Like Tree39Likes
Old 08-30-2014, 12:06 PM   #21946
OSherman's Avatar
Buttonhead screw?
•KO Propo America
•EXOTEK
OSherman is offline   Reply With Quote
Old 08-30-2014, 12:09 PM   #21947
OSherman's Avatar
If you go into the race 'knowing' you are not going to win, guess what. Inferior cars can win yes, if you know that inferior car can win.
•KO Propo America
•EXOTEK
Old 08-30-2014, 07:51 PM   #21948
Originally Posted by OSherman View Post
Buttonhead screw?
buttonhead hex titanium, with a spacer
torg is offline   Reply With Quote
Old 08-30-2014, 09:19 PM   #21949
OSherman's Avatar
spacer or washer?
•KO Propo America
•EXOTEK
Old 08-31-2014, 09:49 PM   #21950
spacer or washer?
looked like a washer, but you'll have to check with grissom
Old 08-31-2014, 10:24 PM   #21951
bd581's Avatar
First run with my new V2 on the weekend.
Some understeer issues to sort out, but otherwise very impressed. Felt better than my M05 right away.
Brad
Xray T4 '16, Xray X1, Tamiya M05 Ver.II Pro.
X-ray XB4 '16, TLR 22 3.0, TLR/Exotek 22T 2.0, Mugen MBX7R Eco.
bd581 is offline   Reply With Quote
Old 09-01-2014, 07:30 AM   #21952
Just a quick thank you to Grandpa and any others who have given bits of advice to me lately. Only been racing since October and only done about 6 outdoor meetings so a relative newcomer to this.
Yesterdays club meet I finally got to tangle with the big boys and held my own. Out of 3 A finals I got 4/2/2 and the 2 second places I was bang on the tail of the winner.
Biggest improvements have been
1) Reducing the toe out on the front wheels
2) Sorting the steering out (See servo not set @ 90dg)
3) Improving motor performance (Grandpa)
The biggest improvement though is gluing the tyres. WOW!! I ran one heat with them unglued and then I tried it on some really badly worn tyres. It was like all the handling issues on my car disappeared. I settled down and was able to race rather than balance racing with crashing. 2 heats and 1 final down I hadn't crashed for 3 races. Last 2 finals I came second in I basically gunned it and trusted the car. Still on badly worn tyres.
Cant believe it has taken so long to try this out but I suppose it helped getting the car to the point where it felt as sorted as I could get it, then try the gluing.
Next step is a fresh, properly run in motor, some voodoo drops, fresh tyres and reduce some of the weight as my car is running extra.
Thelittlesthobo is offline   Reply With Quote
Old 09-01-2014, 10:14 AM   #21953
Congratulations on your good results and glad to be of help. You've reached the point where the "chasing" set ups becomes really interesting much sooner than most. A lot of the progression of skills now becomes an analysis of what you need for the car to go faster and what your driving skills will tolerate. For example do you increase front grip to go faster or do you free up the rear???? Figuring out what does what is the interesting part along with how you use it. How to compensate for changing track conditions is another.
Gluing ties can be a real revelation. Try playing with a few different techniques as far as how far you carry the glue. This really makes a difference on the fronts. I've usually found that on the Tamiya S-Grips it's best to go right to the tread. On some brands of tires, it's counterproductive, but on most 60d tires it's helpful.
Also, weight reduction is probably the least important of all the things you can do. As you said, you're fairly new and I'd explore chassis set up more before going on a crash diet. Most weight reductions can change the balance of the car and also the flex of the chassis. If you don't have a solid knowledge of what does what, you can find yourself in a whole heap of trouble.
Granpa is offline   Reply With Quote
Old 09-01-2014, 02:52 PM   #21954
-jacob-'s Avatar
http://cgi.ebay.com/ws/eBayISAPI.dll...ht_1320wt_1338
- Good deal
www.teameamotorsports.com
www.seattlercracers.com
-jacob- is offline   Reply With Quote
Old 09-02-2014, 02:18 AM   #21955
Hi Grandpa, thanks for the response.
One of my jobs this week is to make a crib sheet of all the measurements etc so that I have a base setup that I know works for me. When doing so do you guys measure ball joint to ball joint or total length? Ie the shock length including the plastic mounts or the distance when the shock is fitted between the ball joints.
The tyres I run are sweeps front and shimizu (sp) on rear. The rear tyres have lasted 4x the sweeps usually last so they are my preferred tyre. Trouble is on the front I haven't found a setup that can get them to work. As I mentioned previously the fronts were wrecked and still the gluing made a massive difference. Looking forward to trying it on a fresh set.
The weight I am going to shed is surplus I have added already. My bumpers have weights in them and I have weight underneath the servo which works well. But I was also running extra weights on top of the bumper and along the battery and at the rear so it was rather excessive. Talking to the fastest guy at our track who has wiped the floor with everyone in mini class he said I was running extra weight for no reason.
Mini class is really taking off here. We are only a small club but we have nearly 30 regular mini competitors for club events.
Old 09-02-2014, 03:40 AM   #21956
Johnn27's Avatar
Trader Rating: 66 (100%+)
Thumbs up M05RA front hubs
Just an FYI: I switched out my front aluminum hubs for the M05RA aluminum hubs and you need to change the front bearings from 1150 to 1050's
Johnn27 is offline   Reply With Quote
Old 09-02-2014, 07:26 AM   #21957
2 quick questions: Is M03 still TCS Legal? & Anyone want an M03 roller? Wife says I have to sell some stuff if I want to buy new stuff, so the spare 03 is on the block =\
pizzaboy192 is offline   Reply With Quote
Old 09-02-2014, 11:11 AM   #21958
marcos graveyar's Avatar
Send a message via AIM to marcos graveyar
M05 editable set-up sheet is at http://www.petitrc.com/reglages/tami...SetupSheet.pdf
M05 Ver.II Pro is at http://www.petitrc.com/reglages/tami...SetupSheet.pdf
marcos graveyar is offline   Reply With Quote
Old 09-02-2014, 01:05 PM   #21959
Originally Posted by marcos graveyar View Post
Thank you. Much appreciated
Old 09-02-2014, 08:59 PM   #21960
jdawg81's Avatar
I have the 3Racing gear diff installed in my M05 but would like to get some spare out drives for the diff but I can't seem to find the part. The checked the manual and it also doesn't mention what the part number is. Does anyone know where I can get this part?
jdawg81 is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
antlockyer
