Tamiya mini cooper
dont worry im sure there will be some stupid and funny stuff getting posted on facebook page.
i cant believe its been 6 years since Tony built me a mini out of spare parts to run having never driven a mini. where have the years gone......
R/C Tech Elite Member
Facebook? Bah!
I'm not normally that generous, I'm usually a c**t.....
Usually? I think you mean ALWAYS.
Raman - part number 50736 TL01 B parts came with the original M03 and M04 kits and it was available in a reinforced/composite version, but I don't know the part number for the reinforced.
Last edited by Tim K; 05-28-2014 at 01:04 AM. Reason: Left out the word - composite.
that was back before lipos, brushless system and m05's. seems like just yesterday.
i do however remember you forgetting to put the 1150 bearing in the front diff and me not knowing driving around with it missing, to realize half way through the Harris Classic that it wasnt there.
That was probably the last time I beat you too...
assuming that I did.
Does it look like the old motor plate would fit the new chassis? The difference in motor offset would be minimal and it would save a chunk of change. Very happy to see a shorty pack fitted. Looks great!
Hi all
So last night I stripped teeth from one spot on my spur gear after a crash that stopped the car in it's tracks.
So I'm about to replace the set with either the stock white gears or the reinforced ones.
I'm sure I read some bad stuff about the reinforced set but cant recall what it was? I run the 3 Racing gear diff if that's relevant with silvercan power.
And how are you (or not) lubing the gears?
Thanks to all that have already helped me on this, I thought I'd post on here so the 'wider market' can have an opinion too!
I'll just leave these here
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LNELLT
In stock in china...
http://www.stellamodels.com.hk/58593...is-p-8240.html
http://www.tamiya-model.com/shop/tam...-90065875.html
can someone explain why arms and motorplate are needed for converting to the new lipo chassis. Why not just the chassis ?
This product was restocked to our store on Wednesday 04 June, 2014
