where i can order one (if online, could you post a link)? i could also see that you got a no rules m03 under the body (foam tires & modified bumper, i think), could you also post a photo of the chasis? im interested coz we're having an unlimited m chasis race in a month. still have to tinker a lot if that pushes through.
I order all of my bodies from Champ ... my outlaw mini race body is a NorthCraft Skyline GTR .... I like it and it has a good handling
Two other bodis that interest me are :
Chevron Model "Monster M". It's a cooper with the wing ..
And also this :
It's Yaris or Toyota Vitz in Japan.
I will take my m03 pics later
akuhon is offline   Reply With Quote
Old 10-30-2006, 09:40 PM   #2209
akuhon's Avatar
Originally Posted by DrKucho
caster is only in one side, i dont know if it is positive or negative , i think it is not called neither those, just "N degrees of caster", from 0 to positive values
http://users.pandora.be/elvo/4/2.html
The 53226 can be swap A-B or B-A (the C-hubs been marked A and B) depend on the car .... minimanintaiwan is right.
See the back cover ... for FWD it's negative caster and for RWD it's positive caster .. for 4WD sure it should be positive...
Check my reference here ....
Caster Angle Basic
then see the advance caster angle info ...
Happy reading ....
Old 10-30-2006, 09:49 PM   #2210
akuhon's Avatar
Originally Posted by MrBlack
If many of you like this body I would suggest you write to Tamiya USA and JPN and let them know. They never (or limited) released it here in the states because at the time we did not have the Fit available. Now that we do though if there is a demand maybe they would be swayed to fire up the mold and update the licensing agreement to make more body kits. They have done this before with other units but the customer must contact them directly to make the biggest impact.
There are actually many good bodies out there. but for minis it seems Tamiya don't make that much.... I think we can ask them (to Tamiya or HPI) to re-release their mini bodies .....
But for currently available bodies, I suggest to see other manufacturers especially ABChobby, active hobby also North Craft and Chevron models.
Old 10-30-2006, 09:51 PM   #2211
sup
sup's Avatar
thanks akuhon! saw the active hobby site too in the yaris body. hmm.. now i'm torn between the yaris and the jazz.
Old 10-30-2006, 09:59 PM   #2212
akuhon's Avatar
Yaris is for playing / racing, and Jazz only for showing 'cause it has the lightbuckle.... IMO
Here's my mini race body ... the Northcraft skyline GT-R (comical edition a.k.a funny)...
Old 10-30-2006, 10:26 PM   #2213
sup
sup's Avatar
akuhon, are you having problems with the foam tires coning towards the inner part of the tire? if you do, do you true them after how many runs/batt packs? thanks!
Old 10-30-2006, 10:39 PM   #2214
akuhon's Avatar
Yes.. that's one of the problem using the foam tires... the outer part worn so quick .... And it's getting worst if you use those 53226 option part ... but it handles lot better .... it's predictable.
About how many runs I can't exactly say. It's all depend on the track condition and the tire itself but mine usually true them after 3-4 packs of 3300 mah with stock 19T or 23T motor ..... My tires is Kawahara shore between 35-41 depend on weather.
I've been looking for adjustable upper arm for camber setting, but no luck so far ... I try to make one but the upper link is kinda too short ....
One possible thing is to make a new positioning hole for the upper link which attach to the chassis.. I did it and it works but it need to revamp the front part of the chassis...
Old 10-30-2006, 10:54 PM   #2215
akuhon's Avatar
I think only the knuckles ... the rest (suspension and hub) doesn;t give you any advantages ..
The only suspension set that resemble those TA04 is 53467 TL-01 / FF Long Suspension Arm ... one piece suspension arm (not a two-pieces / clamp shell design) also the front hub and front knuckles can be inter-changed with TA04 part ....
Old 10-31-2006, 01:15 AM   #2216
The Active Vitz has light buckets and mirrors also.
Sydewynder is offline   Reply With Quote
Old 10-31-2006, 01:33 AM   #2217
Caster Angle Basic
Happy reading ....
wow i just read the article you posted, i never heard before about negative caster, it looks like it is a good option for minis
but then i dont understnad why you said minimantaiwan is right ... ?
also i think the article misstake on the pictures, the supermarket trolley wheels shown when explaining FWD and RWD are swapped ... if i get it right ...
DrKucho is offline   Reply With Quote
Old 10-31-2006, 03:27 AM   #2218
Negative caster is not a good idea.
Positive caster gives you something called camber rise. This is an increase in negative camber on the outside wheel as it turns. When your car turns and the chassis rolls, with camber rise (gain) hopefully you will end up with and large contact patch in the center of your tire for max grip. With negative caster your outside wheel will get positive camber (top of the wheel tipped outwards) as the wheel turns. You end up riding on the outer edge of the tire. To see what I mean take a look at offroad trucks and buggies. They have alot of positive caster. Look from the front straight back and turn the wheels. You'll see negative camber gain on the outside wheel. The Tamiya minis we run have positive caster. It comes from the kick-up built into the chassis. The shopping cart example does not work here. The pivot axis is still straight up and down (vertical). Its just that the wheel is offset back (trail). Theres no camber change. On RCs the pivot axis runs through the wheel. The stability in shopping cart is solely due to trail and not negative caster.
Akuhon:
Maybe this is why the outside of your foam tires wear out so fast. You're getting positive camber change running the C Hubs reversed.
Old 10-31-2006, 04:48 AM   #2219
Customworksking's Avatar
Trader Rating: 71 (100%+)
Talking mo3m
the M03 M03m amd the m03L R all the same car the spacer is "M" mid size where thr L is long and the M03 has no spacer..
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 10-31-2006, 05:21 AM   #2220
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
But the M03M has different knuckles and uprights. Suspension arms are all the same.
tamiyarcracer is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
