Like Tree1Likes
Old 07-15-2014, 06:51 AM   #21586
Trader Rating: 23 (100%+)
Originally Posted by xtrememadness View Post
Sorry jamie, you are correct. You can use a 50c square pack. I just meant that the round packs come in 50c and the square packs are harder to find below 65c.
Sounds good. Thank you for checking on that.
Former RC fanatic just trying to keep up......
BSR Tires / Spektrum RC
Jamie Hanson is offline   Reply With Quote
Old 07-15-2014, 09:18 AM   #21587
To JosB and sosidge there is something you should take into consideration. These are our rules and YOU shouldn't comment. It's like telling someone his wife is ugly. While it may be true, it just isn't something that anyone with even a little common sense would do. Good God man, you don't see us commenting on your rules cause we don't race them and don't think that our comments would be helpful.
Frankly, your snide comments about our series just pisses me off. And as glad as you are that you don't race the TCS Series in the USA, I'm certainly more glad you don't.
If this upsets you two or anyone else, tough. I'm just a little fed up with this BS coming from people that don't race here.
Granpa is offline   Reply With Quote
Old 07-15-2014, 09:19 AM   #21588
OSherman's Avatar
Originally Posted by JosB View Post
?... you can get any chassis to do all those things by adjusting setup, what do you mean exactly?
Yes, you can tune each platform to do such. But what he is implying is that 'by design' each platform layout has such character traits. And he is absolutely correct.
•KO Propo America
•EXOTEK
OSherman is offline   Reply With Quote
Old 07-15-2014, 09:27 AM   #21589
Send a message via ICQ to JiuHaWong
nm
오늘의 청소년들이 미래의 문제를 처리 할 준비가 병 슬프게도 있습니다 우려하고있다.
JiuHaWong is offline   Reply With Quote
Old 07-15-2014, 10:54 AM   #21590
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
for the guys that have run their mini's under the new TCS rules (21.5/blinky)
what kind of setup changes should I expect to make? running it at the same track it was last run at, so track conditions shouldn't vary too much..
just curious what to expect from the car
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 07-15-2014, 11:14 AM   #21591
kwkride's Avatar
I don't know of anyone that had to make any changes to their setup here.
The car is slower with the 21.5 blinky than it is with a silver can.
Jim
"If God had meant for us to drive through the front wheels, he never would have allowed us to invent the ring & pinion"
kwkride is offline   Reply With Quote
Old 07-15-2014, 11:20 AM   #21592
k_bojar's Avatar
really?? i'm sure compared to a properly prepared silver can
how did you compensate for the added torque of the 21.5...I know on my table it seem to definitely spin the wheels a ton more then with the silver can I had in there
Old 07-15-2014, 11:24 AM   #21593
kwkride's Avatar
We don't run any timing in our motors either. There's a couple of new guys that have the silver cans still. They can easily pull us on the straight, we just make up for it on the rest of the track.
Jim
Old 07-15-2014, 11:31 AM   #21594
k_bojar's Avatar
thanks, Jim...
I guess i'll be ok with what I got in mine and adjust as necessary.. I'm sure the guys i'll be running with will be running all sorts of timing in their motors - so I doubt I'll be lucky with getting away with no timing
Old 07-15-2014, 12:22 PM   #21595
Originally Posted by Robert_K View Post
Anyone now where to get the M03 A-parts, the black plastic. Not the gray plastic?
Thanks in advance, Robert
you can get it from this kit on ebay
I have two of these kits and can confirm it's black plastic. This particular listing is without the all important body so it's of no interest to me.
torg is offline   Reply With Quote
Old 07-15-2014, 12:42 PM   #21596
OSherman's Avatar
The mystery piece of the puzzle is that not all motors are the same when it comes to how much timing is 'dialed in'... If you set all motors of different brands to 20• per the label-marking on each can for example, they will all run differently.
rite now the KillShots seem to be the fastest in sheer straight line speed. I'm running and prefer the R1-Wurks.
In my humble opinion from experience, leave the unlimited battery option and varience in motor performance kinda works itself out believe it or not. It's tough for me to catch an M03 down the straight if I don't exit the previous coner just rite and vice versa. I have to catch them in the infield. The speed difference are not that great, it actually comes down to who has the better line and handling.
•KO Propo America
•EXOTEK
Old 07-15-2014, 01:10 PM   #21597
Yeah, with the limited gearing on these cars, it seems like RPM based motors like the killshot/R1 is better suited. My vote goes to the R1 though.
Kyosho Inferno MP9 TKI4
TLR 22 3.0
Apex RC Proshop
inpuressa is offline   Reply With Quote
Old 07-15-2014, 01:23 PM   #21598
So everyone is running an FDR of 5.8:1? At least that is what I recall the lowest FDR was on my last M03. That seems like a silly high ratio for a 21.5 that really needs to be closer to 3:1 no? Which makes me chuckle a bit at the whole C-rating argument currently going on regarding batteries as the motor has a relatively low load to be able to take advantage of any additional current capacity that the battery would be able to provide.
You can find me at the folllowing sites:
twowheel at rcracing.com
FuriousFlip at ultimaterc.com
K.O.M. at rccrawler.com
TW@ at vwvortex.com
TwoWheel is offline   Reply With Quote
Old 07-15-2014, 01:32 PM   #21599
kwkride's Avatar
Which is why we just run them with no timing now. It makes them all pretty close.
Jim
Old 07-15-2014, 01:50 PM   #21600
monkeyracing's Avatar
I had my FDR down around 4:1 once, using cheater gears and some tweaks. On our relatively short carpet track, I killed a silver can in a few laps. Tried running with hi-po fans. Still melty. Also tried the same gearing with a 6t. Really hot! I found the fastest thing was the 6t Hobbyking motor and a 16t pinion with stock gears. Stood on it's nose every time I braked, capable of disintegrating tires if run on the bench!
Stab it and steer.
monkeyracing is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 05:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-02-2011 12:08 AM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 09:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 07:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 08:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
