Like Tree1Likes
Old 05-22-2014, 11:53 AM   #21061
eR1c's Avatar
Not trying to beat a dead horse,
...But, I got really excited about this until I read the description:
No1. and No.2 phillip head screwdrivers are made from Nickel chrome molybdenum steel
1.5, 2, 2.5 Hex wrenches are made from Nickel chrome molybdenum steel
Size 5 minus (-) screwdriver
Size 5.5 & 7 box driver
Comes with a convenient driver stand
-specifically the info about the screwdrivers being "Philip's". Unless the description is incorrect?
...Tamiya in my opinion ought to include a proper JIS screwdriver w/ each kit that requires it.
eR1c is offline   Reply With Quote
Old 05-22-2014, 01:07 PM   #21062
whitrzac's Avatar
Trader Rating: 93 (100%+)
Tamiya ought to start including hex head hardware like every other RC manufacture.
whitrzac is offline   Reply With Quote
Old 05-22-2014, 01:15 PM   #21063
Raman's Avatar
Trader Rating: 48 (100%+)
They seem to have started.. The TB04 Pro II comes with hex, so hopefully it spreads to other kits. They should also do what HPI does, include machine hex and self threading / tapping hex for plastic
TRF419X / Pulse 17.5, T.O.P Racing Sabre Mini AWD / Impact 21.5, M06 Pro / Impact 21.5, XV-01 Pro Rallye / Kinetic 17.5
Raman is offline   Reply With Quote
Old 05-23-2014, 05:27 PM   #21064
poeee's Avatar
Originally Posted by inpuressa View Post
yeah, something like this will help with those kit screws.
I picked up one a long time ago on sale for little over $10. Perfect fit on the heads. The hex is meh though.
Good starter kit, just don't expect the small hex to be perfect. I have used and abuse this set of tools. Excellent value. Just the 1.5mm hex twists a bit. Plus I use the grey stand when doing my shocks!
Scott Pocock | Geelong Radio Control Car Club www.grccc.org.au
poeee is offline   Reply With Quote
Old 05-24-2014, 10:32 AM   #21065
Raman's Avatar
Do any of you trim the axles on your mini. I keep breaking the front right steering knuckle. While it's clear that the plastic is brittle, I am pretty sure the thread that is sticking out past the wheel nut is not helping either.
Old 05-24-2014, 08:02 PM   #21066
caltek1's Avatar
Trader Rating: 33 (100%+)
In response to your trimming of the wheel axles I do not as I sometimes use spacers to make the front end wider, which would not be possible if you cut them. I use the standard Tamiya universals up front and the hardened rear axles. I also use spacers on the rear for the same reason, although sometimes I actually fit 4mm hexs for more rear end grip.
I also use Tamiya alloy front knuckles. The only part I have broken up front is the c hub which I have done on both sides when I have hit something at the wrong angle or had a hit at full noise.
Hope that helps,
Calvin
caltek1 is offline   Reply With Quote
Old 05-25-2014, 10:09 AM   #21067
KA2AEV's Avatar
Ram, when our lead driver first started running the m05 he was breaking the front knuckles a lot until we upgraded to the aluminum knuckles and this solved the problem, I was thinking that trimming them would solve the problem, but it just seems that at that point on the chassis that the stress is extreme when contact is made in the front wheel area
Mike
Hauler Driver, Liason, Lead Mechanic, Crew Chief, Procurement Specialist,
Conflict Resolution Specialist, Pychologist, Therapist All for Team Golddust Racing
Oh and By The Way
NBCsn and FxSports cable is growing on me too!
KA2AEV is offline   Reply With Quote
Old 05-26-2014, 05:55 PM   #21068
Raman's Avatar
Mike
@ Caltek1: I run the M06 with the Alfa GTA body and if I space out the front axle, it will rub on the body. Rears I have not had any issues with breakage, probably because I'm running the 1 aluminium hubs.
@ KA2AEV. I generally don't like to run aluminium in the form of suspension arms, knuckles, C hubs or up rights, because it bends in crashes and its hard to tell that its bent. That is unless I have to, like on the rear, there are no 1, 2, 2.5 rear hubs in plastic.
The C hubs and knuckles seem to be made out of pure abs brittle plastic, where as other suspension parts seem to have flex put into the compound mix. I had hoped that with the Ver II they would update these parts, but it appears just the arms have been updated. So I may have to break down and pick up the front knuckles in aluminium. I will however try trimming the front axles first since they're fairly inexpensive.
Old 05-26-2014, 08:05 PM   #21069
KA2AEV's Avatar
Ram, the way he beats on the cars inthe quals and the mains I would have thought the same about the
Aluminum knuckles, but honestly ever since I installed them in the M05 that Golddust drives, we haven't any issues with parts bending or breaking up front. Keep us informed of your progress
Mike
Oh and By The Way
Old 05-27-2014, 02:19 AM   #21070
tony gray's Avatar
RIP rc-mini.net.
We kept the Mini flag flying for 8 years, and that's not a bad run.
tony gray is offline   Reply With Quote
Old 05-27-2014, 02:27 AM   #21071
sosidge's Avatar
Don't hesitate over the aluminium knuckles. They are plenty strong enough, and there is enough flex in the rest of the car to stop them bending.
I ran my car with plastic knuckles for a few years and didn't have a single issue. Then I started racing at a new track with different markers and I could barely finish a race without a knuckle splitting at the kingpin (oddly enough I would only lose a couple of tenths per lap!). Since changing to tamiya alloy I haven't damaged a thing.
Old 05-27-2014, 04:31 AM   #21072
+1 get aluminium knuckles stick with the composite C Hubs. Its a better combo compared to full alum or alum hubs/comp knuckles
cheapskate.brok is offline   Reply With Quote
Old 05-27-2014, 06:36 AM   #21073
Schs2013's Avatar
Originally Posted by tony gray View Post
RIP rc-mini.net.
Wow the site was up for 8 years.
Good job with it for all this time.
RIP rc-mini.net
VBC Lightning 10LM, Tamiya M05v2
Losi TEN MT, Traxxas 1/10 Summit, Vaterra K-10
-Marc Gill
Schs2013 is offline   Reply With Quote
Old 05-27-2014, 07:02 AM   #21074
monkeyracing's Avatar
Tony G, you're making me sad. I started driving RC 6 years ago, with minis from the very beginning. That site taught me everything, even if I ignored a large portion and wasted hundreds of dollars on useless bling. You were almost never wrong. I say almost because the M04 was a lovely car - only a teensy bit evil.
You've done a great service for all of us and kept the laughter, too. We just have to figure out where to point the next smart ass that comes along asking questions.
Thanks!
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 05-27-2014, 07:42 AM   #21075
axle182's Avatar
Trader Rating: 18 (100%+)
Send a message via MSN to axle182
Thanks!
The touring car class? lol I agree, thanks Tony and all at Rc-Mini, you guys ensured mini stayed a competitive yet still FUN class for alot of us.
Aaron "AJ" Freind
axle182 is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 05:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-02-2011 12:08 AM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 09:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 07:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 08:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
