Like Tree101Likes
Old 10-05-2006, 05:30 PM   #2086
bizkit1's Avatar
Trader Rating: 27 (100%+)
Hey Tony, it's on its way Also have you or anybody else ever seen a Tech Racing M01-M02 4wd conversion? I need some instructions or something
bizkit1 is offline   Reply With Quote
Old 10-06-2006, 03:10 AM   #2087
R/C Tech Charter Subscriber
Default M01 4WD conversion - Tech
Hi,
I have this part at home but only have a scanner at work - if you get stuck, PM me and I will scan the instructions for you on Monday.
Thanks,
Keith.
keithander is offline   Reply With Quote
Old 10-06-2006, 08:58 PM   #2088
minimanintaiwan's Avatar
Post tire wear
hi,
getting unusual tire wear on the inside part of front two tire. Specifically a straight line right along inside top portion of tire. Rest of tire is fine and gets normal wear. I'm using HPI x-patterns on HPI rims. This also occured on some pit shimizu tires. They were all glued properly and tires did not come off rims at anytime. We usually race on newly paved black asphalt in sunny hot conditions. Is this normal for the M03M's or M03's in general? My friends have similar wear.
minimanintaiwan is offline   Reply With Quote
Old 10-06-2006, 09:07 PM   #2089
killingtime's Avatar
nope, that's normal tire wear when you lower your mini and your negative camber increases. Put your mini together like you were about to put it on the track. Look at it from the front and you'll notice that your wheels lean in to the car at the tops, this is negative camber.
Mike Webb
rD Squared-MW Designs-C and R racing
Final Thoughts RC club R.I.P.
killingtime is offline   Reply With Quote
Old 10-06-2006, 09:11 PM   #2090
Default tire wear
hey Tony, read your section on tyres and the "groove" along one side. I'm pretty sure this is what's happening. But, i did take extra care in making sure inserts were properly aligned and snug. Is there a way/trick to do or check this? Should i go with touring inserts cut down and glued together? I really like the firmness of HPI tyres and inserts.
thnks
Old 10-06-2006, 09:15 PM   #2091
Default tire wear
hi killingtime, thanks. So to get rid of this wear i should raise it up to at least get a neutral "zero" camber?
Old 10-06-2006, 09:52 PM   #2092
i got same wear on my tamiya 60Ds till finally break one of thm in tha line , after the race it was almos cutted by this line
you may change camber to get the wear more in the middle , but be carefull cause your car wont grip the same way on the turns and probably wont do as good as before
DrKucho is offline   Reply With Quote
Old 10-06-2006, 10:57 PM   #2093
tony gray's Avatar
I'm afraid its just something that you really cant get around without compromising your correct setup. Not all tyres do it so its not worth changing your setup to get around it.
To be honest, once the tyre gets to the point where it's 'grooving' badly, the tyre's about dead anyway.
tony gray is offline   Reply With Quote
Old 10-07-2006, 12:31 AM   #2094
BigDogRacing's Avatar
Send a message via MSN to BigDogRacing
it's all about the inserts!!!
BigDogRacing is offline   Reply With Quote
Old 10-07-2006, 04:38 AM   #2095
bmr
BigDogRacing: What are you doing about inserts?
I did the narrow Tamiya inserts cut down and taped, and stuffed with the foams on top of them. I don't get as much of a line as the pic a couple of posts back, but it is still noticable. Car handles great, but does go through more tires than it should.
bmr is offline   Reply With Quote
Old 10-07-2006, 05:19 AM   #2096
Default Tech M01 & M02 M-Chassis 4wd Conversion Kit
Hi,
These pictures may help you out, I didn't take them but they are from someone who installed the Tech 4wd conversion quite a few years ago.
I have a new in box Tech conversion kit (part #TFM-19) that I have yet to install. As I said in the previous post, I will scan the instruction sheet and post for you on Monday - this should help you.
Thanks,
Keith.
Old 10-07-2006, 06:43 AM   #2097
bizkit1's Avatar
Man that is a nice conversion, but looks like alot of extra work. I've got 5 mini's now and I'll probabaly convert one of them just to toy around with.
Old 10-07-2006, 07:51 AM   #2098
Customworksking's Avatar
Trader Rating: 73 (100%+)
Lightbulb tire
hi,
I run them that way u get it from lowering the car /camber gain keep it that way it will ware flat and B hooked up soon otherwise u can rais the ride height and tracktion roll last year at trackside tcs race I got 2nd the winner's tire went from tred to slick ide say 2.5 to 3mm of tred outside in....my2cents
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 10-07-2006, 10:37 AM   #2099
badboy's Avatar
Trader Rating: 14 (100%+)
what's the main difference between the MO3 (old mini cooper body) and the MO3M (Swift Body) in terms of parts. . . aside from the body. . .
can i just get the extension part to make it an "m" version?
thanks!!!
slow is fast . . .
badboy is offline   Reply With Quote
Old 10-07-2006, 11:05 AM   #2100
HotrodHopkins's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to HotrodHopkins
yeah, no extention is the m03, large extention is the m03-l, and the medium extention is for the m03m, the swift will work with thte m extention.
SHAUN HOPKINS a.k.a NoRod Hopkins
-1990 Chevrolet K1500 Silverado TBI350 "Heavy Half". 1971 Chevrolet Nova
-My lug nuts require more Torque than your Honda makes.
HotrodHopkins is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
