Like Tree110Likes
Old 10-23-2006, 07:06 PM   #2161
tony gray's Avatar
Originally Posted by waltuo
I'm using a Manta Ray Diff Gear set (part #53070). Is it common for this part to fail?
I've included a photo, but since I don't yet have a macro lens, this is as much of a closeup as I can get. It should get the point across.
OK, well it's not uncommon at all for this to happen. The problem can indeed be partially attributed to not having the o rings in as this is often the cause.
But, a large part of the reason is that the metal used on the diff halves is a really cheap 'pot metal' and it is simply not very strong. And the Manta Ray ones are worse than the TA03 ones for some reason. Since switching to TA03 items I've never stripped one. But back previously, we used to glue the outdrives in to stop this happening.
Tony
tony gray is offline   Reply With Quote
Old 10-23-2006, 08:57 PM   #2162
waltuo's Avatar
Well, thanks for the responses. No, the diff wasn't too tight, it had great diff action ... right up to the wall. 8) And yes, I did have the o-ring in. I'll try the TA03 parts next time.
011011110111010101110100011011000110000101110111
a waltuo production
http://vimeo.com/iamwaltuo - http://youtube.com/iamwaltuo
waltuo is offline   Reply With Quote
Old 10-24-2006, 09:45 AM   #2163
JamesArluck's Avatar
Trader Rating: 52 (100%+)
Send a message via AIM to JamesArluck
Sorry if this has been covered already in this thread, but what are you guys using to glue your foam insert strips together? I've tried everything (CA, 3M#77, shoe goo, kinwald bomb insert glue, etc.) and it either ends up making a hard spot in the tire or it soaks into the foam so it doesn't rebound when you compress it.
-James
JamesArluck is offline   Reply With Quote
Old 10-24-2006, 11:04 AM   #2164
bizkit1's Avatar
Trader Rating: 27 (100%+)
-James
Usually I use rubber cement, just a dab in the center on each side. Lately I'm just using 26mm HPI inserts cut to fit. Good luck.
George
bizkit1 is offline   Reply With Quote
Old 10-24-2006, 12:15 PM   #2165
-James
I use rubber cement (Elmers). Brush a thin coat on both edges and let them dry apart for at least 10 minutes (dry to the touch). Push the 2 edges together and put a piece of tape to hold and let sit over night to cure.
The reason I dont push the edges together when the glue is wet is because it soaks into the foam too much and does exactly what you said about the foam compressing and not rebounding.
Don't use CA. It gives you a hard spot.
Sydewynder is offline   Reply With Quote
Old 10-24-2006, 01:10 PM   #2166
MrBlack's Avatar
I use insert strips my technique is to use tiny 2 or 3 dots of CA on the bottom edge ( edge near the rim) then i use Blenderm ( tape used for RC airplane flaps) tape around the whole insert this tape is sticky yet super flexible and allows the insert to work the tiny dot (I use a thin toothpick to apply it) keeps it from wanting to seperate.
TEAM ORION - AVIONICS - KYOSHO - KO PROPO - PEAK
"Racing is about the journey not the destination if it wasn't it would simply be called Arriving"
"The solution is people need to spend more of their efforts on promoting and finding more people to race with, rather then a personal quest to form a class that they can win at."
MrBlack is offline   Reply With Quote
Old 10-24-2006, 03:38 PM   #2167
minidriver's Avatar
-James
DAP Contact cement works very well - no hard spot. You can get small bottles just like rubber cement, but it holds much better than rubber cement. Apply to both ends to be joined, let it sit 10 minutes, then push the ends together. If you don't want the insert to expand or perhaps come apart, then take and wrap around the outside of the newly constructed insert with one round of black electrical tape. I do that to all my inserts now for mini with great results.
As my favorite Tamiya mini insert is no longer made (black hard shaped insert), I now make my own by purchasing the Tamiya black shaped insert for sedans, cut it and remove about about 1.25", contact cement and electrical tape it back together, and you have the same now discontinued mini shaped insert. The insert material of the black sedan insert seems to be the same consistency as the black mini insert. You do not have to remove anything from the width of the insert, they match up perfectly going from the 24mm sedan to the 60D series mini tires widths.
minidriver is offline   Reply With Quote
Old 10-25-2006, 01:21 AM   #2168
Guys i got a question.
In holland there is a new tamiya swift winter series and we mostly drive on carpet. We are only allowed to drive tamiya 60D (stock) 60D M grip and 60D Reinforced Type A tires. My question is what tire works best on carpet?
thanks,
wouter
Wouter.Z is offline   Reply With Quote
Old 10-25-2006, 06:22 AM   #2169
waltuo's Avatar
Silly question: Why glue the foam together? It's not like the motor generates enough force to counteract the effects of the tire holding the foam together to pull it apart by centrifugal force. If the motor could generate that much force, then the foam would bunch up to account for the lack of space inside the tire and the gap between the foam ends. However, the centrifugal force would spread that "bunch" out evenly since it's contained within the tire. Thus the foam would always be evenly distributed within the tire.
At least, that's my two pennies.
a waltuo production
Old 10-26-2006, 01:04 AM   #2170
tony gray's Avatar
New update on rc-mini.net up now.
First photos of a completed Tech Racing 4WD Mini. And yes, it's every bit as good as you might have hoped, maybe even better.
Check it out and then check your bank balance
http://www.rc-mini.net
Old 10-26-2006, 08:44 AM   #2171
minimanintaiwan's Avatar
Anyone know about a tamiya m-chassis shaped insert #53223.? They're discontinued but was wondering how they performed and why they stopped making them. I'm cutting down touring car inserts and using pit shimizu tires with ABC hobby rims. Performs really well and lasts quite a while. No significant grooving along the one side of tire. Rims don't have a single crack or bend after countless crashes
minimanintaiwan is offline   Reply With Quote
Old 10-26-2006, 09:16 AM   #2172
Customworksking's Avatar
Trader Rating: 73 (100%+)
Default tire
i use sedan inserts cut to fit
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 10-26-2006, 10:48 AM   #2173
minidriver's Avatar
If you don't glue the ends together (or you don't glue them well and they come apart) you wind up with a flat spot in the tire that you can definitely feel while driving - like an out of balance wheel, only worse. The shaped insert leaves a bit of an air gap between insert and tire, so the expansion you mention doesn't work.
Old 10-26-2006, 11:45 AM   #2174
Turbonium's Avatar
Send a message via Yahoo to Turbonium
hey Dave.... any ideas on the liners for the front tires? i have tried Ms locally, with molded liners, but all i get is rollin'... currently on kits/S's, not bad, but a little pushy.
i know for the A's i run on asphalt, i stuffed a full uncut TO Medium insert in there, but with the treaded tires, it still acts like it needs more!
and on a side note for you WI guys... has there been mention if the Swift body will be OK for the Novak race, or are we gonna stick with Coopers?
Wes
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 10-26-2006, 12:08 PM   #2175
Bikerbob's Avatar
Send a message via ICQ to Bikerbob Send a message via MSN to Bikerbob Send a message via Yahoo to Bikerbob
Anyone still running a std wheelbase MO3?
If you are successful with it could you share the setup with me.. PM if you want.
I run indoors on Ozlite carpet.. I have not bothered to install the ball diff yet. ( I have one) and the hollow shafts. I am more worried about driving setup.
James
Bikerbob is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
