Like Tree18Likes
Old 07-04-2014, 07:20 AM   #21511
Originally Posted by JosB View Post
Hi, I've been racing mini for a couple of years now and have to say I'm totally hooked... Also been reading this thread for years now and just lovin' it.
I've raced my M05 for some time now and looking for the next step... M05vII... I know where to order but WHEN?! I can't get a guarantee, only a notification of when the kits arrive when I ask the shop...
It's my first time trying to pre-order something so am I missing something? The question really is.... is there a shop that can guarantee me the product with a pre-order?
My hobby shop has one ordered through Great Planes, but no idea on its ETA.
sad_rocc is offline   Reply With Quote
Old 07-04-2014, 07:37 AM   #21512
Trader Rating: 25 (100%+)
For anyone looking for a kit, Tower Hobbies shows them in stock. I received an email they they were stocked on Wednesday.
Former RC fanatic just trying to keep up......
BSR Tires / Spektrum RC
Jamie Hanson is offline   Reply With Quote
Old 07-05-2014, 02:34 PM   #21513
Conrad's Avatar
Quick question, with Pit Shimizu wet tires, do you guys use the standard foam inserts or a moulded insert?
Swith Racing [www.swithracing.co.uk]
Conrad is offline   Reply With Quote
Old 07-05-2014, 03:15 PM   #21514
Johnn27's Avatar
Trader Rating: 66 (100%+)
Questions?? short wheelbase
I run med wheelbase but I am curious if anyone has tried running short wheelbase with the new 1 degree aluminum rear suspension mount?
If so what results?
Johnn27 is offline   Reply With Quote
Old 07-05-2014, 09:46 PM   #21515
If you're referring to the to the 60D series of tires, The Tamiya hard foam insert seems to be the best. Unfortunately. you should contact or rubber cement the ends together. Shimizu makes an insert that you don't have to do that with, but IMO is too soft. The insert that comes with the tire should be discarded.
Use the 456 or 454 in front, and the 454 or 452 in the rear. Te 450 for some reason just does not work.
Granpa is offline   Reply With Quote
Old 07-07-2014, 10:45 AM   #21516
KA2AEV's Avatar
Anyone know if there is a Cooling fan setup for the 03 and the 05?
Mike
Hauler Driver, Liason, Lead Mechanic, Crew Chief, Procurement Specialist,
Conflict Resolution Specialist, Pychologist, Therapist All for Team Golddust Racing
Oh and By The Way
NBCsn and FxSports cable is growing on me too!
KA2AEV is offline   Reply With Quote
Old 07-07-2014, 10:58 AM   #21517
Raman's Avatar
Trader Rating: 49 (100%+)
+1 Shimizu inserts are horrible. Discard them. I use the sweep inserts with Shimizu's. They come in soft, medium and hard
Raman is offline   Reply With Quote
Old 07-07-2014, 11:32 AM   #21518
OSherman's Avatar
First run with M05vII....
Is very promising. My original setup was garbage, but upon installing just new chassis and suspension bits the car seemed to carry abit more corner speed.
After a few coaching session from a local M05 guru this lil racer is very pleasant to drive.. Stays really flat in the corners. Still easy to drive and takes quite a bit to unsettle it.
Looking forward to putting more laps on it..
•KO Propo America
•EXOTEK
OSherman is offline   Reply With Quote
Old 07-07-2014, 01:04 PM   #21519
Mike
For the M03, the best solution is to silicone or Shoo Goo it to the chassis.
M05---3Racing makes a fan set up that most of the guys around here are using.
Right now, since we are trying to simulate the speeds of the new Spec motor for the Finals, fans are not necessary. We're having to back down the timing considerably. For example, I've turned the R1 to 20 from close to 50. I'm still playing with the Killshot, but that one turned down about 20 degrees.
It's going to be interesting to see what the rules are going to be for TCS Mini racing will be for next year. For myself, I hope we dial down the motors a bit cause these "cranked" 21.5 motors are too fast for the vast majority of us.
Old 07-07-2014, 01:59 PM   #21520
KA2AEV's Avatar
Okay thanks for the info on the fans
Gonna look around and see what I can dig up
I really hope that the rumor I heard about the 03 is not true
Otherwise this is really going to put a damper in my Mini Racing
Oh and By The Way
Old 07-07-2014, 06:03 PM   #21521
OSherman's Avatar
Which rumor is that?
•KO Propo America
•EXOTEK
Old 07-07-2014, 06:07 PM   #21522
Trader Rating: 69 (100%+)
I believe he's talking about this being the last year for the M03's eligibility.
Fans are easy on the M05. You just need a fan, spacer, and a longer screw. tip: I use a little thread lock on the screw so that I don't have to over tighten the fan screw and cause binding in the steering arm. Also a dab of shoe goo inside the fan hole so it doesn't spin.
Markus is offline   Reply With Quote
Old 07-07-2014, 07:39 PM   #21523
oreo's Avatar
Greetings Markus. Thanks for the tip with the fan- out of curiosity, have you shimmed the plastic steering pieces? Upon building my M05(v1), before applying the servo link, the area of the steering linkage as well as the mounts had alot of slop. Are you contending, at all, with slop?
Rc 10L (x6)
(.......in 2010, I jus' may get to run one.)-Irrgang Racing Service;TeamCRP. R.I.P. Billy 105
oreo is offline   Reply With Quote
Old 07-07-2014, 07:56 PM   #21524
ATM I'm throwing all idea's at the v2. I have the plastic parts on because I am hell bent on using a full size battery pack. I've been taking off all of the aluminum pieces and weighing them against their plastic counterparts. if the plastic is is lighter, it stays on the car for the most part.
To answer your question though, I have not tried to remove the slop. I'm a long time Tamiya plastic car racer and I find that the car settles into its pieces and becomes 'Sloptimized'. There is a point were the loose parts effect the performance to where I can notice it. (It takes a lot for me to notice) that's when I replace the plastic parts that are worn. So I don't usually shim, I replace plastics. Also, I use a futaba 9550 steering servo which is overkill for mini but it is not a torque monster by any means. If I'm not mistaken, I believe the aluminum steering arms take care of most of the slop.
I'll be at the Jackson, NJ TCS, maybe I'll see you there.
Old 07-07-2014, 08:01 PM   #21525
monkeyracing's Avatar
"sloptimized"
You sir, are my new hero.
I was thinking today that you guys running fans may not have to anymore, given the tamer spec motors in the pipeline. I know of no one here using one, with our similarly species systems. But, with the new chassis tucking the motor in, it could become a thing again.
Speaking of the V2, has anyone tried building it using the plastic motor plate? I'm curious to know if I'm wrong about it being wrong.
monkeyracing is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
